Author Topic: Generic ATX Power Supply  (Read 2890 times)
  • Pogi/Ganda Points: 520
Re: Generic ATX Power Supply
« Reply #20 on: September 14, 2011, 05:39:24 PM »
Palagay ko sira
Magkaiba ba ang ckt ng standby sa main sir? o pareho lang sila ng start-up resistor?
I'm talking about the resistor in the range of 1Meg.
we are talking atx psu's, tv's and monitors uses start-up resistor which is not involved here....
« Reply #21 on: September 14, 2011, 05:50:18 PM »
these are rects you should check:
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #22 on: September 14, 2011, 06:37:08 PM »
mapapansin mo pati yung plastic spacer ng turnilyo ng mga rectifier minsan lusaw ng konti at nangingitim ang metal tab ng rectifier.
Offline BhongTech
« Reply #23 on: September 14, 2011, 07:16:31 PM »
pag-shorted na.
Offline ars
  • Pogi/Ganda Points: 7
  • No man is an island
« Reply #24 on: September 15, 2011, 09:39:55 AM »
master tony...ito po ung nasa output area na nka top sa heatsink, tama po ba? ung sa primary ay hv switch din to dba?
Offline pabzjose
« Reply #25 on: September 15, 2011, 09:53:33 AM »
pwede po ba gamitin yung 4 pin ng ATX as an adpater ng smartbro wifi router?
« Reply #26 on: September 15, 2011, 03:45:23 PM »
yup yung lower heatsink sa  picture, you have to take it out of board to test, you may also test the small diodes for the negative 12 and 5 rails if installed....
« Reply #27 on: September 15, 2011, 04:01:06 PM »
meron ding cases na walang signs of burning pero shorted pa rin, best to take the heatsink off board and test individual rectifiers.....kasi in circuit you might think that it is shorted, hindi naman pala..
Offline ars
« Reply #28 on: September 16, 2011, 10:36:58 AM »
ok tnx sa idea
Offline profpat
  • Pogi/Ganda Points: 9
  • "pag gawa ng tao! kaya natin ayusin"
    • LCD REPAIR PHILIPPINES
« Reply #29 on: October 10, 2011, 09:48:23 AM »
madalas ntc resistor ang culprit - tama si sis tony, sometimes nag change value yung over voltage/current resistor shunt, also check very well all switching diodes, a little leak will make the circuit go on protection mode..if this unit is equiped with 393 i.c. palitan mo na rin..
Offline /
  • Pogi/Ganda Points: 317
« Reply #30 on: October 17, 2011, 05:34:18 PM »
master anung piyesa yong SCK 055 ang label. may crack na kasi eh, yong kaya ang cause kaya pumuputok ang fuse?
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #31 on: October 17, 2011, 06:30:51 PM »
pa sub....
Offline ditchie
  • Pogi/Ganda Points: 100
  • wish ....wish...
« Reply #32 on: October 17, 2011, 06:49:22 PM »
nakaparallel ba yan sa AC sis?
--Mahatma Gandhi
Offline /
« Reply #33 on: October 17, 2011, 07:01:27 PM »
uu sis malapit sa fuse
Offline Mayalin22
  • Pogi/Ganda Points: 400
« Reply #34 on: October 17, 2011, 07:05:45 PM »
varistor cguro yan sis.. alisin mo pansamantala then check kung puputok pa fuse
Offline ditchie
  • wish ....wish...
« Reply #35 on: October 17, 2011, 07:07:44 PM »
ah forgot the name of that part. ginagamit yan to protect the unit. once tumaas voltage mag turn.on yan causing short circuit at puputok yung fuse. meron siyang certain voltage rating kung saan magconduct. kadalasan ko yan nakita sa samsung boards at mga unit na palagi nakastandby. pwede naman tanggalin muna pero make sure stable supply mo.
--Mahatma Gandhi
Offline ditchie
  • wish ....wish...
« Reply #36 on: October 17, 2011, 07:09:47 PM »
yun na sis. varistor. metal oxide varistor MOV.
thanks kuya google.
--Mahatma Gandhi
Offline /
« Reply #37 on: October 17, 2011, 07:10:43 PM »
^uu nga sis kasi naisaksak sa 220 na naka 110 ang selector.
ahhh sige sis maya pag balik ko sa opis pag tripan ko ulit. basag na kasi eh.
+1 kau sis
Offline Mayalin22
« Reply #38 on: October 17, 2011, 07:12:05 PM »
gamit ka ng gasmask  ;D ;D ;D ;D
Offline /
« Reply #39 on: October 17, 2011, 07:13:54 PM »
bakit sis ecap na ang sasabog? :D :D :D
