Author Topic: Sony KV-21GDR2,no power, no picture, no sounds.  (Read 384 times)
Offline limuel1347
« on: October 06, 2011, 12:09:43 PM »
Sony KV-21GDR2,no power, no picture, no sounds. Pahelp guys kung wat part ang may problem and kung  anu papalitan?
Offline x13r_kit_0
  • Pogi/Ganda Points: 151
  • --__x13r_kit_0__--
Re: Sony KV-21GDR2,no power, no picture, no sounds.
« Reply #1 on: October 06, 2011, 12:15:06 PM »
Pag no power.,Automatic wala lahat diba..
Perform voltage testing bro,or do the basic muna..resolder.,
check mga major major parts.. :D :D
Dagdagan na rin ng info...
   =How about the other side?=
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #2 on: October 06, 2011, 12:28:03 PM »
^ agree,, abang muna sa update
Offline limuel1347
« Reply #3 on: October 06, 2011, 12:32:31 PM »
               ok.thanks..Possible kya yung 300 volts na supply yung cra?
  • Pogi/Ganda Points: 772
« Reply #4 on: October 06, 2011, 12:46:19 PM »
pwede fuse...
nagtataka lang ako nabuksan monaba ang unit?
Offline enriz622
  • Pogi/Ganda Points: 291
« Reply #5 on: October 06, 2011, 12:48:22 PM »
kung walang b+ check primary baka sira na ang str ic o resistor lang,putok ba ang fuse at anong kulay ng fuse maitim ba?
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #6 on: October 06, 2011, 12:51:38 PM »
katuwa si ts :D ;D
Offline limuel1347
« Reply #7 on: October 06, 2011, 12:57:58 PM »
nabuksan ko na yung unit,yung fuse gumagana nmn,pasuggest nmn po ng mga parts na pede ko icheck ,pakispecific nalang po  kung resistor ,diod, or etc.thanks
Offline acer
  • Pogi/Ganda Points: 110
« Reply #8 on: October 06, 2011, 12:58:56 PM »
info pa  po
nevergive up
« Reply #9 on: October 06, 2011, 01:00:38 PM »
check main switch
check voltage on primary cap may naiwan bang supply?
check HOT,
Offline pEN DoTA
« Reply #10 on: October 06, 2011, 01:24:39 PM »
back to basic ...
GOD LOVES YOU
Offline enriz622
« Reply #11 on: October 06, 2011, 01:39:31 PM »
yung capacitor sa secondary ng transformer ts may boltahe ba?
Offline BUMBLEBEE
« Reply #12 on: October 06, 2011, 01:44:46 PM »
antay ulit ng update,, sundin mo muna ts lahat ng sinabi ng mga ka-elab natin..
  • Pogi/Ganda Points: 231
« Reply #13 on: October 06, 2011, 04:28:19 PM »
basa mode muna.
Offline BUMBLEBEE
« Reply #14 on: October 06, 2011, 04:42:54 PM »
baka may secondary voltage na pero hindi mag-oscillate ,, ;D ;D need info poh sir,, kung may secondary voltage ba o wala,, kung may b+ and so on.....
post mo na rin lahat ng nagawa mo,, hindi kami makahula kung kulang din ng info.. :D
kung dead set ang unit,, first focus ka muna sa primary,, ano poh part number ng power regulator nito?
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #15 on: October 06, 2011, 07:16:01 PM »
pa sub nga dito....
Offline pEN DoTA
« Reply #16 on: October 06, 2011, 09:58:24 PM »
nawala na ang t.s
GOD LOVES YOU
Offline Emman091063
« Reply #17 on: May 16, 2013, 05:20:16 PM »
ang problema ko sa repair ko na kv-21GDR2 walang output ang regulator niya na strs6307. parehas ba strs6307 at strs6707 para isubok ang strs6707.
« Reply #18 on: May 17, 2013, 08:41:57 PM »
magka iba yan sir.,, next time paki basa mona ng date bago mag post 3  years ago na ang thread na ito
Offline TBG
  • Pogi/Ganda Points: 145
« Reply #19 on: May 18, 2013, 07:27:33 AM »
awwwoooooo,,.
