Author Topic: Zigbee shield (E-gizmo)  (Read 2168 times)
Offline janno0718
Re: Zigbee shield (E-gizmo)
« Reply #20 on: November 25, 2011, 11:13:38 AM »
Balik tayo dito sa tanong mo.
Yes, of course, isasama mo ang pag configure ng Zigbee sa program ng Arduino (Gizduino). You edit the program using the Arduino IDE, compile and download it to the Arduino.
Sa serial interface ng Arduino to the Zigbee ipapadala ang command. Magyayari yan pag pinogram mo si Arduino. I assume marunong ka mag program ng Arduino.
Anung commands i-send ni Arduino kay Zigbee? Ang sagot binigay ni Born2BeWired.
And finally follow this advice.
WoW thanks sir. Mediyo naliliwanagan na ako. Hindi ko po kasi maiisip kung pano ko icconfigure yung zigbee ko eh. Kung pano ko sila iseset ng receiver/Transmitter. Akala ko sa XCTU din.
Pero may tanong pa po ako. San ko po ba ilalagay yung sinabi ni Born2BeWired?
Sa loob po ba ng loop? or sa Setup? Ano po ba yugn serial Interface?
Tapos ano po ba yung wait about 0.5s?
Sensiya na po. nag research din po kasi ako. Pero lahat ng nakikita kong tutorial. Serial.print lang ayos na. Parang yung akin dame pang gagawin
Offline motion55
  • Pogi/Ganda Points: 244
« Reply #21 on: November 25, 2011, 12:18:24 PM »
Once lang kailangan gawin, ayon sa kanya. Pwede gawin sa setup or initialization.
Yan ang connection between the Arduino and the Zigbee. It's a physical connection. Sa program, you can use serial functions to send commands through this physical connection. Eto found using Google... This is the last spoon feed you will get.
http://arduino.cc/en/Reference/serial
Akala ko ba marunong ka na ng Arduino. Sinungaling!
http://www.arduino.cc/en/Reference/delay
Read and understand. Wag maging tamad!
"Set your mind free!"
Offline janno0718
« Reply #22 on: November 29, 2011, 12:02:52 PM »
Sir natesting ko na po yung code. Kaso hindi parin ako makapag send ng data. Pano po bagagawin. Serial.print(...) lang po ba yun? Help please.
Offline janno0718
« Reply #23 on: November 29, 2011, 12:08:29 PM »
Tapos may switch yung zigbee shield. Yung isa po USB nakalagay tapos yung isa walang label. Siguro Power or Zigbee yun.
Ano po ba ang ioon ko dun kapag mag cocompile ng program saka pag itetesting yung device?
« Reply #24 on: November 29, 2011, 12:22:37 PM »
make it sure na may "carriage return" (0x13) ka for every command
Offline janno0718
« Reply #25 on: November 29, 2011, 12:35:43 PM »
Every command po talaga? Pati mga delay or any command talaga?
« Reply #26 on: November 29, 2011, 01:00:13 PM »
kindly review it once again
Try the following setup sequence. With the zigbee in command mode:
zigbee slave
1. AT+RESET<CR>
2. wait about 0.5s
3. AT+FLOWCONTROL=0<CR>
4. wait at least 0.1s
additional step for zigbee master only
5. AT+ROLE=0<CR>
Note: <CR> - carriage return
The zigbee pair should now work as wireless UART cable replacement upon exiting the command mode. Di mo na kailangan baguhin yung ibang parameters kung isang zigbee pair lang ang gamit ng system mo.
ano ba ginawa mo?
Serial.print("AT+RESET<CR>");
or
Serial.print("AT+RESET\r");
or
Serial.print("AT+RESET");
Serial.print("\r");
Offline janno0718
« Reply #27 on: November 29, 2011, 01:04:12 PM »
ano ba ginawa mo?
or
or
Serial.print("\r");
Ay grabe hindi ko po ulit na iintindihan. Ano po ibigsabihin nung Serial.print("AT+RESET<CR>");
Ang ginawa kopo sinulat ko po yung mga code sa void setup. tapos serial.print(data)
Mali po ba yun? kaya siguro hindi nagana. haha
« Reply #28 on: November 29, 2011, 01:51:34 PM »
ay grabe... :D :D :D
ano ba laman ng "data" variable na yan?
try this format;
delay
another command
delay
Offline Born2BeWired
  • Pogi/Ganda Points: 168
    • e-Gizmo Mechatronix Central
« Reply #29 on: November 29, 2011, 02:25:54 PM »
Further reminder:
The new setup is saved on the zigbee NVRAM; you only have to do this once. No further program intervention is necessary after you set it up. Yung ibang user gumagawa ng separate program (sketch) for setup purpose only. You can even do the initial setup using windows hyperterminal software (kailangan nga lang ng RS-232 to logic converter interface).
