Author Topic: cd-r king DVD-2018 reviews & tweaks  (Read 602 times)
Offline efren
  • Pogi/Ganda Points: 210
  • old school audio fanatic
« on: October 13, 2011, 11:53:35 AM »
a trip to cd-r king store i spotted this small DVD player worth 880 pesos, i needed a CD player in my work table so i bought it, unpacking it at home i hook it up to my tube amp, to my disgust my tube amp sounded like a gainclone, too bright and harsh, hooking it to my class A solid state it sounded even worse... :P
the player, RCA cable & 5V power supply included
slightly larger than a CD case
so i decided to mess around with its audio circuitry, an op-amp feeds the output jacks, how about by-passing the op-amp?....
here is the two e-caps straight from its D/A converter
the tweaks made, replace the e-caps with a new one, bypass the op-amp at the expense of a lower voltage swing at the output (i'm using a high impedance tube per amp anyway so this would never be a problem
the blue & green jacks will now be the audio out
a few listening tests....now much better, 75% of harshness is gone, anyway, i don't expect it to sound like a high end CD player, what do you expect from 800 pesos ;D
now covering up, oopps, i tear up the warranty seal, there goes my three month service warranty ;D
a player not bad if you perform these tweaks / mods, no issues on the video though,...
Before the tweak i'd rate it 2 out of 10 after tweaking i'll give it 6 out of 10
Summary: nice cheap daily audio/video player that can run even on batteries, but not recommended for serious hi-fi listening ;)
"just keep 'em glowing"
Offline ditchie
  • Pogi/Ganda Points: 100
  • wish ....wish...
Re: cd-r king DVD-2018 reviews & tweaks
« Reply #1 on: October 13, 2011, 12:04:30 PM »
plus 1 sis
--Mahatma Gandhi
Offline pEN DoTA
« Reply #2 on: October 13, 2011, 01:29:52 PM »
+1 ka din sa akin master efren. :)
GOD LOVES YOU
Offline efren
« Reply #3 on: October 13, 2011, 02:38:57 PM »
salamat mga sis :)
  • Pogi/Ganda Points: 411
« Reply #4 on: October 13, 2011, 08:08:46 PM »
Napunta pala kaagad sa operating table.
+1 rin sa review sir efren. Saka sa modification.
  • Pogi/Ganda Points: 53
« Reply #5 on: October 13, 2011, 08:15:42 PM »
galing +1 :D
  • Pogi/Ganda Points: 412
« Reply #6 on: October 13, 2011, 08:20:46 PM »
What I salute the most is the desoldering pump...:P
I can see that it serves you well for so many years...and I bet walang 100 petot yan..but damned tough! yun din gamit ko at worth talaga...;D
Offline efren
« Reply #7 on: October 13, 2011, 09:33:50 PM »
right sir, binata pa ako nyan, if my memory was right it cost me 65 pesos sa Deeco Marcos hi-way, now my daughter is 9 years old ayos pa sya, tinataktak lang pag napuno na ;D
« Reply #8 on: October 13, 2011, 09:37:22 PM »
makikita sa body nya mismo...talbog pa soldapullt dyan..
Offline efren
« Reply #9 on: October 13, 2011, 09:44:11 PM »
I once bought a soldapult, after about a year nagkalasan na yun mga plastic parts, mahal pa pagkabili ko nun :P
« Reply #10 on: October 13, 2011, 09:54:01 PM »
uu mahal yun...last time yung kasing laki lang ng nasa pic sa taas nasa 1250 na yata...puro plastic na light brown..
Offline /
  • Pogi/Ganda Points: 317
« Reply #11 on: October 13, 2011, 09:56:36 PM »
+1 master, ang gagaling nyo.
Offline Fast_Click
« Reply #12 on: October 13, 2011, 10:12:53 PM »
+1 po sis
galing naman,..
may bago nanaman ako natutunan,...
Offline efren
« Reply #13 on: October 13, 2011, 10:52:24 PM »
+1 po sis
galing naman,..
galing +1 :D
glad this helps in my own little way, salamat po sa inyo :) :) :)
