Author Topic: Zigbee shield (E-gizmo)  (Read 2171 times)
Offline janno0718
Re: Zigbee shield (E-gizmo)
« Reply #40 on: February 17, 2012, 10:02:19 AM »
thank you to this thread napagana ko na zigbee ko. :D just follow the tips of the masters of this thread and read the manual then yun na:D
config the zigbee sa hyperterminal, then used the serial.print and serial.read from arduino.cc learning area okay na ako.
Ano po zigbee mo? Zigbee module? Or yung zigbee shield?
Offline tambay_9
« Reply #41 on: February 17, 2012, 11:06:21 AM »
shield po
Offline janno0718
« Reply #42 on: February 17, 2012, 02:18:06 PM »
Pano po ginawa mo. Kung pano na configure?
Kasi po napagana ko na po yung dalawa kong shield. 1 reciever 1 transmitter
Kaso kailangan ko pa po ng isa. Di ko po maconfigure. Kailangan ko po kasi 1 transmitter 2 reciever.
Kapag pinapalitan ko ng bagong shield yung shield sa naganang reciever. Di na po siya nakakareciever, pero nadedetect niya na may transmtter. Tapos kapag binalik ko yugn lumang shield dun sa gizduino. Guamgana na po ulit ssiya. Tiannong ko po sa Gizmo. Sabi kailangan ko daw po ipair yung shield sa bluetooth something. PAno po gagawin yun?
Offline tambay_9
« Reply #43 on: February 17, 2012, 03:07:00 PM »
do u have a usb to serial/tll from e-gizmo? if yes it will be easy to configure. the other 1.
Offline janno0718
« Reply #44 on: February 17, 2012, 08:52:16 PM »
May mahihiraman po ako. pano po ba gagawin ko?
Pwede po ba yung sa hindi PC interface na design?
May isa pa po akong problema. Nagloko po yung isa kong shield.
Naka hold ON lang po yung green tapos di nag bliblink red. Ano po kaya problema nun :(
Offline janno0718
« Reply #45 on: February 25, 2012, 04:47:42 PM »
Nakabili na po ako ng USB to serial. Pano po connection nun sa zigbee shield? RX/ TX saka ano po?
Offline tambay_9
« Reply #46 on: February 26, 2012, 06:14:41 AM »
anu yan? yun may external power or uyun power from usb na?
kung yan yun may external power
converter --------serial
rx----rx
tx---tx
gnd--gnd
kung yan yun sa usb na rin kumukuha ng power supply
rx-tx
tx-rx
gnd-gnd
Offline janno0718
« Reply #47 on: February 26, 2012, 07:41:13 AM »
HELP po. Kapag nag eenter po ako ng command. Walang respond. Kunwari po AT. space lang po nakikita ko...
Offline tambay_9
« Reply #48 on: February 26, 2012, 08:45:40 AM »
remove the mode jumper
Offline janno0718
« Reply #49 on: February 26, 2012, 08:49:18 AM »
Wala po talagang lumalabas na respose. Ano po kaya mali ko?
Connections ko
Shield --- USB to serial
RX --- TX
TX --- RX
GND --- GND
5v --- 5v
GND --- GND
Ang lumalabas po sa hyper terminal
Example
AT
AT+BAUD=9600
Ayan po. Space lang po response
Bali kapag tinatype ko po. Tinatanggal ko po yung jumper sa mode. Tapos naka short yung CTS saka RTS. ANo po kaya mali?
Offline janno0718
« Reply #50 on: February 26, 2012, 09:06:41 AM »
Offline tambay_9
« Reply #51 on: February 26, 2012, 12:42:48 PM »
bkt ngakadisconnect? call mo. click the phone button
Offline janno0718
« Reply #52 on: February 26, 2012, 12:51:55 PM »
Sir napagana ko na po yung 1 is to 1. Pero kailangan ko po 1 is to 2.
Kaso di na po makasali sa pairing yung isa ko. Pano po gagawin ko? Sendmode 0 po tapos flowcontrol 1. Tama po ba kapag 1 is to 2?