Offline janno0718
« Reply #30 on: November 29, 2011, 11:52:14 PM »
try this format;
delay
another command
delay
YUng data po ay yung temperature measurement ko na nakukuha ko sa LM35.
Bali pano ko po masesend yung data na yun??
Tapos eto po. Hindi po kaya delikado kapag nagkamali ako ng nakaopen na switch
Offline janno0718
« Reply #31 on: December 02, 2011, 08:18:18 AM »
Question po. Pano po kung 1 master tapos 2 slaves yung akin. Parehong data. Nag sesend sa magkaibang system
« Reply #32 on: December 02, 2011, 09:14:14 AM »
try to make a program to display the temperature reading on PC using your arduino.
kapag nagawa mo na yan, masasagot mo na yang tanong mo.
Offline janno0718
« Reply #33 on: December 02, 2011, 12:15:01 PM »
Yup nagawa ko na po siya ng hindi wireless using serial monitor. Tanong ko po kung pano 1 transmitter 2 reciever
« Reply #34 on: December 30, 2011, 03:09:49 PM »
Up ko lang.
CTX should be low.
ewan ko why...
Offline janno0718
« Reply #35 on: January 10, 2012, 05:42:02 AM »
Sir may problema pa po. Bali napagana ko na po yung dalawang zigbee shield. Meron na pong isang transmitter saka isang reciever. Pero kailangan ko pa po ng isa pang zigbee shield. Ang problema ko po.
Kapag nilalagay ko po yugn bagong zigbee shield sa Gizduino kkung saan nakacompile yung program ng transmiiter/reciever. Hindi po siya nakakapag communicate. Pero kapag binalik ko po yung dati kong shield nakakapag communiciate na po siya
TApos kunwari po yung bagong shield lang po yung nakakabit. Tapos walang ibang shield. Ang ilaw niya po ay GREEN->OFF RED->BLINK (Kung saan eto po ang ilaw kapag nagdedetect ang dalawang shield na dapat na hindi kasi wala naman ibang nakakabit na shield kundi ito lang.). Pero kapag nilagay ko na yung lumang shield dun sa same gizduino. Ang ilaw na po niya ay GREEN->ON RED->BLINK(Kung saan eto po ang ilaw kapag naghahanap ng madedetect pero wala naman madetect which is tama. Kasi kapag kinabit ko po yung isang shield sa isa pang gizduino. madededetect niya po ito. tapos magiging GREEN->OFF RED->BLINK ang ilaw niya.)
Ano po kayang problema? Kakabili ko palang po nung zigbee shield. Sana hindi ko pa naman na sira.
Offline janno0718
« Reply #36 on: January 10, 2012, 05:43:24 AM »
Ang gamit ko palang code ay nandito sa thread na to.
http://www.electronicslab.ph/forum/index.php?topic=30917.0
Offline customer_9
« Reply #37 on: February 03, 2012, 07:01:03 AM »
applicable kaya etong tutorial ng zigbee shield?http://www.youtube.com/watch?v=vKVNmA8C6m8
simple hobbyist
Offline customer_9
« Reply #38 on: February 07, 2012, 09:24:12 PM »
hi sir.
question lang po sa step na eto.
ive been configuring the zigbee shield according to sir abbey of tech is doing his.
ive been shorting the cts and rts then hypertermnial
i am configuring like this
AT
AT+BAUD=9600
AT+PANID=1234
AT role =0 //0 FOR TRANSMITTER AND 1 FOR RECIEVER
at panid 1234
at channel 0
at send mode 2 - KASI 2 ZIGBEE LANG GAGMITIN KO MASTER-SLAVE
AFTER noon ive been downloading this program to each
tintanggal ko po yun shorted ng rts and cts- tama po ba eto?
then move the switch into zigbee from usb
then
program for transciever
void setup()
  Serial.begin(9600);
void loop()
  Serial.print("elab\r\n");
reciever
String str;
void setup()
  Serial.begin(9600);
void loop()
  if(Serial.available()>0)
    str+=Serial.read();
  else{
     Serial.print(str);
sa serial monitor ng transmitter may elab siya prinoprocess kaso sa reciever wala pong marecieve
pa help naman po
simple hobbyist
Offline tambay_9
« Reply #39 on: February 08, 2012, 08:55:12 PM »
thank you to this thread napagana ko na zigbee ko. :D just follow the tips of the masters of this thread and read the manual then yun na:D
config the zigbee sa hyperterminal, then used the serial.print and serial.read from arduino.cc learning area okay na ako.
