Author Topic: anong difference ng PIC na may suffix na "A" sa part# sa walang "A"  (Read 1932 times)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
ano ba ang pinagkaiba nila? ???
like 16F84 vs. 16F84A, 16F877 vs. 16F877A, 16F628 vs. 16F628A, etc..
Offline 1110000
  • Pogi/Ganda Points: 28
Re: anong difference ng PIC na may suffix na "A" sa part# sa walang "A"
« Reply #1 on: June 08, 2008, 08:52:15 PM »
sa aking kaalaman na idinagdag ni William Richardson ang designer at owner ng blueroomelectronics mas accurate daw ang built in clock nya at mas mura din ::)
E153C51513
Offline paranz
  • Pogi/Ganda Points: 177
  • 1/4W resistor specialist
    • RapidSignal Electronics
« Reply #2 on: June 08, 2008, 11:18:47 PM »
best thing to do is check the datasheets, i guess  :)
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #3 on: June 08, 2008, 11:23:09 PM »
wala namang built-in clock yung F84(A), F877(A), F628(A), etc..  ???
« Reply #4 on: June 08, 2008, 11:30:26 PM »
medyo mahirap din masagot ang tanong mo pareng yus, talagang datasheet ang makakasagot nyan ;D
Offline 1110000
« Reply #5 on: June 08, 2008, 11:31:18 PM »
F628 walang built in clock? ???
E153C51513
Offline paranz
« Reply #6 on: June 08, 2008, 11:35:09 PM »
meron. 4Mhz
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #7 on: June 08, 2008, 11:35:58 PM »
meron pala..  :D
hindi pala sila "in general" ? ???
Offline 1110000
« Reply #8 on: June 08, 2008, 11:38:57 PM »
yup iba iba ang meaning ::)
E153C51513
Offline 40800414
« Reply #9 on: June 10, 2008, 01:09:53 PM »
The part with the suffix "A" is a new CMOS version, and is easy to manufacture resulting in a cheaper price and are also more enhance than the part without the "A" suffix. For example the PIC16f84 can function up to 10MHZ whilst the "A" version up to 20MHz. You can also consult some migration documents.
There are 10 kinds of people in the World...Those who understand binary, and those who dont!
Offline 'yus
  • hw -> fw -> sw
    • yus' projects
« Reply #10 on: June 10, 2008, 02:14:50 PM »
mas lamang (improved version) pala yung may "A" suffix..
Offline kmb36td
  • Pogi/Ganda Points: 5
« Reply #11 on: February 08, 2012, 08:15:32 PM »
cheaper pala tapos ibenta ng masmahal.... boinx...
  • Pogi/Ganda Points: 53
« Reply #12 on: February 08, 2012, 08:22:31 PM »
;D ;D ;D
