Author Topic: help: serial communication with PIC16F877A  (Read 516 times)
Offline Nhicko
« on: November 23, 2011, 11:49:28 PM »
Picture 1:
Picture 2:
ginaya ko po ung connection sa picture 1 tapos nagtry ako nung sample program sa mikroC about UART kasi nga gusto kung matuto ng serial communication gamit ay pic16f877a ok naman ung pag build na burn ko na rin sa pic ko kaso nung ginamit ko ung usart terminal para icheck ayun ung lumabas sa picture 2. nung nag send ako ng 'a' walang lumabas na received kung anu-anong leters na ang sinend ko walang narereceived ung Usart terminal. diba dapat kapag nagsend ako ng 'a' dapat may a den lalabas.
Bale ganito dapat ung format:
Sent: a
Received: a
yan yung gus2 kong mangyare pero bat ayaw.
tska pasinin nio ung dalawang Received sa picture 2 ung nasa usart terminal after mareceived ung word na "Start" nagkaroon pa ng garbage value tapos hiwalay pa ung 'S' sa "tart". Pahelp naman kelangan ko kasing matuto actually may gui pa dapat yan sa C# kaso eto muna ung inaaral ko.
Offline PlCUSER
  • Pogi/Ganda Points: 152
Re: help: serial communication with PIC16F877A
« Reply #1 on: November 24, 2011, 12:12:03 AM »
palitan mo ung "chuva" na folder name mo. baka sakaling gumana.  :D :D :D
Offline Nhicko
« Reply #2 on: November 24, 2011, 02:19:11 AM »
"picuser" pinalitan ko na ganun pa ren talaga.
Offline Nhicko
« Reply #3 on: November 24, 2011, 02:21:28 AM »
nga pala 16MHz ang crystal na gamet ko.---------------> for additional info sa problem ko
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #4 on: November 24, 2011, 06:11:32 AM »
TS please paki show naman ng schematic sa entire setup ng hardware mo pati na yung power supply. Salamat.
Offline Nhicko
« Reply #5 on: November 24, 2011, 11:04:16 PM »
Power supply:
Whole ckt:
Offline Nhicko
« Reply #6 on: November 24, 2011, 11:13:40 PM »
yan po tapos tinatry ko ung code sa picture 2.
additional info: 16MHZ crystal, USB-to-serial gamet kong cable from PIC16F877A to computer laptop po kasi gamet ko eh wala siang serial port
Offline Engr. Dacuycoy
  • Pogi/Ganda Points: 161
  • Proton Orcad EasyPCB User
« Reply #7 on: November 25, 2011, 12:00:03 AM »
be sure na tama ang rx tx connection
pic                     pc
rx ---------------tx
tx----------------rx
gnd---------------gnd
Offline dummy_c
« Reply #8 on: November 25, 2011, 12:05:26 AM »
Put a .1uF across the VDD and VSS pins as near as possible sa PIC po.
By the way hindi ba ito naka bread board sir?
Offline Nhicko
« Reply #9 on: November 25, 2011, 09:46:56 AM »
naka breadboard po. Bale papalitan ko ung 104 na capacitor ng .1uF, so dalawang ganun. tama bo ba sir?
Offline dummy_c
« Reply #10 on: November 25, 2011, 10:00:34 AM »
^ Huwag lang palitan, 104=.1uC, ilagay lang as close as possible sa PIC mo sir.
Naka breadboard pala, most probably yan po ang dahilan. Baka meron mga loose contacts or may noise sa RX/TX line mo sir.
I know these is a dumb question, but matanong lang po, may suppy ba ang max232 mo sir?
Offline SpongeBob
  • Pogi/Ganda Points: 33
« Reply #11 on: November 25, 2011, 10:04:45 AM »
104 at 0.1uF pareho lang yun. lagyan mo sa VDD at VSS ng PIC at MAX, dagdagan mo na rin ng 100uF sa 5VDC.
Offline Nhicko
« Reply #12 on: November 25, 2011, 10:33:19 AM »
pic                     pc
sir mukhang tama nga kayo. nagawa ko na tama po keo! hay nako natanga nanaman ako. TY po TY rin po ser dummy_c
Offline Nhicko
« Reply #13 on: November 25, 2011, 10:34:44 AM »
wala nga po kanina hehehehehe....
Offline Nhicko
« Reply #14 on: November 25, 2011, 10:35:36 AM »
sorry po sa istorbo hehehehehe... pero ty pa ren
« Reply #15 on: November 25, 2011, 10:38:28 AM »
musta na? ok na ba?
Offline Nhicko
« Reply #16 on: November 25, 2011, 10:48:14 AM »
Offline dummy_c
« Reply #17 on: November 25, 2011, 12:17:27 PM »
Kulang lang ng supply?
Ahahahaha may +1 ka sa akin TS pinatawa mo ako. ;D
Na remember ko nangyari din ito noon. Nagpatulong yung classmate ko, halos isang oras tini troubleshoot namin, I assumed may supply na yung max232, yun pala wala. ;D
Offline nucleus
« Reply #18 on: November 25, 2011, 12:24:55 PM »
supply nga ang problema, baligtad yung input at output ng 7805 sa schematic eh ;D ;D ;D
« Reply #19 on: November 25, 2011, 12:27:40 PM »
paatras. wahehehehe
