Author Topic: 60 Watts Amplifier  (Read 1212 times)
Offline elmertronics
  • Pogi/Ganda Points: 6
  • expect the unexpected
Re: 60 Watts Amplifier
« Reply #20 on: September 09, 2011, 03:09:07 PM »
totoo ba yan 18v 500mA  :o
iyan lang kasi ang supply ko dito
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #21 on: September 09, 2011, 03:16:00 PM »
sinubukan ko lang kanina sa 18V 500mA na supply. .tapos 4ohms na 275W ang max power. .ok ang output nya kaso pag full ko na ang pot medyo basag na. .
Tama pala yung circuit mo, common-emitter nga yung C945, gain nya ay galing sa 100k(feedback).
  • Pogi/Ganda Points: 520
« Reply #22 on: September 09, 2011, 03:20:04 PM »
hindi 60 watts, baka 6 watts lang..
« Reply #23 on: September 09, 2011, 03:21:12 PM »
masyadong transistor dependent yung circuit mo.....dapat aregluhin para mapatunog ng maayos...
  • Make it simple
« Reply #24 on: September 09, 2011, 03:57:50 PM »
Dapat yung feedback tlaga nito galing sa output tranny o kaya gawin na lang Class A yung output.
« Reply #25 on: September 09, 2011, 03:58:54 PM »
hindi naman siya 6 watts. .malakas naman po ang tunog niya. .
« Reply #26 on: September 09, 2011, 04:11:01 PM »
paano po sir tony?. .
  • Pogi/Ganda Points: 909
« Reply #27 on: September 09, 2011, 05:07:41 PM »
pa subs
« Reply #28 on: September 09, 2011, 11:04:18 PM »
kumbinsihin mo ko na hindi 6watts yung amp mo.....18volts at 0.5amps ilang watts yan?
« Reply #29 on: September 10, 2011, 12:22:07 AM »
ay. .yan lang kasi ang available ko na supply sir tony. .try ko lang sa mataas na supply. .
Offline jiggins20
  • Pogi/Ganda Points: 15
« Reply #30 on: September 10, 2011, 11:00:06 AM »
working po ba talaga ang circuit nito sir?
Audio amp addict
« Reply #31 on: September 10, 2011, 06:22:56 PM »
working po yan. .
« Reply #32 on: September 10, 2011, 06:48:33 PM »
ala tsamba ang circuit na to....
« Reply #33 on: September 10, 2011, 07:40:49 PM »
haha di ko nga alam sir kung saan to kinuha ng nagconduct ng workshop namin. .
« Reply #34 on: September 11, 2011, 03:31:55 PM »
^this is not the right way to learn circuits....
Offline TinTopHack
  • Pogi/Ganda Points: 154
« Reply #35 on: September 12, 2011, 12:35:23 PM »
mga master ito po pala ang circuit. .nagkamali lang ako sa paggawa ng diagram. . ;D
This amp is designed to drive audio alarms. Not for listening pleasure. Most probable source of audio signal is a 555 circuit oscillator or variations of that to produce a distinct alarm sound.
A simple way of looking at it is -
Q3 is a collector biased common emitter stage. Its collector voltage at zero input signal sets the operating point. The voltage therefore at the emitter of Q1 and Q2 is just one Vbe higher than Q3's collector voltage.   We cannot expect the voltage at the the emitter of Q1 and Q2 to be exactly 1/2 the supply rail. It will be +/- 1 Volt (or more) around that figure because the collector voltage of Q3 will depend primarily on the temperature and Q3's hfe. For this circuit, Q1 and Q2 remains off when there is no input signal due to the single diode D1. So the biasing of Q3 and the load formed by D1 and R2 determines the collector voltage of Q3. This simplicity in this setup also allows it to operate over a wide range of supply rail voltage. Typically the supply will be 24V in industrial applications.
Q1 is a follower for the upper half of the signal while Q2 is a follower for the lower half.
Q1 and Q2 operate in class B mode due to the single diode D1 that prevents them from conducting at the same time.
Offline j a y k e z
  • gimmegaggigsss
« Reply #36 on: September 12, 2011, 12:41:48 PM »
nice explanation sir TTH pogi point for you  :)
parang may nabasa akong ganito sa EE book.
