Author Topic: cant boot on cd/dvd.. any advice please..  (Read 1808 times)
Offline j a y k e z
  • gimmegaggigsss
Re: cant boot on cd/dvd.. any advice please..
« Reply #40 on: October 17, 2011, 02:37:14 PM »
kung suported ni mobo ang boot usb  ;D
try mo po gumawa bot usb
madaming tut kay pareng google  :D
Offline /
  • Pogi/Ganda Points: 317
« Reply #41 on: October 17, 2011, 02:38:20 PM »
corrupted yata ang MBR or partition neto kaya nagkakaganyan.
  • Pogi/Ganda Points: 771
« Reply #42 on: October 17, 2011, 02:40:32 PM »
hindi po yan installer, meron na syang OS na ready. i boboot mo nalang dyan at pwede mong buksan ang pc mo kahit walang hdd.
magic O.S ba ito master?
Offline /
« Reply #43 on: October 17, 2011, 02:43:07 PM »
sa herin merong mini xp sir, live cd sya.
at pwede ka ring gumawa ng personalized, kahit mga boot screen pwede mong ilagay ang picture mo. gagamit ka ng PE builder.
Offline Comanchee
  • Pogi/Ganda Points: 10
« Reply #44 on: October 17, 2011, 03:18:04 PM »
TS another try, palitan mo ang keyboard at mouse mo isa din yan sa cause.
ok sir update ako ulet.. hirapan na ako dito... indi ko maformat-format ang PC ko..
"Life is not a problem to be solved, but a gift to be enjoyed"
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #45 on: October 17, 2011, 04:25:28 PM »
he he he sir kahit walang hardisk o corrupted dabat mag-boot sa cd or dvd rom yan kung tama ang setting sa bios, TS na-try muna po ba ang pag-disable ng hardisk para malaman mo lang sa pag-reboot nya kung mag-run ang bootable disk mo.asus yan di po ba paki-try na i-disable ang hardisk sa boot setting ng mobo mo.pag hindi nag-run pwedeng me problema sa cable mo papuntang rom lalo na't alam mong ok ang bootable disk mo. :D
Offline Comanchee
« Reply #46 on: October 17, 2011, 04:32:16 PM »
disable ko ba sa boot settings or dun sa mismong settings nya po... nasubukan ko na kase disable lahat sa boot settings malibang lang sa first ko na dvd/cd rom..
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
« Reply #47 on: October 17, 2011, 04:40:54 PM »
abang,,
first boot cd or dvd, tapus save..and exit
tapus mag-restart yan
 tapus tingnan mo ulit sa bios kung nasave ba kung ang first boot mo is cd or dvd.. pag-bumalik ulit sa dati.... malamang
pero kung na'save ng tama at first boot mo talaga is cd or dvd
tapus hindi mag-labas ang -------- press any key .......
kahit bago dvd/cd rom..
malamang kakaiba nga sira nito,, at aabangan ko talaga to.. para may-matutunan
Offline BhongTech
« Reply #48 on: October 17, 2011, 04:47:13 PM »
sis naibalik mo yung reset sa dating position(cmos)sabagay pag di mo naibalik di yan mag-start up bale naka hang lang.
TS yung i-disable lang yung hardisk mo. :)
Offline j a y k e z
  • gimmegaggigsss
« Reply #49 on: October 17, 2011, 04:51:00 PM »
subukan mo po ung ibang monitor hehehe ;D ;D ;D
  • Pogi/Ganda Points: 411
« Reply #50 on: October 17, 2011, 04:55:36 PM »
I-check rin keyboard baka meron stuck up.
Check cmos settings lalo na sa mga drive. Irefresh mo kung maari para magredetect sya ng mga drive pero wala yung HDD. Then saka mo subukan ichange ang boot order sa cdrom. Shutdown cpu then connect again HDD upon boot up recheck cmos settings sa mga drive kung nagiba na naman settings.
Online Lola Baciang
  • Pogi/Ganda Points: 131
« Reply #51 on: October 17, 2011, 04:59:08 PM »
Aha,my bad sector na yata ang hdd mo,kung tumitigil sya during scanning files,kunin mo kung anong percent sya tumigil,let say tumigil sa 60% i-divide mo ng 2 or 3 partition para mai-quarantin mo ung badsector na nandun sa 60% kung saan sa sya tumigil,bka makatulong
Expect The Unexpected
Offline BUMBLEBEE
« Reply #52 on: October 17, 2011, 05:16:57 PM »
hindi yata mag-boot ang problem ng ts kaya hindi rin eto magawan ng partition,, ang hdd
kahit walang hdd kailangan mag-boot ang cd neto,,
 kung tama ang pag-set sa bios kailangan din pala yata na ma-detect ang cd or dvd,, sa bios
Online Lola Baciang
« Reply #53 on: October 17, 2011, 05:26:00 PM »
At ang sabi nya ok nman dw sa dati nyang hdd na my win7 os.meaning palit hdd ang magiging ending nito
« Reply #54 on: October 17, 2011, 05:47:13 PM »
Hinahanap ng bios yung hardware ID ng lumang HD.
Offline rigor37
  • Pogi/Ganda Points: 76
« Reply #55 on: October 20, 2011, 10:37:55 PM »
matindi ang trouble nito a... ano na kayang update?
abang mode.....
Kung kaya ng iba...Ipagawa mo na lang sa kanila ;D
Offline BhongTech
« Reply #56 on: October 20, 2011, 11:55:41 PM »
he he he dapat disable ang hardisk para maghanap ng ibang bootable, syempre kailangan naka Enabled din ang Boot from other Device, at karamihan sa asus para maka pag boot sa cd rom dapat disable ang first boot(hardisk).  ;)
Offline Comanchee
« Reply #57 on: October 21, 2011, 10:18:45 AM »
Sir update ko kayo.. medyo ngaun lang ulet nagkaroon ng time.. ginagawa ko ngaun.. nilagay ko HDD ko na may  windows 7 to boot sa windows (Sata) then nilagay ko din yung isang HDD (IDE) para maiformat ko sa windows.. tpos try ko sya install ng xp...
Offline Comanchee
« Reply #58 on: October 21, 2011, 10:58:03 AM »
after for wala pa rin ayaw talga magboot sa CD/DVD Rom.. any lumalabas ang message.. ask ko na lang ulet mga sir, i have 2 HDD yung isa ay merong windows 7 OS... so naisip ko kung pwed kaya install ko ng lang xp yung 2nd drive.. without booting sa bios.. sa mismong windows kumbaga sa Setup tpos install ko sya sa drive ng 2nd HDD ko.. possible ba yun..
Offline BhongTech
« Reply #59 on: October 21, 2011, 11:04:30 AM »
sis kung naka win 7 ang os mo tapos install ng xp, sa tingin ko di pwede.
