Hello to all Wizard,Sorry if in the wrong place of posting this i just need some help of all the expert here..This amp is known as Vertex by apexaudio posted on other forum it was base on C**st A.Ca18/9001 modelPinagsikapan ko magawan ng pcb ang amp na to and nagawa ko din para ma test as Class ab ampBut Sadly it fails..Problems of the Amp i made1.4mje's 15035/15035 heats up even there's no load or signal on amp2.audio is clear but less power like 5 to 10watts only Malakas pa si AVEGON3.I also try to use the set up of C**st and parts value result is the sameI hope Pinoy expert can help Me to make this workI made several amp Class H H900x6(apex),Master 3k6(John Malluto) ,M10/K10 clone Ir2117stepper (Chestap)
Kuya Tony could this be possible of the problem the original driver used is Mje13007/5851 SILICON NPN/PNP SWITCHING TRANSISTORAPPLICATIONS SWITCHING REGULATORS MOTOR Cand the clone vertex is usingMJE15034/35Complementary SiliconPlastic Power TransistorsTO−220, NPN & PNP Devicesdesigned for use as high−frequency drivers in audio amplifiersdrivers used has different characteristics
