Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Academic Community and Professionals
Absolute Beginner Technical Discussion
simple buzzer schematic diagram please pahingi mga sir.,
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: simple buzzer schematic diagram please pahingi mga sir., (Read 2699 times)
mecaniko
CR2032 Battery
Pogi/Ganda Points: 3
Gender:
on:
February 01, 2008, 09:44:09 AM »
mga boss pahingi naman dyan ng diagram ng buzzer...gusto ko kasi mag-assemble nalang para di na ako bibili ng tester .. ........gagamitin ko kasi pang tester ng cotinuity.. masmadali kasi sa circuit tracing pag buzzer ang gagamitin.
salamat in advance mga sir.
Logged
God first before everything
on:
0b00000111
Technical People
Solar Power Satellite
Pogi/Ganda Points: 398
There is no delight in owning anything unshared.
Re: simple buzzer schematic diagram please pahingi mga sir.,
Reply #1 on:
February 01, 2008, 09:50:25 AM »
mura na lang sir ang tester na may buzzer sa raon...
kung gagawa kayo for continuity, kuha kayo ng battery at yung buzzer. connect the + of the battery to a probe and another end of a buzzer to another probe. tapos connected na yung - ng battery at another end of buzzer.
Logged
E-Gizmo Mechatronix Central:
www.e-gizmo.com
YM: julie.egizmo aka Born2BeWired
Reply #1 on:
mecaniko
CR2032 Battery
Gender:
Reply #2 on:
February 01, 2008, 09:58:35 AM »
gusto ko kasi boss chargeable buzzer gamit ang battery ng cellphone..tapos cellphone charger din ang gagamitin ko pangcharge
Logged
Reply #2 on:
0b00000111
Technical People
Reply #3 on:
February 01, 2008, 09:59:38 AM »
ah ok
Logged
www.e-gizmo.com
Reply #3 on:
paranz
Technical People
Nuclear Reactor
Pogi/Ganda Points: 177
Gender:
1/4W resistor specialist
Reply #4 on:
February 01, 2008, 10:04:49 AM »
magaling talaga si idol manny
Logged
Reply #4 on:
Ikasamoko
Pogi/Ganda Points: 414
Gender:
..sexually deficit..
Reply #5 on:
February 01, 2008, 03:34:18 PM »
Check this out..
http://www.talkingelectronics.com/html/ContinuityTester.html
Logged
Visit My "BLAG!"
http://rbt-techdepot.blogspot.com/
mArKhAo
Gas Turbine
Pogi/Ganda Points: 70
Gender:
point and shoot
Reply #6 on:
February 18, 2008, 02:03:17 PM »
hehe pasaway na buzzer yan ah.
Logged
bravokilo
Gas Turbine
Pogi/Ganda Points: 109
Reply #7 on:
July 30, 2009, 09:55:23 AM »
Uy, maganda yan ckt. Low injected voltage pa.
Pwede din blinking LEd unless bulag and user.
Bumili na ka na lang ng alito FM na may earphone na P60 lang ata. Break the battery connection and put a probe. Ayan, pag kumanta, on yun.
BK
Logged
bravokilo
Gas Turbine
Reply #8 on:
September 14, 2009, 01:07:27 AM »
mecaniko, hi! I am wondering what had happened to your buzzer continuity tester. Alam mo, the worst kind of continuity tester is the one in hardwares, even Ace, where they use 220 v in series with a bulb. Isa, delikado sa tao,k ikalawa mataas ang injected voltage na ok lang kung blb lang ang under test.
Alam mo a simple buzzer in series with a battery is fine in as long as hindi mo gamitin sa devices na sensitive to high V or high current. The cellphone battery na Li Ion as 4.2 volts and you have to find a buzzer na tutunog at that voltage. MArami pa nga ako ganoon. yung circuit ni Kasamiko may advantage na ang |V and current doon sa probe maliit lang. may safe sa equipment under test.
Bumili ka na lang ng either blinking LED o yung dual color. Series mo ng resistor, the battery, then the probes. Pag may contact, sisindi. m,ayroon gangyan sa Radio Shack at mayroon ako nun. Led lang. Nice for quick test ng bumbilla, ballast, relay, etc..
let me kow if you need help.
BK 8253867
Logged
Reply #8 on:
Print
Pages: [
1
Go Up
« previous
next »
