Author Topic: [HELP] Z8F042A to 5 x 7 segment display?  (Read 282 times)
Offline hpesoj15
« on: October 12, 2011, 04:00:00 PM »
Sir, Pwede po patulong nito.
Ang ginawa ko na lang po ang charlieplexing kasi limited lang po yong IO pins ng micro ko. Naintindihan ko po yong setup ng hardware kaso wala po akong masyadong experience sa codes.. Puwede po ba gawin niyo to na codes?? (from Jose Pino website)
Maraming salamat po.
Define variable DATA
Define variable POSITION
if POSITION = 1
   port A0 = DATA BIT 7 ; shift all bits
   DATA BIT 7 = DATA BIT 6
   DATA BIT 6 = DATA BIT 5
   DATA BIT 5 = DATA BIT 4
   DATA BIT 4 = DATA BIT 3
   DATA BIT 3 = DATA BIT 2
   DATA BIT 2 = DATA BIT 1
   DATA BIT 1 = DATA BIT 0
   set PORT B as input where data bit = 0
   set PORT B as output where data bit = 1
   set PORT B0 as output
   PORT B = DATA
   PORT B0 = 0 ; 0 for Common cathode
end if
if POSITION = 2
   port A0 = DATA BIT 7 ; shift 7 bits
   set PORT B1 as output
   PORT B = DATA
   PORT B1 = 0 ; 0 for Common cathode
end if
if POSITION = 3
   port A0 = DATA BIT 7 ; shift 6 bits
   set PORT B2 as output
   PORT B = DATA
   PORT B2 = 0 ; 0 for Common cathode
end if
if POSITION = 4
   port A0 = DATA BIT 7 ; shift 5 bits
   set PORT B3 as output
   PORT B = DATA
   PORT B3 = 0 ; 0 for Common cathode
end if
if POSITION = 5
   port A0 = DATA BIT 7 ; shift 4 bits
   set PORT B4 as output
   PORT B = DATA
   PORT B4 = 0 ; 0 for Common cathode
end if
if POSITION = 6
   port A0 = DATA BIT 7 ; shift 3 bits
   set PORT B5 as output
   PORT B = DATA
   PORT B5 = 0 ; 0 for Common cathode
end if
if POSITION = 7
   port A0 = DATA BIT 7 ; shift 2 bits
   set PORT B6 as output
   PORT B = DATA
   PORT B6 = 0 ; 0 for Common cathode
end if
if POSITION = 8
   port A0 = DATA BIT 7 ; shift 1 bit
   set PORT B7 as output
   PORT B = DATA
   PORT B7 = 0 ; 0 for Common cathode
end if
Offline hpesoj15
Re: [HELP] Z8F042A to 5 x 7 segment display?
« Reply #1 on: October 19, 2011, 08:56:23 AM »
Up ^^
Please patulong naman po sa inyo..
Offline SpongeBob
  • Pogi/Ganda Points: 33
« Reply #2 on: November 03, 2011, 06:22:14 PM »
Check mo yun CD ng e-Gizmo, meron code ng LED matrix. Edit mo lang kung gusto ng mas mahabang display.
