Author Topic: cant boot on cd/dvd.. any advice please..  (Read 1807 times)
Offline Comanchee
  • Pogi/Ganda Points: 10
« on: October 16, 2011, 03:19:38 PM »
Sir's from windows 7 downgrade ko sana sa Windows Xp  operating system ko.. kaso ang problema ayaw magboot sa cd/dvd yung PC ko.. nkakapagtaka kase before ko nman magformat iset dvd/cd as 1st boot then inserted the windows xp cd and restart.. after the restart indi lumalabas yung message na "press any key to boot from cd/dvd" kundi black screen lang.. same thing sa external dvd rom ko.. sinibukan ko na rin reset ang bios tru sa jumper.. peroganun pa rin.. motherboard - Asus P5gc /MX ...
"Life is not a problem to be solved, but a gift to be enjoyed"
Offline /
  • Pogi/Ganda Points: 317
Re: cant boot on cd/dvd.. any advice please..
« Reply #1 on: October 16, 2011, 03:33:24 PM »
check mo sir yong bootable cd mo.
Offline j a y k e z
  • gimmegaggigsss
« Reply #2 on: October 16, 2011, 03:33:50 PM »
"Baka"
Need to press a key to boot to the CD or DVD
CD or DVD is not bootable.
Not setup properly in CMOS.
Bad CD / DVD disc.
Jumpers not set properly.
Cables or other drive related issues.
Bad CD drive.
 ;D  ;D  ;D
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #3 on: October 16, 2011, 03:58:05 PM »
sis try mo lagay sa disable mode ang hardisk ;)
Offline chinokscapsighter
  • Pogi/Ganda Points: 81
  • Chinoks_capsighter the imaginative painter.......
« Reply #4 on: October 16, 2011, 04:19:15 PM »
Try ka gumamit ng ibang cd/dvd rom... or ibang bootable Disk...
Offline explorer1007
  • Pogi/Ganda Points: 29
« Reply #5 on: October 16, 2011, 04:47:59 PM »
gamit ka ng ibang installer, malamang sira windows xp cd mo or di bootable
Offline Comanchee
« Reply #6 on: October 16, 2011, 05:10:36 PM »
nasubukan ko na rin gumamit ng ibang installers pero ganun parin.. then gumamit na rin akoibang dvd rom external ganun parin.. yung hdd ko ide connection sya tpos yung dvd ron ko nman sata.. ok lang nman yun db as long as nakaset sa bios sa ide configuration ng enhance mode at sata+pata mode... khit nga yung installer ko ng windows seven ayaw din pero kpag try ko nman iboot sa laptop yung mga installers ok nman lahat nagbobot nman..
Offline de PatAtas
  • Pogi/Ganda Points: 330
  • ' The unbreakable
« Reply #7 on: October 16, 2011, 05:13:30 PM »
' e try mo IDE na DVD/CD ROM
Offline /
« Reply #8 on: October 16, 2011, 05:15:25 PM »
restore default mo nalang sis ang settings ng bios mo. yong boot order lang ang baguhin mo, by assigning your cdrom to first boot.
Offline de PatAtas
  • ' The unbreakable
« Reply #9 on: October 16, 2011, 05:22:49 PM »
' nka first boot na daw ang CD/DVD ROM.. ;D
Offline Comanchee
« Reply #10 on: October 16, 2011, 05:33:45 PM »
sir sa hdd ko nakajumper sya sa first two pins from left which is nka master or singledrive... kpag ganun indi ba magboot sa cd khit na first bott na sa bios???? hdd ko IDE connect tpos ung dvd ron ko Sata
Offline /
« Reply #11 on: October 16, 2011, 05:37:37 PM »
uu nga i reset nya nga ulit ang bios settings to default at ulitin ang settings, pero this time yong boot order lang ang galawin nya. i disregard nya na yong ibang settings.
Offline Vaounsi
  • Pogi/Ganda Points: 146
« Reply #12 on: October 16, 2011, 05:54:45 PM »
wala ba error msg? nang gumamit ka ba ts ng portable dvdrom detected ba? baka hindi, format mo nlng hdd mo sa ibang pc saka ka magformat. baka sakali tumalon cdrom
Offline BhongTech
« Reply #13 on: October 16, 2011, 06:22:50 PM »
boot
1st boot (hardisk)---> natry nyo sis na ilagay sa disable
2nd boot (cdrom)
 tapos save in exit. ;)
Offline Johannah Aleksandria
  • Pogi/Ganda Points: 136
  • Make it simple
« Reply #14 on: October 16, 2011, 06:37:09 PM »
Baka nman di na nag-save yung settings mo sa bios dahil sira na battery.
Check mo kung nagbabago nga ang settings mo pag nag-restart. Baka naiwanan mo sa reset yung jumper mo.
« Reply #15 on: October 16, 2011, 07:14:30 PM »
Oo nga pwede rin sa battery... naka experience na ako nyan... :)
  • Pogi/Ganda Points: 411
« Reply #16 on: October 16, 2011, 07:53:51 PM »
Ayan rami na payo ng mga master.
1. Check Cmos batt baka wala na rin at default first boot ay HD. Kasi sabi mo black screen malamang nga baka palitan ng battery.
2. Recheck reset jumper settings baka nga naiwan sa reset.
3. Isa pang problema dyan ay nagagalaw ang RAM module kaya black screen din.
4. Baka meron built in video card or may nakalagay na additional video card. Baka kailangan native envi muna.
Haysst hula lang.
  • Pogi/Ganda Points: 771
« Reply #17 on: October 16, 2011, 08:06:04 PM »
reformat mona sa ibang unit ang hdd mo saka mo pasukan ng xp or copy nalang
kahit naman walang battery e mag save parin yan waglang tanggalin ang saksak ng cpu
Offline Lola Baciang
  • Pogi/Ganda Points: 131
« Reply #18 on: October 16, 2011, 08:18:34 PM »
detected ba hdd at dvdrom mo sa bios?oo nga chek mo ang cmos batt.at kung lobat na yan hnd na nya kaya i save ang bios setting mo
Expect The Unexpected
« Reply #19 on: October 16, 2011, 08:18:41 PM »
