Author Topic: sanyo model st-21c18 chassis No.97-2118sx-ph12  (Read 964 times)
Offline acer
  • Pogi/Ganda Points: 117
« on: October 07, 2011, 12:48:25 AM »
patulong mga master baka po may diagram kayo o kaya data ng flyback
may gumawa na kasing ibang tech. ang ginamit na flyback  FA2017. hindi ko alam ang original na No. ng flyback
eto po ang nakita ko sa loob ng tv, naka hung ang flyback connected ng wire sa board kasi magkaiba ang pin asignment
ang problem ko pag angat ko ng board may natangal na dalawang wire medyo nalito ako
eto po ang nakita kung connection sa board
pin 1 = 200 v
pin 2 = col
pin 3=  ? (ano po kaya tawag dito connected sya papuntang VERtICAL out via resistor )
      4= B+
      5= 12V
      6= 24 V
      7 = ABL
      8 =GND
      9 = NC
      10 = heater
ang kelangan ko po ay data ng FA2017 baka meron kayo dyan TIA at kung ano tawag sa pin 3
nevergive up
Offline acer
Re: sanyo model st-21c18 chassis No.97-2118sx-ph12
« Reply #1 on: October 07, 2011, 10:42:05 AM »
up ko lang
nevergive up
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #2 on: October 07, 2011, 10:48:36 AM »
sis pwede matanong kung ano yung mga major parts nito,,
 syscon or uoc and vertical,regulator
Offline acer
« Reply #3 on: October 07, 2011, 12:26:28 PM »
wala  sa akin ang unit nasa bahay pa ng tumer ko post ko dito pag balik ko sa tumer
nevergive up
Offline beNj2angeL
  • Pogi/Ganda Points: 18
« Reply #4 on: October 07, 2011, 12:30:54 PM »
abang sa update..thanks.
``never get tired giving love to your beloved might lose them over a lifetime``
Offline acer
« Reply #5 on: October 07, 2011, 12:31:07 PM »
may nakita akung data hindi ko alam pinning
http://www.donberg.ie/descript/h/hr_8303.htm
nevergive up
Offline BUMBLEBEE
« Reply #6 on: October 07, 2011, 12:35:21 PM »
iba yata sis kasi yung pin 4 is grnd..and doon sayo is b+
 nag-hanap din ako,, pero wala akong makita.. abang tayo nito kung sino man ang may mapa,,
modified na pala eto sis?? hindi na original yung FBT nya??
Offline acer
« Reply #7 on: October 07, 2011, 12:50:17 PM »
sis bumblebee ito yung pin ng flyback
ito naman ang sa board,
pin 1 = 200 v
pin 2 = col
      4= B+
      5= 12V
      6= 24 V
      7 = ABL
      8 =GND
      9 = NC
      10 = heater
 replacement lang kasi ang ginamit na flyback ng dating tech na gumawa ng tv hindi na ogig ang nakalagay na flyback
nevergive up
Offline BUMBLEBEE
« Reply #8 on: October 07, 2011, 01:11:33 PM »
kailangan talaga yan ng mapa sis,,
hindi ko masundan mukhang kakaiba yung original na FBT nyan sis,,
pero matanong ko lang sis gumana poh ba yung unit ng palitan yan ng replacement na fbt?
pahabol na rin sis,, yan poh sinasabi mo na pin 3 anong value poh nung resistor na yan?
parang ganito ba yung schema nyan?
kung ganyan at hindi dumaan sa diode baka negative supply ng vertical pero,, hindi ako sure,,..
Offline enriz622
  • Pogi/Ganda Points: 304
« Reply #9 on: October 07, 2011, 03:49:55 PM »
Patambay nga
Offline unitech
  • Pogi/Ganda Points: 61
  • all in one hunter
« Reply #10 on: October 07, 2011, 04:17:51 PM »
pa sub nga dito....
Offline acer
« Reply #11 on: October 08, 2011, 01:00:58 PM »
matagal na daw yun gumagana sabi ng tumer ko aksedente ko lang ntanggal yung wire sa board hindi ko na alam kung saan nkakabit. naka hung lang kasi ang flyback mas ok sana kung may tamang data ang flyback
nevergive up
  • Pogi/Ganda Points: 776
« Reply #12 on: October 08, 2011, 02:01:30 PM »
pag-aralan mo nalang ang voltage na natanggal sa wire ng fbt. voltage reading sir aandar naman yan kahit kulang ang nakakabit
Offline acer
« Reply #13 on: October 08, 2011, 04:42:27 PM »
sir pete umaandar kaya lang parang may fold over sa  left side ng screen
nevergive up
Offline rigor37
  • Pogi/Ganda Points: 76
« Reply #14 on: October 08, 2011, 04:48:51 PM »
Eto original flyback nyan sis
JF0501-1909A
Kung kaya ng iba...Ipagawa mo na lang sa kanila ;D
« Reply #15 on: October 08, 2011, 06:46:28 PM »
picture mo kaya sis ang screen at fbt  connection na cut
Offline acer
« Reply #16 on: October 08, 2011, 09:44:59 PM »
iniwan ko muna tumer  ang unit sis pete,  sabi ko sa tumer hanap muna ko ng diagram
JF0501-1909A
salamat sis tatanung ko pa sa tumer ko kung papalitan nya ng flyback ,
nevergive up
Offline enriz622
« Reply #17 on: October 08, 2011, 10:35:35 PM »
 FA2017
 1.AFC
 2.HEATER
 3.189 VOLTS
 4.GROUND
 5.13.5 VOLTS
 6.25.9 VOLTS
 7.NC
 8.ABL
 9.B+ 134 VOLTS
10.COLECTOR
Offline acer
« Reply #18 on: October 09, 2011, 12:41:50 AM »
FA2017
 1.AFC
 2.HEATER
 3.189 VOLTS
 4.GROUND
 5.13.5 VOLTS
 6.25.9 VOLTS
 7.NC
 8.ABL
 9.B+ 134 VOLTS
10.COLECTOR
itry ko ito pag balik ko sa tumer
nevergive up
Offline acer
« Reply #19 on: October 24, 2011, 09:19:10 PM »
 update lang ako ok na yung TV mga master pinalitan ko
JF0501-1909A
salamat sa lahat ng nagreply  ;) ;) ;)
nevergive up
