Author Topic: using smt components.  (Read 458 times)
Offline poorgrammer
« on: August 18, 2011, 04:08:47 PM »
mga sir, enge naman pong tips pag handle ng mga smt components like 4digit resistors at small diodes and ceramic caps,. i was able to salvage some of these small components from some old electrical device,. sayang naman,. gumagana panaman (sakto din yung values sa kailangan ko.). kaso gamitin ko lang sana sa bread boards or prototype boards, anu bang magandang paraan pag mount sa mga to? i know, first thing na kailangan ko malamang ay tweezer look-a-like pliers. anu po bang tawag dun. hmm... ska anu paba...
tnx po.
  • Pogi/Ganda Points: 630
Re: using smt components.
« Reply #1 on: August 18, 2011, 04:13:42 PM »
tweezer, marami niyan sa cellphone repair shop supply. ang recommended brand ko 'yung Win ang tatak (color black ang handle), matulis ang tip pero makapal sa puno kaya 'di madaling bumaluktot. BTW, I'm handling as small as 0402 passive components.
as much as possible, huwag silang gamitin sa breadboard, sa actual boards na. gagawan pa kasi ng adapter. though 'yung IC's pwede talaga, sa ibang components, waste of time lang.
Offline poorgrammer
« Reply #2 on: August 18, 2011, 04:15:40 PM »
ahh.. ok sir. thanks sa info. noted po.
Offline Macgyver
  • Pogi/Ganda Points: 70
    • MakerDude
« Reply #3 on: August 19, 2011, 11:07:31 PM »
yung iba sa protoboard muna ginagawa maski SMD components para di mo na kailangan mag etch.
Offline zrehtiek/keitherz
  • Pogi/Ganda Points: 45
  • PhilRoboKit Anito
« Reply #4 on: August 19, 2011, 11:08:49 PM »
saan pala may nabibiling SMD protoboard dito?
« Reply #5 on: August 19, 2011, 11:45:53 PM »
^ pwede naman sa underside nung protoboard. sakto 'yung sukat ng pagitan ng traces nun para sa 0805 or 0603.
« Reply #6 on: August 20, 2011, 12:22:53 AM »
gawa kna lang.
  • Pogi/Ganda Points: 412
« Reply #7 on: August 20, 2011, 01:50:08 AM »
I'm beginning to migrate on SMD..;D
Offline PlCUSER
  • Pogi/Ganda Points: 152
« Reply #8 on: August 20, 2011, 02:02:34 AM »
nagsabi ka sana nang maaga na migrating ka to smd. napadalhan sana kita ng samples.  :P
OT ka dito kas! gawa ka sariling thread mo nyan! ;D ;D ;D
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #9 on: August 20, 2011, 08:23:42 AM »
buti pa kayo ako hinahalo ko palang smd  :)
Offline Macgyver
    • MakerDude
« Reply #10 on: August 20, 2011, 09:47:10 AM »
wala talagang smd proto na puro pads dito sa Pinas (well at least wala pa akong nakikitang nagbebenta).  yung usual through hole proto board ang gamit.  yung pagitan ng 2 butas, usually enough na masingit dun yung smd resistors/caps/diodes.  may nabibiling protoboard na di-magkakaconnect yung copper sa underside.  yung iba yung ang preferred para mas macontrol nila layout.
pag smd chip naman, may nabibiling soic to dip sa e-gizmo.
Offline Macgyver
    • MakerDude
« Reply #11 on: August 20, 2011, 09:50:57 AM »
Santa paki sama naman ako sa list mo ng iisponsoran ng samples :)
Offline PlCUSER
« Reply #12 on: August 20, 2011, 10:33:23 AM »
no problem sir Mac. kapag napag connect ko na tong nike+ receiver at NRF tranceiver module, ipapangalan ko na sayo un isa jan.
« Reply #13 on: August 20, 2011, 10:57:27 AM »
Alam ko na padalhan mo ako nyan...luv mo ko eh..:P
at please lang wag mo na idaan sa custom....;D
Offline PlCUSER
« Reply #14 on: August 20, 2011, 11:25:00 AM »
Alam ko na padalhan mo ako nyan...kasi luv tika eh..:-*
bading. ewww.
Offline e-tronix
« Reply #15 on: August 20, 2011, 05:45:41 PM »
ate picpic ako rin.
Offline Macgyver
    • MakerDude
« Reply #16 on: August 20, 2011, 10:06:01 PM »
salamat !  Yahoo! :)
