Author Topic: BENQ monitor  (Read 1010 times)
Offline vic24lordsf
  • Pogi/Ganda Points: 12
BENQ monitor
« on: September 15, 2011, 01:26:33 PM »
mga master sino pa nakaranas ng ganito problem tungkol sa BENQ monitor mag shutdown po siya tapos on na naman tapos shutdown ulit.. ano po problem nya.. sana matulongan niyo ako mga master...thank you
BENQ monitor
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
Re: BENQ monitor
« Reply #1 on: September 15, 2011, 01:27:50 PM »
loss connection
resolder muna sis for the basic..
FBT section,vertical section,sys,psu update ka if natapus kana mag-resolder
Re: BENQ monitor
Offline acer
Re: BENQ monitor
« Reply #2 on: September 15, 2011, 02:26:44 PM »
ano po ito lcd or crt paki clear lang
nevergive up
Re: BENQ monitor
Offline vic24lordsf
Re: BENQ monitor
« Reply #3 on: September 22, 2011, 03:33:43 PM »
LCD Po sir.. mag shut down po siya tapos on ulit.. 17 inches LCD po siya yong FP72E ang model po nya sino po nakararanas ng ganitong problem...
Re: BENQ monitor
Re: BENQ monitor
« Reply #4 on: September 22, 2011, 04:51:02 PM »
kalimitan dito ay mga ecap na bloated paki check mo.
Re: BENQ monitor
Offline Triple_D
  • Pogi/Ganda Points: 164
Re: BENQ monitor
« Reply #5 on: September 22, 2011, 05:47:03 PM »
agree visual check muna mga ecaps baka may leak na jan...
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
Re: BENQ monitor
« Reply #6 on: September 22, 2011, 05:53:17 PM »
agree ako  dito...
Re: BENQ monitor
« Reply #7 on: September 22, 2011, 07:58:00 PM »
tama ecap nga siguro yan
Offline BUMBLEBEE
Re: BENQ monitor
« Reply #8 on: September 22, 2011, 08:04:52 PM »
akala ko nito CRT ;D ;D hula-hula lang kasi ;D ;D
wala na yata update ang TS matagal na eto.. 1 week na update poh TS.
Offline danny
  • Pogi/Ganda Points: 323
Re: BENQ monitor
« Reply #9 on: September 23, 2011, 02:41:10 AM »
 ;D ;D ;D
danny
Offline vic24lordsf
Re: BENQ monitor
« Reply #10 on: October 04, 2011, 03:28:04 PM »
salamat sa mga feedback mga master,, medyo bz kasi kaya ngayon lng ako naka reply tungkol po  sa mga capacitor po ok lahat po.. wala akong nakita nga deformation niya.. check ko din po ang mga burn resistor at ibang pang mga components ok po siya.. bakit kaya.
Re: BENQ monitor
« Reply #11 on: October 04, 2011, 04:06:42 PM »
try u sa psu yung opto isolator :D
Offline x13r_kit_0
  • Pogi/Ganda Points: 150
  • --__x13r_kit_0__--
Re: BENQ monitor
« Reply #12 on: October 04, 2011, 05:17:20 PM »
Try lagyan ng load yung psu.,kung bumagsak,andyan pa problem nyan.
measure din mga output voltage kung kumpleto.. :)
try mo nga silipin kung pareho sa power board nyan.. :)
"Kumain tayo at uminom,Sapagkat bukay ay mamamatay tayo"  CORINTO 15:32
   =How about the other side?=
Offline acer
Re: BENQ monitor
« Reply #13 on: October 04, 2011, 06:25:52 PM »
agree voltage reading muna pag kompleto nama try silipin ang inverter
nevergive up
Offline x13r_kit_0
Re: BENQ monitor
« Reply #14 on: October 04, 2011, 06:32:40 PM »
Kung sure na buo ang power supply.,check high voltage trasnformer..
Yan ang sakit nyan minsan..gudluck!
Offline jiggins20
Re: BENQ monitor
« Reply #15 on: October 04, 2011, 07:04:51 PM »
ganyan din yung sa akin,resolder mo yung inverter section lalo na yung high voltage trafo...
Audio amp addict
Offline vic24lordsf
Re: BENQ monitor
« Reply #16 on: October 05, 2011, 11:23:03 AM »
tapos ko na pong na resolder ang mga part na yan tapos balik ulit sa dati... ang hindi ko pa na check ang mga voltage rating nya..feedback lang ako ulit kong anong resulta.. salamat mga master
Offline vic24lordsf
Re: BENQ monitor
« Reply #17 on: November 15, 2011, 07:16:59 PM »
problem solve for this ben q monitor  pinalitan ko ang mga electrolytic caps niya.. kahit sa tingin ko wala pang budge ang top niya mayroon din palang sira na caps kahit hindi budge ang top nya..
Re: BENQ monitor
« Reply #18 on: November 15, 2011, 07:22:06 PM »
Re: BENQ monitor
   Reply with quoteQuote
yan ang sinasabi namin
kong walang capacitance meter may mas magandang tester dyan ay actual palit ng bago para sure ka pero dapat isa-isa para ma tumbok mo talaga ang sira.
Offline jhobert
Re: BENQ monitor
« Reply #19 on: December 09, 2011, 08:53:52 PM »
hahai!macheck nga yung sakin!ganyan din ang sira e!
20 inches na BEnq monitor
ang gnwa ko naman nilabas ko ang mga switches nia,ang hirap kasing i-on,khit pnalitan ko n ng bagong switch..
tapos ngayun ok na xa.ndi na nama2tay..
Re: BENQ monitor
