Author Topic: Zigbee shield (E-gizmo)  (Read 2178 times)
Offline janno0718
« on: November 23, 2011, 09:33:40 AM »
Pano po ba icoconnect at icconfigure yung zigee shield sa Gizduino. Iba po kasi pala siya sa Xbee shield. Yung nakita ko pong tutorial ng Xbee shield may nakaconnect sa ICSP ata yun. Yung nabili kong zigbee shield wala..... help po. Data lang po itratransmit ko. Data na galing sa LM35. Tapos ididisplay sa LCD ng reciever.
Yung pang 10 po na picture dito.
http://www.e-gizmo.com/pmaster.php?dpage=KIT/categ/gizduino.htm
Re: Zigbee shield (E-gizmo)
« Reply #1 on: November 23, 2011, 10:31:46 AM »
can you provide the datasheet of the module?
ang xbee kasi may ADC pin na... di ako sure sa module mo.
Offline janno0718
« Reply #2 on: November 23, 2011, 11:01:46 AM »
Eto po yung sa Zigbee module
http://i276.photobucket.com/albums/kk10/janno0718/Appearnce.png
eto po yung layout nung shield
http://i276.photobucket.com/albums/kk10/janno0718/Schematic.png
Eto po yung layout ng board
http://i276.photobucket.com/albums/kk10/janno0718/Sc.png
Thanks po sa help. Shield po sya. tanong ko na rin po kung pagkakabit niya sa Gizduino. may gagawin pa ba akong wire connection.?
Offline janno0718
« Reply #3 on: November 23, 2011, 12:12:49 PM »
Pwede ko po bang gamitin yung Arduino Shield ko sa tutorial na to?
http://lab.guilhermemartins.net/2008/12/24/serial-comunication-between-arduinos-with-wire-wireless/
or dito
http://www.electrojoystick.com/tutorial/?page_id=25
Yung gagayahin ko lang po each steps?
« Reply #4 on: November 23, 2011, 12:18:52 PM »
wala nga bang kasamang software ang e-gizmo sa module na to?
ano ba ang manufacturer nung module mismo? dapat yun ang makuhang datasheet/manual. for sure, nandun yung configurations ng module na yan.
Offline janno0718
« Reply #5 on: November 23, 2011, 12:50:24 PM »
Wala pong kasamang software.
Tapos eto po yung data sheet na http://www.4shared.com/document/U2tjmiH0/zigbee_Module.html?
Thansk po sa pag help.
Offline janno0718
« Reply #6 on: November 23, 2011, 09:25:20 PM »
San ko po ba iproprogram yung Zigbee shield na yan? Sa XCTU po ba? Para malaman yung Receiver and Transmitter.. Or sa Arduino IDE na din? Kasama na sa program.
« Reply #7 on: November 23, 2011, 10:31:09 PM »
Base on the datasheet, you will have to set the parameters through serial interface. Siguro sa Terminal program mo ito gagawin.
XTU of digi is just basically a terminal software. So parang ganun na din yun gagawin.
Read the datasheet closely... sufficient na yun.
I just can't give you an actual example kasi honestly di pa ako nakakagamit ng katulad nyang sa e-gizmo.
Offline janno0718
« Reply #8 on: November 23, 2011, 11:43:48 PM »
Ask ko nalang po kung ano yung ibigsabihin niyo sa
"you will have to set the parameters through serial interface."
Na sa program ko na talaga siya i coconfigure? Sa Arduino IDE na talaga?
Offline janno0718
« Reply #9 on: November 24, 2011, 09:58:49 AM »
Sir pwede ko po bang iconfigure tong zigbee shield sa X-CTU??
Eto po sabi sakin nung page sa Facebook na GIzduino
"The Zigbee in E-gizmo communicates via UART. So all you need is study the manual of the module for its commands.I think it is included in the cd that they give .once you know the command, you simply send it via serial from the arduino"
"Im afraid the Zigbee shield that the toturiall employs is one whose already preprogrammed to recieve and transmit pure UART data. kaya serial.print() lang ang ginamit pag send. In e-gizmo's case yould need to transmit not only the data but ALSO SOME HEADERS, CONFIGURATION DATA, CHECKSUM AND THEN THE DATA.yOU THEREFORE NEED TO PROGRAM THE SENDING IN THIS MANNER SO YOU MUST THEREFORE LEARN BY HEART ALL THE REQUIRED COMMAND IN THE MANUAL."
