Author Topic: Poor Man's DIY PCB Exposure Box  (Read 2395 times)
Offline e-tronix
Re: Poor Man's DIY PCB Exposure Box
« Reply #40 on: September 20, 2011, 10:30:48 PM »
http://imageshack.us/g/40/dsc00724s.jpg/
sis KAS ito yung exposure box ko, dpa totaly tapos to. pero nagamit ko na for single sided lang muna.  2mins exposure time lang sis using tracing paper. 1min using transparency.
  • Pogi/Ganda Points: 412
« Reply #41 on: September 20, 2011, 10:43:24 PM »
anung tube gamit mo dito bai??
Offline e-tronix
« Reply #42 on: September 20, 2011, 10:52:43 PM »
20w electronic ballast fluorescent yan sis. one set na bili ko niyan 290petot.
« Reply #43 on: September 21, 2011, 12:30:14 AM »
di naman sobrang malapit?
Offline duc_tech
  • Pogi/Ganda Points: 32
« Reply #44 on: September 21, 2011, 08:48:16 AM »
san ba area niyo sis
Surallah, south cotabato ako sis...Koronadal at Gensan pinakamalapit samin..
  • Pogi/Ganda Points: 53
« Reply #45 on: September 21, 2011, 10:52:26 AM »
black light ba yan sis? magkano po iyan?
Online insomartin
« Reply #46 on: September 21, 2011, 02:36:01 PM »
^ warm white yan. warm white.
TAKBO MARTIN, TAKBO!
« Reply #47 on: September 21, 2011, 03:27:35 PM »
Meron ako nakita dito sa Ace na BL para sa mga lamok..di ko alam if BL stand for Blacklight? at blacklight = uv?
Offline zrehtiek/keitherz
  • Pogi/Ganda Points: 45
  • PhilRoboKit Anito
« Reply #48 on: September 21, 2011, 03:37:53 PM »
lamok magnet = uv
blacklight = uv
« Reply #49 on: September 21, 2011, 03:43:54 PM »
then BL = PCB exposure lamp??
Offline dark_comet
« Reply #50 on: September 21, 2011, 03:48:38 PM »
A black light, also referred to as a UV light (Ultra Violet Light), is a lamp that emits ultraviolet radiation almost exclusively in the soft near ultraviolet range. Only a very small fraction of visible radiation passes through the filtering material, with wavelengths no longer than 400-410 nm, and as a result, the human eye detects its color as deep blue and violet. Wood's glass is an example of filtering material which is transparent to ultraviolet wavelengths between 320 and 400 nm.
-source wikipedia
« Reply #51 on: September 21, 2011, 03:58:05 PM »
too good to be true....;D
69 petot lang kasi ang isang 15 watts na tube....bili ako 3 pcs at 3 rin na fixture...
Offline marsianpipz
  • Pogi/Ganda Points: 10
  • life is so amazing :D
« Reply #52 on: September 21, 2011, 03:59:43 PM »
sis kasamiko pa check nang pm ko sayo :D
"   Life doesn't get easier, you just get stronger.              "
« Reply #53 on: September 21, 2011, 04:17:32 PM »
ganito din ang dati ko ng gamit... black lamp from handyman.
pero nung nagkatime at ginanahan na din akong gawin yung exposure box ko (made from an old scanner), di na ako gumagamit ng ganito.
« Reply #54 on: September 21, 2011, 04:21:06 PM »
Patingnin nga po sis! ng scanner na mod.. :) gusto ko din modify yung old printer namin sira na din
  • Pogi/Ganda Points: 631
« Reply #55 on: September 21, 2011, 05:15:37 PM »
gamit namin sa opisina. madalas double sided ang ginagawa namin kaya top and bottom. 1/2" thick 'yung gingamit naming glass.
Offline nucleus
« Reply #56 on: October 02, 2011, 11:16:30 AM »
yung kulay itim ba? baka tamang presyo lang yan, dito kasi samin yung 10W na uv bulb 150 isa, puro overpriced naman tinda dito ;D ;D ;D
« Reply #57 on: October 02, 2011, 11:23:35 AM »
bluish white...na halos di mo makita....nag alala ako kasi di naman ganun ka liwanag without considering na invi pala yung UV light...;D
Offline iQ50
« Reply #58 on: February 25, 2012, 10:27:05 AM »
yung BL bulb e diba eto din yung nasa mga Counterfeit Money Detector?
Offline e-tronix
« Reply #59 on: February 25, 2012, 10:53:46 AM »
uu
