Author Topic: Sakura Amp Modification  (Read 8036 times)
Offline eesbiboi
  • Pogi/Ganda Points: 6
  • ...chegehng discoh...
Re: Sakura Amp Modification
« Reply #180 on: September 08, 2011, 10:50:43 AM »
^what if sir tony i'd use the amp for PA???...
ano kaibahan nun higher VAS supply than output, kesah same or single rail supply???...
ees
  • Pogi/Ganda Points: 522
« Reply #181 on: September 08, 2011, 10:55:59 AM »
the output stage will saturate of clip ahead of the VAS....if you are not letting your amp clip then this is unimportant....
Offline eesbiboi
« Reply #182 on: September 08, 2011, 11:00:05 AM »
^ahhh i see na sir tony why its not really that important with PA's...
ano nmn sir tony effect if vas is higher than the output when it comes to power/audio???...
sir tony, pwede ko po ba eplace yung diode say 1n4007 in place of the 10R resistor???...
regards
ees...
« Reply #183 on: September 08, 2011, 12:34:00 PM »
regards
ees...
for audio.....i see that technique used in a lot of japanese amps....if it were me i'd regulate the front-end instead...
in some mosfet power amps, VAS has higher rails due the Vgth of the output mosfets used.....
skyjam used that diode in his amp, you can also ask him....
Offline nick...j
« Reply #184 on: September 16, 2011, 10:31:22 PM »
my n22han ako ah thankz e lab at sa mga master..
Offline mund24
  • Pogi/Ganda Points: 37
  • Certified Boy'z
« Reply #185 on: April 14, 2012, 01:15:24 AM »
buhayin ang thread dami matutunan :)
Offline kaiky14
  • Pogi/Ganda Points: 27
« Reply #186 on: May 05, 2012, 07:17:36 AM »
ganda magbasa basa dito. hehe
Offline jeproks69
  • hello to all elabers!
« Reply #187 on: June 16, 2012, 01:37:39 PM »
Mga sakura masters paano i modify, ito kasing volume control konting pihit lang malakas agad ang volume wala pa sa 1/4 ang lakas na ng sound output. paano ba operahan ito? saan circuit puwede baguhin.
« Reply #188 on: June 16, 2012, 01:39:42 PM »
^ modify ung feedback resistor sa ampli (sa akin lang)
or sa OP-AMP
Offline jeproks69
« Reply #189 on: June 16, 2012, 01:48:00 PM »
thanks master ryu plus 1. feedback value ng sakura av5023, 39k at 1 k. so ano kayang puwedeng match na value?
sa op amp sa may preamp titingnan ko muna ang value.ty^
« Reply #190 on: June 16, 2012, 01:50:34 PM »
pde mo paglaruin yan , mga 22k at 1k will give about  a gain of 22.
sa opamp ganun din.
Offline jeproks69
« Reply #191 on: June 16, 2012, 01:59:21 PM »
ok pre ;)
  • Pogi/Ganda Points: 136
« Reply #192 on: June 16, 2012, 02:25:58 PM »
Baka nman anliit ng value ng volume control mo, palitan mo ng mataas, 100k.
Lagyan mo ng resistor divider sa input, baka malakas na kasi source mo. 10k to input then 10k to ground.
Offline jeproks69
« Reply #193 on: June 16, 2012, 02:37:16 PM »
wala pa sa 1/4 volume lakas na ng sound output. itry ko rin yung suggestions niyo.thanks plus 1.
Offline Wolfdale
« Reply #194 on: June 16, 2012, 06:00:03 PM »
interested kasi ako gumawa nito!
meron po ba pcb layout with their parts?
pengi poh!
« Reply #195 on: June 16, 2012, 07:23:21 PM »
gumamit ka ng Audio taper or logarithmic na volume control....kung wala ngang mahanap pwede ito...http://geofex.com/Article_Folders/potsecrets/potscret.htm
http://www.jt30.com/jt30page/potfix/
  • Pogi/Ganda Points: 98
« Reply #196 on: June 16, 2012, 09:06:53 PM »
pa abang sa thread na2 :D
Offline gancua68
  • Pogi/Ganda Points: 11
« Reply #197 on: July 18, 2012, 09:45:29 AM »
ako  din. basa basa lng muna ako.
http://www.elab.ph/forum/Smileys/default/smiley.gif
