Author Topic: Dell Inspiron N5010 (windows 7 cannot stalled)  (Read 843 times)
Offline sympleguy2u™
  • Pogi/Ganda Points: 12
  • Experience is the best teacher of all time
« on: November 02, 2011, 04:45:50 PM »
Mga sir sino na ba naka-encounter mgrepair ng Dell inspiron N5010 laptop, naboot naman sa installer pero napakatagal, sa sobrang tagal mga 10 mins mgerror na sya, ok nman ang staller ko walang scratch at yun din ang ginagamit ko dati pa, kahit sa ibang windows installer ko ganun din, normal din naman ang init nya. Pa-help naman mga boss. Thanks!
Pag gusto may paraan, pag ayaw maraming dahilan
Online Lola Baciang
  • Pogi/Ganda Points: 134
Re: Dell Inspiron N5010 (windows 7 cannot stalled)
« Reply #1 on: November 02, 2011, 04:54:51 PM »
Sis anong error ang nababasa mo?at os ang iniinstall mo?
Expect The Unexpected
Online Lola Baciang
« Reply #2 on: November 02, 2011, 04:55:15 PM »
Online Lola Baciang
« Reply #3 on: November 02, 2011, 04:56:51 PM »
Sis anong error ang nababasa mo?Pls.indicate complete detail
« Reply #4 on: November 02, 2011, 05:03:59 PM »
Windows 7 po, yung error eh ndi nya naistall ung update and hindi rin maifinalized ung stallation.
Online Lola Baciang
« Reply #5 on: November 02, 2011, 05:11:50 PM »
Lumalabas ba ung'press any key'?
« Reply #6 on: November 02, 2011, 05:18:26 PM »
Hindi po, now try ko uli sya stall windows starting lang sya then dun na sya ngsteady paikut-ikot lang ung bilog nya.
Online Lola Baciang
« Reply #7 on: November 02, 2011, 05:27:51 PM »
try mo cd cleaner muna bka marumi lng ang lens nya,at dapat lumalabas ung PRESS ANY KEY
« Reply #8 on: November 02, 2011, 05:37:37 PM »
Lumalabas po un, matagal po talaga sya mgload/mg-install nw andun n ako sa HDD partition nya still mabagal pa rin.
Online Lola Baciang
« Reply #9 on: November 02, 2011, 06:01:02 PM »
Minsan ginagawa ko defrag ko muna bago ako mag rf para smooth ang booting up
« Reply #10 on: November 02, 2011, 07:07:44 PM »
Sis hindi ko na po mddefrag kasi yung system nadelete/naformat na now mula sa pgboot dun sa windows 7 installer mabagal talaga, pag andun na ako sa mga partition nya then i-format ko na ung partition mabagal din then pgstalling windows component na dun sya mas lalo ngtatagal hanggang sa mg-error na sya, tapos lalabas na ung "windows cannot complete installation. Yun na wala na ako gagawin kundi i-off na sya.
Offline explorer1007
  • Pogi/Ganda Points: 29
« Reply #11 on: November 02, 2011, 07:29:51 PM »
mataas namn specs ng laptop na ito ah. bka nga may problem reading ng disk. try mo kaya install windows 7 gamit usb flash drive.
« Reply #12 on: November 02, 2011, 07:52:16 PM »
Sis mataas nga hindi ko pa nsubukan yung sa flash drive nasa bahay kasi ung installer ko na flash drive, kasi ang una problema eh dun palang sa start up nya mabagal na, ng-try ako safe mode dun pa lang sa pg boot ng safe mode ng-hang pa rin, try ko na i-repair sya gamit ung windows repair kaso pati dun hang pa rin. Kaya ayun naisip ko na i-format na sya hanggang dun un hang pa rin sya. Ppede kaya na harddisk na yun? Ano pa kaya ppede mging cause ng problema na un?
Online Lola Baciang
« Reply #13 on: November 02, 2011, 08:10:51 PM »
  • Pogi/Ganda Points: 413
« Reply #14 on: November 02, 2011, 08:55:49 PM »
Patambay lang.....
Kapag hindi bumilis sa installation sa usb. Malamang marumi ang memory mo. O me tama.  Feeling ko lang.
« Reply #15 on: November 02, 2011, 09:17:34 PM »
Sana nga mgparamdam na rin sa akin, pra mafeel ko na rin kung ano tlga problema! Kaylangan kasi bukas ng boss ko kasi mgbabakasyon daw. Mamaya i-try ko usb format sana nga un lang ang solusyon. Thanks guys.
Online Lola Baciang
« Reply #16 on: November 02, 2011, 09:53:02 PM »
Try mo sis pumasok sa bios under ng exit select mo "laoding default setting"then save
  • Pogi/Ganda Points: 316
« Reply #17 on: November 02, 2011, 10:18:06 PM »
palamigin mo processor,
 try lang :)
« Reply #18 on: November 02, 2011, 11:11:54 PM »
^Baka me topak.
1. Settings sa bios.
2. Magulo ang ayos ng HD
3. Me problema ang memory.
Offline nucleus
« Reply #19 on: November 02, 2011, 11:40:42 PM »
or baka bawal iyan installan ng pirata, naka encounter na kasi ako sa lumang dell inspiron ayaw mainstallan ng pirata
