Author Topic: Sakura Amp Modification  (Read 8034 times)
  • Pogi/Ganda Points: 521
Re: Sakura Amp Modification
« Reply #20 on: August 28, 2011, 02:40:45 PM »
let us carry on.......
Q: with the 35volt rails, how much power can the circuit deliver to say an 8ohm load?
A: assuming rails won't sag and that Vce sat is 0, then we have 35volts peak, or 25volts rms, therefore at 8 ohms, power is about 80 watts...in reality power will even be lower because of losses...
Q: will adding extra ouput trannies increase power?
A: no, but the SOA is mitigated, lower ohm loads can be driven more safely.....
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #21 on: August 28, 2011, 02:40:57 PM »
heto, hinalungkat ko...
http://www.electronicslab.ph/forum/index.php?topic=23173.0
Vce = VR22 + VR23
; VR23 = Vbe
So let's look at VR22,
VR22 = I_22 X R22
; I_22 = I_23 ; they are in series
So, I_22 = Vbe/R23
VR22 = (Vbe/R23)R22
Final Equation:
Vce = (Vbe/R23)R22  +  Vbe
Taking Vbe = 0.6
Vce = (0.6/1.2)2.7  +  0.6
      = 1.95 volts
« Reply #22 on: August 28, 2011, 02:46:19 PM »
^good  analysis, +1 point for you......sana kanina mo pa inilabas yan.....nagdrama ka pa......
mine is a shortcut computation......remember that these are just computations....the real life voltage could be somewhere in between....
Offline pEN DoTA
« Reply #23 on: August 28, 2011, 03:07:31 PM »
Q: why is there a need to add emitter degeneration resistors?
A: because those resistors do not change in value with current and temperature unlike the transconductance which varies all over the place.....
Q: why do we want transconductance to be stable? what is the benefit?
A: reduced distortion and wider bandwidth...
+1 ka master. dagdag kaalaman na naman. :)
GOD LOVES YOU
Offline pEN DoTA
« Reply #24 on: August 28, 2011, 03:09:38 PM »
Vce = VR22 + VR23
; VR23 = Vbe
VR22 = I_22 X R22
So, I_22 = Vbe/R23
VR22 = (Vbe/R23)R22
Final Equation:
Taking Vbe = 0.6
      = 1.95 volts
+1 ka din sir. :)
GOD LOVES YOU
« Reply #25 on: August 28, 2011, 04:02:40 PM »
continuing with the analysis of the output stage:
at 80watts into 8ohm power level, peak current = 35/8 = 4.375 amps...
base of output trannie therefore requires Ib = 4.375/35 (lowest hfe rating is takes into consideration) = 125mA, this is the peak current required from our driver....
« Reply #26 on: August 28, 2011, 04:09:54 PM »
the driver stage:
using the 2SC2073 driver it has a minimum hfe of 40, therefore drive current to its base needs to be = 125/40 = 3.125 mA.....
using a 2SC4837 which has an hfe of 100, drive current decreases further to 0.125mA....
Q: what is the significance of all this?
A: having devices of higher gains reduces loading on the previous stage, so that that stage if more free to do its thing, that is to swing voltage....
« Reply #27 on: August 28, 2011, 05:27:56 PM »
Vce = VR22 + VR23
; VR23 = Vbe
VR22 = I_22 X R22
So, I_22 = Vbe/R23
VR22 = (Vbe/R23)R22
Final Equation:
Taking Vbe = 0.6
      = 1.95 volts
if you want to be anal about it, there is a small flaw in your analysis:
; I_22 = I_23 ; they are in series,
to be more accurate about it:
I_22 = I_23 + Ib (base current)
so in reality, I_23 is always smaller than I_22,
so we assume that Ib is <<< I_23 so that it is ignored....in order that your argument to be true....
for trannies with hfe >>10 this is very true...
  • Pogi/Ganda Points: 412
« Reply #28 on: August 28, 2011, 05:43:07 PM »
Vce = VR22 + VR23
; VR23 = Vbe
VR22 = I_22 X R22
So, I_22 = Vbe/R23
VR22 = (Vbe/R23)R22
Final Equation:
Taking Vbe = 0.6
      = 1.95 volts
Ilabas na kasi ang computation at ng matuto kaagad kami at marefresh ang iba pa naming basic. I too rely on computation kasi nakakapagbigay ng shorcut at basis.  Plus 1 sir hengil at tony.
Basa mode uli.  :D
Sana idissect pa ng masyado.
« Reply #29 on: August 28, 2011, 05:47:26 PM »
And +1 to sis johannah for bringing this up. Marami sana kaming matutunan.
Offline Skyjham
  • Pogi/Ganda Points: 138
« Reply #30 on: August 31, 2011, 10:33:22 PM »
good day po sa lahat!
  ask ko lang po kung pano mag share ng photo dito,not allowed kasi to post link
thanks po
Learning is un-ending process
Offline Woots29
  • Pogi/Ganda Points: 344
  • asan si mojacko?
    • Woots Page
« Reply #31 on: August 31, 2011, 10:37:06 PM »
post mo lang link without http then kami na bahala dun
WootsPC2 Videos  Woots Page
Offline Skyjham
« Reply #32 on: August 31, 2011, 11:58:32 PM »
ok po try ko thanks ng marami
Offline Skyjham
« Reply #33 on: August 31, 2011, 11:59:50 PM »
modefied av-502
[IMG//i256.photobucket.com/albums/hh180/Skyjham/konzertAV-502.gif[/IMG]
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #34 on: September 01, 2011, 12:18:56 AM »
  • Make it simple
« Reply #35 on: September 01, 2011, 06:23:42 AM »
modification na ba to for higher power?
  • Make it simple
« Reply #36 on: September 01, 2011, 06:28:10 AM »
thanks po
Tanong ko lang sir, ilang volts na ba gamit sa mod?
« Reply #37 on: September 01, 2011, 06:53:37 AM »
rail voltages are the same so no.......
Offline Skyjham
« Reply #38 on: September 01, 2011, 07:13:45 AM »
[IMG//i256.photobucket.com/albums/hh180/Skyjham/konzertAV-502modefied.jpg[/IMG]
Offline Skyjham
« Reply #39 on: September 01, 2011, 07:22:32 AM »
ito naman po ung pang modefy sa amp ng mga component kung sakaling sira ung mamahaling IC amp,
av-735 po yan upto 60 vdc po VCC
[IMG//i256.photobucket.com/albums/hh180/Skyjham/IMG_7873.jpg[/IMG]
