Author Topic: samsung monitor/blinking picture  (Read 474 times)
Offline hackerz
  • Pogi/Ganda Points: 5
    • operamini
« on: September 21, 2011, 06:15:09 PM »
mga sis,gud evening ngaun.  My tanggap ako monitor,pag open ,ok naman picture pero blinking sya,ano kaya sira ng blink,lagi .salamat.
god is good all the time
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
Re: samsung monitor/blinking picture
« Reply #1 on: September 21, 2011, 06:17:54 PM »
sis yung FET nya paki-tingin ,, poh.. baka leak na
Offline hackerz
    • operamini
« Reply #2 on: September 22, 2011, 08:18:02 AM »
tnx sis,.try ko,hnd ko pa kc alam kng panu ,gawin ang monitor,update nalang ako ulit.
Offline hackerz
    • operamini
« Reply #3 on: September 22, 2011, 08:39:02 AM »
sis tanung lang,mag kaparihas lang ang IRF740/IRF630/ panu reading eto salamat.
Offline BUMBLEBEE
« Reply #4 on: September 22, 2011, 08:51:16 AM »
ano part number ng orig?
ang ano ang i-replace mo??
saan galing yung ipapalit mo?? mas-maganda sa monitor din
pero bago yan nag-resolder kana-ba??
check muna natin FEWT na yan
kailangan hindi leak yang pin2 and pin3,
pin1 and pin2 ,.. observre mo lang kung mabilis ba uminit
palitan muna ,, goodluck poh..
Offline Triple_D
  • Pogi/Ganda Points: 164
« Reply #5 on: September 22, 2011, 09:01:50 AM »
baka may looscon lang sis..
Offline hackerz
    • operamini
« Reply #6 on: September 22, 2011, 09:04:04 AM »
pin 2 at pin 3 pumapalo sa tester sis,kahit pin3 pin2.
Offline acer
« Reply #7 on: September 22, 2011, 10:13:01 AM »
pareho ba sila ng resistance kung pareho meaning sira na yan
nevergive up
Offline BUMBLEBEE
« Reply #8 on: September 22, 2011, 10:20:28 AM »
;D ;D palitan mo na yan.. para malaman natin ang result... goodluck poh ingat..
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #9 on: September 22, 2011, 10:31:59 AM »
sis yung Irf630 mababa ang drain to source breakdown voltage nsa 200v samantalang ang Irf740 nsa 400v.paki-try i-short ang gate at drain tapos try u uli tester ang drain at source vice versa.dapat isang direction lang may resistance at pagganun good yan.
Offline BUMBLEBEE
« Reply #10 on: September 22, 2011, 10:34:58 AM »
pwede rin.....
Offline BhongTech
« Reply #11 on: September 22, 2011, 10:41:40 AM »
N-ch fet yan.ang tamang pagtest i-set u tester sa X1 tapos yung red probe steady sa sa source(pin 3) tapos yung black probe i-tap mo ng isang beses sa gate(pin 1) tapos tester u ang drain (pin 2) at source(pin 3)magkabilaan me resistance yan at magkaiba ang resistance nyan at para mawala resistance i-short ang drain at gate. :)
Offline BUMBLEBEE
« Reply #12 on: September 22, 2011, 10:53:37 AM »
tama ka sir bhong may tamang pag-test sa FET katulad din sa sinabi mo
kaya kailangan i-descover mo kung paano mag-test jan TS...
pero kung alam mo paano pag-test sa FET at leak na talaga palitan muna yan
