Author Topic: dell inspiron 1300  (Read 861 times)
Offline Lola Baciang
  • Pogi/Ganda Points: 131
Re: dell inspiron 1300
« Reply #20 on: October 28, 2011, 05:53:38 PM »
sis kung hndi ka sure na yan ang culprit,connect mo ulit atobserve muna kung ayaw pa rin disconnect mo lng ung cable ng backlight,tapos sukatin mo inverter board,pin 1 + at negative probe somewhere sa mga screw holes,dapat my masukat ka 19vdc,ingat lng sis sa pagtest mo kc once na magkamali ka pag diin ng test probe maari lumala sira nyan,
Expect The Unexpected
« Reply #21 on: October 28, 2011, 05:53:46 PM »
« Reply #22 on: October 28, 2011, 06:03:33 PM »
Or bili ka ng backlight pang testing lng 2 klase lng size ng conector yan,1 maliit at 1 malaki,pra lng ma isolate mo kung ano part ang salarin
Offline explorer1007
  • Pogi/Ganda Points: 29
« Reply #23 on: October 28, 2011, 06:28:57 PM »
oo nga make sure muna na inverter nga ang may problema kasi pwede ring bulb yan.
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #24 on: October 28, 2011, 06:49:08 PM »
apdit lang ko sundy sis...my gigs pa ako bokas..tnks po sa lahat...baka backlight ang sera...
dj fel on the mix
Offline unitech
  • Pogi/Ganda Points: 58
  • all in one hunter
« Reply #25 on: October 28, 2011, 09:22:07 PM »
paabang po...
Offline DJFEL
« Reply #26 on: October 29, 2011, 07:43:59 AM »
mga sis...diba high voltage yong out neto..may na kita ring ako f ok lang mang test lang ng LCD yong baclight lang eba model lang riserch mona ako bokas f kapareha sa voltge po nang LCD sa dell...
dj fel on the mix
« Reply #27 on: October 30, 2011, 03:14:42 PM »
Sis basta backlight ng lcd yan,pang test lng nman and be sure na pareho size ng connector,kung umilaw yan meaning backlight ang culprit,then go along wid your defect backlight for comparison to buy new one
  • Pogi/Ganda Points: 53
« Reply #28 on: October 30, 2011, 04:25:28 PM »
Ow may gas!
AKoy' nahehehelo saiyu Ts..
Repost lang natin:
« Reply #29 on: November 01, 2011, 01:15:54 PM »
 update na nito? :D :D :D
Offline DJFEL
« Reply #30 on: November 02, 2011, 07:23:40 AM »
bz sa gigs 4r Hallo-ween....apdit lang ako neto mga sis...tnks po sa advce.
dj fel on the mix
Offline profpat
  • Pogi/Ganda Points: 9
  • "pag gawa ng tao! kaya natin ayusin"
    • LCD REPAIR PHILIPPINES
« Reply #31 on: November 02, 2011, 11:48:38 PM »
malamang may tama na inverter or ccfl lamp, kaya nag proprotech yung backlight..
Offline DJFEL
« Reply #32 on: November 09, 2011, 06:36:26 PM »
pa senya na...inverter yong sira sa aken...try ku palit bago laptap kaC elang mths balik ang sira kaC replacement lang yong inverter...tnks po sa lahat..ngayon ko lang apdet to mga sis..
dj fel on the mix
« Reply #33 on: November 09, 2011, 07:08:20 PM »
Ganun ba sis?congrats na pla ito at kapehan na rin na my kasamang puto pa,hehehe
Offline DJFEL
« Reply #34 on: November 10, 2011, 07:47:16 AM »
tnks daddy jhun....kapehan din para saU..
dj fel on the mix
