Author Topic: Samsung CT-211S may itim na guhit sa taas ng screen  (Read 2030 times)
Offline Fast_Click
  • Pogi/Ganda Points: 10
Re: Samsung CT-211S may itim na guhit sa taas ng screen
« Reply #20 on: October 08, 2011, 03:59:49 PM »
150 dito sa amin,.. medyo ma ulan pa punta pa ako ng bayan,.
Offline /
  • Pogi/Ganda Points: 317
« Reply #21 on: October 08, 2011, 04:01:12 PM »
basa..
Offline acer
  • Pogi/Ganda Points: 107
« Reply #22 on: October 08, 2011, 04:48:18 PM »
abang lang muna
sa vertical
nevergive up
Offline Fast_Click
« Reply #23 on: October 08, 2011, 05:21:43 PM »
wew,sakit na ng mata ko at batok,..
puwede po ba akong mag dikit ng ecaps sa ibaba ng board same voltage or mas mataas na capacitance any tricks ng madali ko itong ma trbleshot mga sis?
Offline pEN DoTA
« Reply #24 on: October 08, 2011, 05:27:23 PM »
wait nlang ako sa RC baka mkuha sa svc.
GOD LOVES YOU
Offline Fast_Click
« Reply #25 on: October 08, 2011, 05:40:03 PM »
hanap lang muna ako remote sa kapit bahay baka sakali meron sila,.
basta po ba hpold mute at 182 lang po ba gagawin ko bos?
  • Pogi/Ganda Points: 771
« Reply #26 on: October 08, 2011, 05:52:27 PM »
basahin mo uli ang post ko service mode na kailangan dyan
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #28 on: October 08, 2011, 06:02:52 PM »
pa sub...
dj fel on the mix
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #29 on: October 08, 2011, 06:05:02 PM »
OT: makiki-copy ;D
one point sayo master pete..
Offline Fast_Click
« Reply #30 on: October 08, 2011, 06:31:48 PM »
naka hiram ako ng remote hold mute tiaka 182 wala po lumalabas na service mode mga sis or mali procedure ko?
« Reply #31 on: October 08, 2011, 06:39:40 PM »
bakit hold mute?
standby mode
press mute 1 8 2 power on
Offline Fast_Click
« Reply #32 on: October 09, 2011, 11:17:07 PM »
Up kolang po mga idol,at pasensiya na ngayun lang po ako nakasagot sa thread ko nag duty kasi ako sa robonson pampana as a cp tech, ayaw pumasok sa service mode may ibang way ba kayo para maayos kona po ito?
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #33 on: October 09, 2011, 11:52:21 PM »
pa subs......
  • Pogi/Ganda Points: 411
« Reply #34 on: October 10, 2011, 12:42:01 AM »
Ako rin paabang lang muna.
Offline Fast_Click
« Reply #35 on: October 10, 2011, 01:16:35 PM »
pa up lang po mga bossing,.
puwede bang nasa memory ang prob nito?
« Reply #36 on: October 10, 2011, 05:46:20 PM »
paano ba ang procedure na ginawa mo? you don't follow simple instruction
sahalip na standby mode mute 1 8 2 power on
Offline rigor37
  • Pogi/Ganda Points: 76
« Reply #37 on: October 10, 2011, 06:23:03 PM »
Kung kaya ng iba...Ipagawa mo na lang sa kanila ;D
Offline DJFEL
« Reply #38 on: October 10, 2011, 08:51:29 PM »
pa abang nito...dami kaC samsung ko dito..
dj fel on the mix
Offline Fast_Click
« Reply #39 on: October 11, 2011, 12:33:20 AM »
thanks to all mga master,..
napasok ko din ang service mode
at ang ginawa ko ne RESET kolang at ayun sapul ok na,..
post ko pic bukas maraming salamat din po sis PETE at sa inyo mga sis.
+! lahat kayo :D
