As ive said magdistort din yong sakura for sure kaso kung sa midhigh mo sya ginagamit ang volume level mo nun is lower than bass amp.I think distort is not the right word for this but CLIP.Sir tony is right my amp clips earlier than normal and im sure ganun din yong sakura. The only diffrence is their volume level. My amp clips at high volume because of rail drops due to main line low voltage.Nasabi ko lang dati na nagdistort yong sakin while ang sakura hindi dahil di ko nakausap yong may-ari in personal, kaya nang nagkausap na kami saka ko naintinfihan ang ibig nyang sabihin.
ok din po ba ito sa CCS mga master?
info naman po about dito,, nag ka time kasi akong tumutok kay multaysem na ngalikot lang ako.
simulators does not take into account parasitics due to board layout, lead lenghts.........i do not put too much faith in those....results should be taken with a grain of salt...
Someday simulators will be more realistic.New versions will always come out and will somehow take into account all that you need.SPICE is where experts still put their trust.Tingnan ko tong PowerPro Edition ko kung mganda.
