Author Topic: need help toshiba laptop a200 naghahang pag nakasaksak ung charger  (Read 1290 times)
Offline niknok777
« on: September 05, 2011, 08:57:05 PM »
scenario: halos ayaw mag charge nung battery..in battery mode, ok.. d cya naghahang pag saksak charger hang na po at minsan blank screen..mobo daw po problema.
Offline rhidalgo
  • Pogi/Ganda Points: 5
Re: need help toshiba laptop a200 naghahang pag nakasaksak ung charger
« Reply #1 on: September 30, 2011, 12:14:54 PM »
sis try mo gumamit ng ibang charger. kung ganun pa rin. try mo disconnect battery tapos saksak mo charger. on mo laptop without battery. pag d sya nag hang battery ang problem....
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #2 on: September 30, 2011, 12:24:58 PM »
subs..
Offline Rhodzkie73
« Reply #3 on: October 12, 2011, 01:19:40 PM »
There is problem on toshiba laptop mobo.   Your mobo needs repair. I have encountered 2pcs toshiba laptop and Sent it to laptop tech
Offline explorer1007
  • Pogi/Ganda Points: 29
« Reply #4 on: October 12, 2011, 02:15:51 PM »
may nakapagsabi sa akin dati problem nga yan ng toshiba. meron silang tinatangal na 8pins na diode ic, kung technician ka pwede mo nmn subukan. tanggal ka muna then testing, mga 4 pieces ata yong ic na yon.
Offline comtronixs
  • Pogi/Ganda Points: 53
« Reply #5 on: October 12, 2011, 03:54:10 PM »
sis baklasin mo yung laptop palitan mo yung nec tokin chips niya sa likod ng processor..
Offline song
  • Pogi/Ganda Points: 34
  • tyaga + elab, makukuha mo din yan!!!
« Reply #6 on: October 12, 2011, 10:12:16 PM »
sis mahirap yata maghanap ng same spareparts ng nec/tokin. ano ba pwede replacement?
"It takes a month to find a customer, seconds to loose one."
Song's TV Shop
Offline /
  • Pogi/Ganda Points: 317
« Reply #7 on: October 12, 2011, 10:16:58 PM »
patambay..
Offline comtronixs
« Reply #8 on: October 14, 2011, 01:37:24 PM »
4 pcs tantalum capacitors 2.5 330uf farad  smd type
Offline comtronixs
Offline comtronixs
Offline /
« Reply #11 on: October 14, 2011, 02:59:53 PM »
ilalabas ko lang sis.
Offline comtronixs
« Reply #12 on: October 14, 2011, 03:01:22 PM »
sundin lang ang polarity sa pagbabalik
Offline comtronixs
« Reply #14 on: October 14, 2011, 03:09:32 PM »
Offline comtronixs
« Reply #15 on: October 14, 2011, 03:10:29 PM »
  • Pogi/Ganda Points: 433
« Reply #16 on: October 14, 2011, 07:30:04 PM »
Ano yan? Diode?
Offline BANNEDMemberAccount
  • Pogi/Ganda Points: 130
« Reply #17 on: October 14, 2011, 07:39:06 PM »
tantalum capacitors 2.5 330uf farad  smd  raw, waiting for result
Offline song
Song's TV Shop
Offline BUMBLEBEE
« Reply #19 on: October 14, 2011, 11:01:38 PM »
abangan ko eto ulit,, nice one @comtronixs :-*
