Author Topic: e-Solution (Electronics Store) distributor of e-Gizmo located at Carmona, Cavite  (Read 1689 times)
  • Pogi/Ganda Points: 53
Actually reseller na rin ako dito sa Laguna pero di pa official since wala pa ako stall. I plan to open up a space in Lucban Quezon to cater both Laguna and Quezon.
Offline macky
  • Pogi/Ganda Points: 51
san ka sa laguna sis?
john 3:16 | oil of gladness
I work in Kalayaan Laguna but I reside in Luisiana. Pwede ako up to Pagsanjan and Sta. Cruz
Offline macky
i see, ang layo pa din from binan...
mas malapit ang carmona, cavite
