Author Topic: signal booster  (Read 2215 times)
Offline wakei
Re: signal booster
« Reply #40 on: January 18, 2012, 10:18:34 AM »
ah..so pwede po pala gawin ung signal booster kahit 2 antenna lang at walang diplexer?.cool
Re: signal booster
  • Pogi/Ganda Points: 635
Re: signal booster
« Reply #41 on: January 18, 2012, 01:39:02 PM »
theoretically, yes.
Re: signal booster
Offline wakei
Re: signal booster
« Reply #42 on: January 24, 2012, 08:03:42 PM »
even without the LNA? is it still possible? using 2 antennas and a power amp circuit is enough?
Re: signal booster
Re: signal booster
« Reply #43 on: January 24, 2012, 09:33:12 PM »
hmmm. most probably, malaki ang signal deterioration niya. typically ang mga Power Amp ay mataas ang Noise Figure kaya kailangan parating may LNA.
Re: signal booster
  • Pogi/Ganda Points: 321
Re: signal booster
« Reply #44 on: January 24, 2012, 09:43:09 PM »
baka pwede na dalawang attenna na lang without the power amp since mataas ang noise figure nya.
parang parabolic mirror na lang. at lease lahat passive.
Re: signal booster
Offline wakei
Re: signal booster
« Reply #45 on: January 24, 2012, 09:53:16 PM »
@insomartin, yan nga po iniisip ko e.pero dapat kahit papano may cicruit..gusto namin subukan na walang ung LNA since 8 days pa ung ic nya..though gawa na ung power amp..antenna nalang ung kulang para maitesting.medyo sigurista lang po kasi kami e.haha..ang amin po kasi e basta maiboost namin ung signal ok na.
Re: signal booster
« Reply #46 on: January 24, 2012, 10:18:43 PM »
pwede niyo namang subukan.
Re: signal booster
« Reply #47 on: January 24, 2012, 10:47:57 PM »
BTW, kabilaan merong Power Amp? tapos wala kayong Diplexer or Filter? kung ganyan, malamang magkaroon kayo ng oscillation, effectively jamming the link.
Offline wakei
Re: signal booster
« Reply #48 on: January 26, 2012, 02:44:35 AM »
ang balak po namin subukan is antenna->p.amp->antenna ganyan lang po..kung hindi po ako nag kakamali may bandpass filter na po ung p.amp since ung p.amp e may ic siya na may bandpass filter na po sa specs..kung wala po ung LNA magkakaproblema po pag tuamwag since baka puro noise nalang marinig.pero kung sa text po ba di naman ito affected?
Re: signal booster
« Reply #49 on: January 26, 2012, 01:18:18 PM »
GSM is digital, clear pa rin ang boses mo kung tatagos, though, choppy kung may problem sa signal. 'yung text, mas madaling nakakatagos sa problem areas.
post the datasheet nung power amp para makita natin.
Offline wakei
Re: signal booster
« Reply #50 on: January 26, 2012, 08:32:51 PM »
sige po.haha..asa kagroup ko po e.so baka bukas po ipost ko.
naitry na po namin ung project sa school kung saan e 1 bar lang ung signal..pinwesto na din namin dun ung antenna sa may 1 bar signal na area..di kasi pala abot ung 4m na cable sa may malakas na signal para maipwesto pa ng maayos yung antenna..so ung sinubukan namin e yagi->p.amp->dipole antenna lang..then ung 1 bar e naging 3 bars after ng ilang segundo..may nag kataon pa na nagfull bar siya ngunit saglit lang.susubukan ko sana mag text pero nasira ung ic.nagshort lahat  kaya gagawa nalang ulit kami bukas.
sa tingin nyo po ba since yan lang ung buong circuit or components na gagamitin namin makakapag text po o tawag po ba kami?kasi ang iniisip ko makakatanggap kami ng text pero hindi kami makakareceive.
isa pa pong iniisip ko e kung transceiver na po ba agad ung yagi at ung dipole na gamit namin..di po kasi masyadong itinackle ung mga antenna sa amin.puro pag compute lang ng free space loss kadalasan para sa microwave link designing..na gets ko po kasi ung sinabi nyo na magcacancel out nga naman ung signal kung maglalagay kami ng isa pang pabalik e.
Offline wakei
Re: signal booster
« Reply #51 on: January 27, 2012, 10:22:10 PM »
http://painkillers.narod.ru/usil/pf08109b.pdf
yan po ung datasheet. di po ako marunong maglink e.
Re: signal booster
« Reply #52 on: January 27, 2012, 10:31:51 PM »
kung iche-check niyo 'yung graphs, hindi siya band filtered sa GSM bands lang (Uplink 880MHz - 915MHz), naa-amplify niya pa rin 'yung sa paligid, though, mas ok ang matching niya doon sa area nung mismong band.
Offline wakei
Re: signal booster
« Reply #53 on: January 29, 2012, 07:13:37 PM »
hindi gumana ung smart..at nasira ulit ung ic namin.wew..mukhang maiinc kami e.haha..hindi ata 900mhz ung bandwidth nung smart sa pinagtestingan namin
Re: signal booster
« Reply #54 on: January 29, 2012, 11:06:41 PM »
maliit lang ang band ng Smart sa GSM900. mas marami silang band sa GSM1800.
Offline wakei
Re: signal booster
« Reply #55 on: January 30, 2012, 07:55:49 PM »
waaaaaa!yun lang.hahaha!..sir baka meron po pala kaung site na maibigay para sa tutorial ng pag gawa ng antenna.ung nakita kasi namin e.isang frequency lang ung tinuturong design hindi ung buong bandwidth..ala po din po kasi kaming makitang 1800mhz na antenna
Re: signal booster
« Reply #56 on: January 30, 2012, 09:31:45 PM »
search mo 'yung book na Broadband Planar Antennas. pero kung gusto niyo ng easy way at walang masyadong hassle, mag-design na lang kayo ng Lod-Periodic Antenna.
Offline wakei
Re: signal booster
« Reply #57 on: February 25, 2012, 11:04:43 AM »
mga sir,maam, thank you po ng marami.ok na po ung project namin naipasa na..un nga lang kulang pa daw sa testing..since hindi kasi nakapag amplify ng signal sa school.though may naipakita na kaming video kung saan inamplify ung signal sa ibang lugar..gusto talaga nila sa school gumana e..magdadag dag nalang kami ng transmission line para hindi mareceive nung yagi antenna ung frequency na inamplify na para hindi mag cancel out ung frequency..
thank you po.
Re: signal booster
« Reply #58 on: February 25, 2012, 11:15:37 AM »
mukhang isolation ang problem niyo, kung ganyan kasi, dapat at least 20m para minimal ang interference nung amplified sa original, bawas oscillation.
Offline wakei
Re: signal booster
« Reply #59 on: March 04, 2012, 09:30:38 PM »
yup..bali naging 20m nga po ung cable namin buti pareho lang ung impedance nung mga cable...thank you po ng marami..pinapafinalize nalang po ung papers.thank you
Re: signal booster
