Author Topic: Analog to Digital Converter  (Read 1177 times)
Offline daveee143
« on: September 04, 2011, 10:12:58 PM »
Mga Sir/mam pahelp nmn po sa idea ADC
kc pinapa complete po saamin ng prof nmn eh. kaso po maxado na po kaming busy sa thesis eh kaya wala na po time para makapag research regarding to this topic
Kc po pinapagawa po kami ng prof nmn ng ADC EH
ang gus2 noya po ay
from voice to digital display
For example po
kapag sinabi mu po na "HELLO" lalabas po sa screen yung word na hello
pero po pwede pa po siya maiba. pwede po pa2long pa suggest po salamt
Offline daveee143
Re: Analog to Digital Converter
« Reply #1 on: September 06, 2011, 09:42:23 PM »
pa help nmn po
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #2 on: September 07, 2011, 06:33:59 AM »
Speech to text? You have mentioned ADC so gagamit kayo ng uC or uP sir? I think madugo ito, mas lalo pang maging busy kayo nito. Salbahe naman yang prof ninyo. ;D
Offline ahlburuto
  • E&I tech.
« Reply #3 on: September 07, 2011, 07:01:03 AM »
ang gus2 noya po ay
For example po
Iwasan po natin ang text typing.
Anyway, medyo madugo ito. Wait mu ang ibang mga masters...
BR
Offline akhen
  • Pogi/Ganda Points: 47
« Reply #4 on: September 07, 2011, 07:55:34 AM »
madugo nga ito... ang dapat sa mga ganyang prof sila ang pinapadugo... ;D
« Reply #5 on: September 07, 2011, 08:06:03 AM »
^ parang ikaw. hihihi
Offline dummy_c
« Reply #6 on: September 07, 2011, 08:08:18 AM »
OT:
Sa tingin ko para ito sa masteral ni prof.. ;D
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
« Reply #7 on: September 07, 2011, 09:06:55 AM »
OT:
Tumpak! ;D ;D ;D
« Reply #8 on: September 07, 2011, 09:41:01 AM »
kahit nga 'yung Google Voice Search hindi perfect 'yung conversion. ;D
hindi ko pa 'to personally nagagawa, pero ang karaniwang ginagamit sa speech recognition is Hidden Markov Model.
Google - hidden markov model speech recognition
Offline dummy_c
« Reply #9 on: September 07, 2011, 10:46:57 AM »
May nabasa ako na post ni sir alyas dito sa ELAB about using windows 7 para sa voice
recognition. Mayroon na kasi built-in voice recognition ang windows 7. Ni try ko interface yon sa
VB6. Again and again the problem is ambient noise. Kailangan ng quite environment kasi lagi
syang nag convert as long as narinig siya ng sound or noise. So instead of one word yung intended na input
ko naging  sentence tuloy. ;D
Pero as long as buo yung word na narinig ng Mic, almost 99% siya accurate mag convert.
Nag enjoy ako using it, I could open any folder, run a program, write to textpad, etc... It can
even be used to click anywhere in the screen. ;D
Mas ok sana if may signal conditioning circuit after sa mic.
Offline daveee143
« Reply #10 on: September 07, 2011, 10:54:53 AM »
ew T_T eh panu ko clap recognition po? yung tipong
pag pumlakpak ka ng isa bubukaw ilaw tapos pag dalawa mamatay?
Offline dummy_c
« Reply #11 on: September 07, 2011, 11:47:37 AM »
Meron na niyan sa electronic enthusiast.
I thought text-to-speech yan. ;D
Offline daveee143
« Reply #12 on: September 07, 2011, 02:01:29 PM »
nakiusap po kami sa ibang prof kung anu pwedeng gawin tapos po eto sabi ng isa naming prof
"Pwede kung voice command activation...for example, "ON" and "OFF"..kasi kung palapak eh akseidenteng nagpalakpakan boung klase eh di nalito ang circuit nyo... tapos mamatay yung ilaw nyo..
pwede po b 2? sa tingin nyo? tapos po may nakagawa na po ba nito d2? salamt po sa mga nag reply
Offline dummy_c
« Reply #13 on: September 07, 2011, 02:19:25 PM »
Para sa akin pwede yan sir. Windows 7 + VB6 + serial port +xtor + relays + tyaga. Pwede din palitan ng USB-to-Serial cable yang serial port, mas simple pa.
Offline PlCUSER
  • Pogi/Ganda Points: 153
« Reply #14 on: September 07, 2011, 03:53:14 PM »
TS,
or if allowed ka sa setup ni dummy_c, you can also use a windows phone or an android phone to do the voice recognition. then pass the command from phone bluetooth to an mcu with bluetooth, to trigger you light bulb.
Offline ΔЅịMø
  • "Live Curious"
« Reply #15 on: September 07, 2011, 06:51:37 PM »
^^The concept is still voice recognition.
Offline daveee143
« Reply #16 on: September 08, 2011, 09:53:11 PM »
Ui sir Asimo :D hehehe
TS,
Panu po yung sa mcu setup? pic16f877a po gamit eh?  tapos po meron po kame window phone kaso 7? pwede b yun? salamt po sa idea sir.
Offline bravokilo
  • Pogi/Ganda Points: 105
« Reply #17 on: October 10, 2011, 05:29:28 PM »
Hinde analog to digital ang subject nito kundi VOICE RECOGNITION.
     The principle really is to first record the pattern in a computer and once the sound is inputted again, the library is scanned for matching. Isang limitation is that it has to be the same person dahil intonation, diction, clarity will play into the recognition match. for example, today, in business, the Time In/Time Out the thumbmark. Well, a new employee first have to registehis/her thumbmark into the computer to be part of the library. Eveytime a thumb is inputted, the lib is scanned to match.
     In Powerpoint, the printed lecture can be made voice via speech "avatars". This is of course the reverse. There are programs to do it.
     Your project is complex and expensive to do.
BK
