Author Topic: philips shutoff  (Read 1873 times)
Offline xoochu
philips shutoff
« on: August 21, 2011, 09:49:41 AM »
..good day po masters!
ano po kaya problema nito?
21pt2325/71, nagsh-shutoff.  ???
philips shutoff
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
Re: philips shutoff
« Reply #1 on: August 21, 2011, 12:19:10 PM »
up lang natin ulit eto..
another protect problem na naman sir w8 din natin mga master ng phillips
post nyo poh lahat nyong nagawa...at lalo na sa vertical section voltages check post nyo poh lahat boltahe and check all ecaps
Re: philips shutoff
Offline m@r
  • Pogi/Ganda Points: 59
Re: philips shutoff
« Reply #2 on: August 21, 2011, 01:05:04 PM »
so ano na mga nagawa mo sir? nagvoltage measurement kana ba, nagresolder ka na ba? hirap yata manghula sir..! :D
it's not how much what we have but it's how we used what we have...
Re: philips shutoff
Offline mcguyver
  • Pogi/Ganda Points: 24
  • SLIPPERY WHEN WET
Re: philips shutoff
« Reply #3 on: August 21, 2011, 02:18:55 PM »
gaano katagal bago mag OFF? more info plzzz... may raster ba? sound? ilaw ba heater.. G2, voltage?, B+?, 9,12,5volts normal ba during ON and OFF.post nyo po lahat para madiling ma analyze...
NOTHING HAPPEN WITHOUT CAUSE
Re: philips shutoff
Online pete
Re: philips shutoff
« Reply #4 on: August 21, 2011, 02:26:51 PM »
pakitaasan ng kaunti ang screen sa fbt kong mag off parin
check 47uf/160v at 200v
Re: philips shutoff
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
Re: philips shutoff
« Reply #5 on: August 21, 2011, 08:12:24 PM »
abang muna....
Offline brucetech
Re: philips shutoff
« Reply #6 on: August 21, 2011, 11:08:48 PM »
ts, paki post na lng ng mga voltages sa c board....
Offline xoochu
Re: philips shutoff
« Reply #7 on: August 23, 2011, 10:21:11 AM »
opo. mataas ang rgb nia 200v.
may chip diode na nasusunog sa crt.
around 75 lang po ang screen.
walang raster.
nag-iilaw po ang heater
G2, voltage around 75V
B+ okay.
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: philips shutoff
« Reply #8 on: August 23, 2011, 12:00:07 PM »
pm mo si westleygulay taga philips yun...
Offline brucetech
Re: philips shutoff
« Reply #9 on: August 23, 2011, 12:17:06 PM »
masyadong mababa ang g2 mo..
 ung diode na sunog sa crt , saan poba naka connect?
Offline J@M
  • Pogi/Ganda Points: 122
Re: philips shutoff
« Reply #10 on: August 23, 2011, 01:47:21 PM »
San connected ang diode?
Don't Give up
Offline m@r
Re: philips shutoff
« Reply #11 on: August 23, 2011, 04:12:40 PM »
walang raster.
B+ okay.
sir check mo mga resistor niyan, check mo path ng G2 kung bakit masyado mababa...
Online pete
Re: philips shutoff
« Reply #12 on: August 23, 2011, 06:36:38 PM »
pwede hatulan ang tube hehehe joke lang po
hung mo ang c-board abang ang tester sa g2 saka mo power post mo kong ilang ang masusukat mo
Offline Tripler02
  • Pogi/Ganda Points: 85
  • Saka na my own pic
Re: philips shutoff
« Reply #13 on: August 23, 2011, 09:48:59 PM »
check 47uf/50v sa hdtrafo.
If you have a reason to live,then you have no reason to quit....
Offline J@M
Re: philips shutoff
« Reply #14 on: August 24, 2011, 09:50:46 AM »
Ts mzta na philips mo.
Don't Give up
Offline brucetech
Re: philips shutoff
« Reply #15 on: August 24, 2011, 11:35:25 AM »
ts, ano na? baka my problema ang fbt nito....
Offline m@r
Re: philips shutoff
« Reply #16 on: August 25, 2011, 02:07:03 PM »
abang nalang kami dito...  :D
  • Pogi/Ganda Points: 911
Re: philips shutoff
« Reply #17 on: August 25, 2011, 02:37:46 PM »
patambay..
just  focus on C board at gawin ang advice  ni pete regarding isolation ng Pics tube sa C board.
pag umakyat ang G2 mu...  alam mu na  ang posibleng  salarin  ;D
Offline xoochu
Re: philips shutoff
« Reply #18 on: August 25, 2011, 04:26:31 PM »
..ang diode connected po sa transistor
110V po. :)
Re: philips shutoff
« Reply #19 on: August 25, 2011, 04:49:29 PM »
hung mo muna ang wire ng G2 sa CRT board , then Power On mo habang na ka tutok ang tester mo sa Wire ng G2 na ini hung mo then Power On measure mo kung mag okay o tataas ang Voltages.
post kung anong result
Re: philips shutoff