Offline motion55
  • Pogi/Ganda Points: 245
« Reply #10 on: November 24, 2011, 04:09:50 PM »
Kaunting sipag lang ang kailangan, otherwise hindi impossible (very possible) gawin.
My momma always said, "Life was like a box of chocolates. You never know what you're gonna get."
--Forrest Gump
"Set your mind free!"
Offline Born2BeWired
  • Pogi/Ganda Points: 171
    • e-Gizmo Mechatronix Central
« Reply #11 on: November 24, 2011, 06:00:48 PM »
Try the following setup sequence. With the zigbee in command mode:
zigbee slave
1. AT+RESET<CR>
2. wait about 0.5s
3. AT+FLOWCONTROL=0<CR>
4. wait at least 0.1s
additional step for zigbee master only
5. AT+ROLE=0<CR>
Note: <CR> - carriage return
The zigbee pair should now work as wireless UART cable replacement upon exiting the command mode. Di mo na kailangan baguhin yung ibang parameters kung isang zigbee pair lang ang gamit ng system mo. ;)
  • Pogi/Ganda Points: 321
« Reply #12 on: November 24, 2011, 07:41:15 PM »
zigbee slave
1. AT+RESET<CR>
2. wait about 0.5s
5. AT+ROLE=0<CR>
(basag na nga yung zigbee stack, ginawa pang uart cable replacement!)
EDIT: my point is, zigbee has been hacked many times before nang mga white hat (before almost every month). madami sa google na "zigbee hack" so far china no name brand don't have the newer security that got in to zigbee's today. much immune and mature na ang zigbee much like wifi.
Offline janno0718
« Reply #13 on: November 24, 2011, 08:31:07 PM »
zigbee slave
1. AT+RESET<CR>
2. wait about 0.5s
5. AT+ROLE=0<CR>
Saan po itytype yung command na yan? Sa Arduino IDE na po mismo?
« Reply #14 on: November 24, 2011, 11:15:10 PM »
It appears wala sa zigbee ang problem mo. Take one small step at a time. Yung arduino muna ang aralin mo. It is not terribly hard to learn arduino. In fact maraming high school students pa lang gumagamit na nyan.
Once natutunan mo na ang arduino, you will figure out in a matter of minutes kung paano mo magamit yung zigbee with the arduino. Yung analog kasi ng approach mo parang gusto mo matutunan ang calculus bago ang algebra.
Offline janno0718
« Reply #15 on: November 24, 2011, 11:33:02 PM »
Ay sir. Marunong na po ako mag Arduino. Ang mga nagamit ko na po ay. LCD, Buttons, LM35, Stepper Motor, RTC... Tapos yung iba pang kailangan sa project ko at dun sa isa kong kaklase.
Pa tapos na po project ko eh. Bali gumagana na po siya ng hindi wireless. Ang kulang nalang po gawing Wireless.. Kaya paturo naman po.
« Reply #16 on: November 25, 2011, 03:40:11 AM »
it is related on how will you communicate with the zigbee....
so paano nga ba? then pag-alam mo na kung paano magcocommunicate si arduino at si zigbee, malamang alam mo na kung paano gagawin jan...(mababasa mo rin yan sa manual/datasheet yan)
Offline janno0718
« Reply #17 on: November 25, 2011, 07:05:52 AM »
Hahaha.. Ayun nga po sir yung tinatanong ko dito sa forum. Kung pano po sila mag cocommunicate. Hindi ko po alam kung saan ako mag sisimula. xD
« Reply #18 on: November 25, 2011, 09:27:05 AM »
read between the lines...
pero matanong ko lang. have you used your arduino to communicate with your PC? ...like hyperterminal or any terminal software?
Offline motion55
« Reply #19 on: November 25, 2011, 09:53:00 AM »
Balik tayo dito sa tanong mo.
Yes, of course, isasama mo ang pag configure ng Zigbee sa program ng Arduino (Gizduino). You edit the program using the Arduino IDE, compile and download it to the Arduino.
Sa serial interface ng Arduino to the Zigbee ipapadala ang command. Magyayari yan pag pinogram mo si Arduino. I assume marunong ka mag program ng Arduino.
Anung commands i-send ni Arduino kay Zigbee? Ang sagot binigay ni Born2BeWired.
zigbee slave
1. AT+RESET<CR>
2. wait about 0.5s
5. AT+ROLE=0<CR>
And finally follow this advice.
