Author Topic: Power Amplifier OTL 30W by IC TDA2030 +Transistor  (Read 1537 times)
Offline Alexis1989
Re: Power Amplifier OTL 30W by IC TDA2030 +Transistor
« Reply #20 on: August 16, 2011, 06:01:10 PM »
salamat po master tony
ilan po ba ang wattage n2 ngayon?
  • Pogi/Ganda Points: 522
« Reply #21 on: August 16, 2011, 06:02:14 PM »
same pa rin.....hindi naman nabago ang rail mo....
Offline Alexis1989
« Reply #22 on: August 21, 2011, 08:09:22 PM »
maraming salamat po sainyo working na po!!
« Reply #23 on: August 21, 2011, 09:40:35 PM »
good job......+1
Offline Alexis1989
« Reply #24 on: August 21, 2011, 11:32:15 PM »
tanong ko lang po
I used headphone jack for the input, the connection are in ground and left no connection in right
kulang po ung tunog, is it possible to short the left and right pin para makuha ko ung kumpletong tunog?
« Reply #25 on: August 22, 2011, 12:46:02 AM »
magmimix ung signal, mag series ka ng mga 3.3k or 33k ba un? nakalimutan ko ;D
on each channel
Offline Alexis1989
« Reply #26 on: August 22, 2011, 08:42:02 PM »
parang ganito po?
« Reply #27 on: August 22, 2011, 09:03:51 PM »
yes, test ka lang ng 3.3k or 33k, nkalimutan ko na eh ;D
Offline elmertronics
  • Pogi/Ganda Points: 6
  • expect the unexpected
« Reply #28 on: August 23, 2011, 07:54:16 PM »
14 watts na lang ba ang output power nito?. .'yon kasi nkalagay sa datasheet niya. .
« Reply #29 on: August 24, 2011, 06:00:37 AM »
yes, at Vss of +/- 19.......this means that an unloaded supply of +/-22volts which is maximum for this device will drop when delivering rated power into 4ohm....
you will not hear the difference betwen a 30 watt or 14watt amps when playing music...
you will see the difference when you test it under load using sine waves....
  • Pogi/Ganda Points: 136
« Reply #30 on: August 24, 2011, 06:35:49 AM »
parang ganito po?
220ohms lang gamitin mong resistor, wala na nmang preamp na kasunod. masyadong hihina na yung amp mo sa 1k pataas.
« Reply #31 on: August 24, 2011, 07:57:51 AM »
parang ganito po?
your midband gain is ~30000/3300 or ~ 9.1 say 10.....
for an output of 14 watts into 4 ohms, output voltage is 7.5v rms....
now your 24 volt rail gives you 12volt peak(assumes no voltage lost in the output trannies) or 8volts rms...
thus we can see that with the rail voltage as shown, it will not be possible to get 14 watts output...
another thing to consider is the voltage drop on the rail once big current is drawn from the supply...
therefore looking at the schematics alone does not give you the whole story....
we have to consider the completed amps with its power supply to find out exactly what the power output will be...
« Reply #32 on: August 24, 2011, 08:03:55 AM »
let us accept that this is true for the moment...
to get this output voltage, the input voltage then needs to be 7.5v/10 or 750 mV.....
now, today's gadget can give line outputs of up to 2.5 volts rms easy...
so that the 33k and 50 k input resistance then gives an input signal at maximum pot position of Vin = (33k/83k)2.5v = 993mV rams....
therefore the circuit as shown should suffice...
Offline RhedN14
« Reply #33 on: May 09, 2012, 10:08:30 PM »
Alexis1989 san po ilalagay ung potentiometer?paki explain po sorry noob lng dipa graduate eh 3rd year plang
Offline drin20
  • Pogi/Ganda Points: 17
« Reply #34 on: May 24, 2012, 09:03:22 PM »
sa input ng amplifier
