kung gusto nya pakontian ng parts, mag LM12 sya meron nito sa Electronic Enthusiast.kaso limot ko na kung anong volume
meron pa bang nabibiling lm12? Issue boss yun hindi volume.
Magkaiba po b ang ta8216h sa ta8216hq?
pwede pu papost schematic pcb ng stk2050?
download http://www.alldatasheet.com/datasheet-pdf/pdf/82969/ETC/STK2050.html here is much more simple, based on Philips TDA1521, i built this two years ago, very few external parts this is for single rail supplydual rail, PO= 12W X 2 I used +/- 18VDC, much lesser parts (no output cap, no bypass cap) my TDA1521 build, with a 12AU7 tube on the front endchassis preparationparts preparationtesting the final product
4A for better headroom ok na yan, but this can go for as little as 1A in my opinion, 24W total RMS is too loud kung pang kwarto lang, & i suggest that you incorporate bass & treble control to tailor fit your preferences if you build this TDA1521.as for me Toshiba's TA8216H is much more superior in terms of sonic quality than Philips TDA1521, the latter excels in simplicity
yung dual rail for tda,18-0-18,edi pumapatak po ng 36v from negative to positive?Monorail 18v lang?Tama po ba?Pareho lang ba yung me tda1521q sa walang q?Me schematic+pcb pu ba sa ta8216h?Kape ka muna sis.=)
as per Toshiba datasheet parehas lang...http://www.toshiba.com/taec/components/Datasheet/TA8216HQ.pdf ta8216hqhttp://www.datasheetcatalog.org/datasheet/toshiba/1152.pdf ta8216h
