Author Topic: Looking for 200W to 300W AT psu  (Read 516 times)
Offline lapigut!
  • Pogi/Ganda Points: 49
« on: September 03, 2011, 10:31:24 AM »
Looking for 200W to 300W AT psu...please you have one im interested to buy...urgent lang po...
kutsarain ang mainit na sabaw
Offline acer
  • Pogi/Ganda Points: 109
Re: Looking for 200W to 300W AT psu
« Reply #1 on: September 03, 2011, 10:37:04 AM »
saan nyu po gagamitin
nevergive up
Offline makuy
  • Pogi/Ganda Points: 11
« Reply #2 on: September 03, 2011, 10:55:34 AM »
sir saan po location nyo? madami po sa raon sa sidewalk naka kariton.
sa openpinoy.com meron din
http://openpinoy.com/shop/step1.php?number=2292&scode_mode=&sc_code=C20080719031842&sm_cdoe=
ay teka sir AT lang po ba hanap nyo?
Offline lapigut!
« Reply #3 on: September 03, 2011, 07:27:50 PM »
para kasi sa DC air compressor ko na 12V 10amp...maxado nang mahal ung transformer nya
Offline lapigut!
« Reply #4 on: September 03, 2011, 07:33:11 PM »
taga naga po ako..di ko maopen ung site nila...bakit kaya...haiz...
  • Pogi/Ganda Points: 521
« Reply #5 on: September 03, 2011, 07:51:30 PM »
it is easy to convert an ATX psu to an AT psu......kung 12 volts lang ang hanap mo....
Offline lapigut!
« Reply #6 on: September 03, 2011, 08:10:14 PM »
pano po sis??ung 12V kasi nagsshutdown skn sa atx...tapos wala man available dito ng 120W 1ohm resistor for my dc air compressor
Offline acer
« Reply #7 on: September 03, 2011, 11:23:11 PM »
kala ko kasi sa old model cpu 386 gagamitin,   bakit mas mababa wattage hinhanap mo, diba mas mataas mas maganda  baka mataas ampere ng air compressor kaya shutdown ang ATX
nevergive up
Offline lapigut!
« Reply #8 on: September 04, 2011, 12:29:06 AM »
10amp nga po...350W atx kasi ngsshudown...tpos ung 200W at psu gumana xa...pero naglokonga lang...
« Reply #9 on: September 04, 2011, 07:34:14 AM »
^overload, or you need to load the 5v rails also, you can put at 4.7ohm/10watt resistor to load that rail....
get a psu rated for 500 watts and do not get a generic atx......di kakayanin ang 10amp load, never mind what it says on the label...
to use the atx psu, install an on off switch using pin 14 wire(usually color green) and any black wire.....the psu will stay on as long as the switch is in on posistion....
Offline lapigut!
« Reply #10 on: September 04, 2011, 09:06:25 PM »
500W is too much for me...puputok na ung hose ko sa tank if i surpass 140psi... also i tried using 10ohm 10Watt resistor on the 5V rail, super init lang xa with the air compressor attached to the 12V...pero under 330W un...
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #11 on: September 04, 2011, 10:30:43 PM »
kulang ka sa safety... dapat may pressure switch ka to switch off power to your air compressor.
Offline lapigut!
« Reply #12 on: September 04, 2011, 10:40:32 PM »
mahal pa kasi sis huntering...nakahanap ako ulet ng at 200W..siguro lalagyan ko nlng ng mano mano remote turn-on for 12secs ung air compressor...12secs upto 80-90psi na un...tpos nakukuha ko is 5-10psi psi per switch sa cylinder
Offline makuy
« Reply #13 on: September 05, 2011, 12:32:49 PM »
ang layo mo pala sir, btw kala ko sir sa lumang pc mo gagamitin.
ang alam ko lang sa naga Save On Surplus. dyn ako nkabili dati :D
