Author Topic: sharp aphrody 29" shut off  (Read 264 times)
Offline rednax2
« on: October 01, 2011, 08:56:56 PM »
 help mga masters ito pong sharp aphrody na ginawa ko na hindi ko na tapus kanina dahil ngayon palang po ako nka encounter ng ganitong klasing trouble....... mag shut off after na mag display sa screen ang TIME OVER TV _________ NOT AVAILABLE.....pasencya na po na may kulang after ng TV nakalimutn ko po yong nkalagay dyan na word, yan po ang makita before mag shut off... ang ginawa ko po nag resolder ako sa lahat ng section ng board pero wla pa ring effect... hndi ko na lang muna ginalaw ulit kasi po hndi ko alam kng saan ako mag simula.... pls mga masters i really need your help plssssss.... tnx & godbess 2 all
Offline nucleus
Re: sharp aphrody 29" shut off
« Reply #1 on: October 01, 2011, 09:04:17 PM »
parang sa settings lang ng timer ah sa remote, or baka corrupt na ang eeprom nyan
Offline unitech
  • Pogi/Ganda Points: 61
  • all in one hunter
« Reply #2 on: October 01, 2011, 09:23:58 PM »
agree ...
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #3 on: October 01, 2011, 10:02:59 PM »
subs,..
Offline J@M
  • Pogi/Ganda Points: 130
« Reply #4 on: October 02, 2011, 01:40:10 AM »
Possible nga corrupt na eeprom...try mo kaya hang pin #8 ng eeprom then power ON TV then balik mo ulit pin #8.
Don't Give up
Offline rednax2
« Reply #5 on: October 02, 2011, 09:29:05 AM »
cge po tnx sa mga suggestion mga master try ko mamay...update ko lang mamaya...
Offline taqui
  • Pogi/Ganda Points: 228
  • ang ganda ko
« Reply #6 on: October 02, 2011, 04:57:49 PM »
parang eeprom nga ito...
Offline J@M
« Reply #7 on: October 08, 2011, 01:23:58 PM »
Mzta na kaya to...
Don't Give up
