Author Topic: SANYO MODEL ST-14SA1 3 Seconds STANDBY  (Read 2721 times)
  • Pogi/Ganda Points: 316
Re: SANYO MODEL ST-14SA1 3 Seconds STANDBY
« Reply #100 on: April 18, 2012, 07:01:19 PM »
cge salamat ulit sis pete ;D +1
try ko mamaya...
« Reply #101 on: April 18, 2012, 07:43:45 PM »
nakakatakot ung unit.
sumisexy kapg mag dark view/area
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #102 on: April 18, 2012, 09:36:57 PM »
kala ko ok na sis? uoc mo na search mo na datasheet(pincushion ckt) and vertical ic ok ba, di b masyado mainit?
« Reply #103 on: April 18, 2012, 09:52:48 PM »
dem di ko alam . kakaayos nung isa, meron na nman ;D nanganganak.
Offline BhongTech
  • Pogi/Ganda Points: 152
« Reply #104 on: April 18, 2012, 10:20:25 PM »
parang kinakapos yan sir.bakit parang may mga light gray na bar akong nakikita?
check mo rin ang abl circuit.
« Reply #105 on: April 18, 2012, 10:32:12 PM »
light grey bar - sa camera lang yan sir.
Offline mcleod
« Reply #106 on: April 19, 2012, 08:37:23 AM »
bat sis kasi halos 1/4 lang ng tv mo pinapakita mo sa amin? may x ba dyan?
« Reply #107 on: April 19, 2012, 10:45:22 AM »
di kasi klaro kung whole.
« Reply #108 on: April 19, 2012, 03:56:45 PM »
btw matanong ko lang. sabi sa mapa. 130 ung B+ nito.
current B+ ko naman ay 113. may nakita akong trimmer na pdeng i adjust ung B+.
pde din iba na ito ung dahilan ng pin cushion?
Offline mcleod
« Reply #109 on: April 19, 2012, 04:43:09 PM »
sis malamang damper diode or resistor hinahanap mo near sa area ng fbt wag din isnabin mga caps diyan.
pag wala malamang nasa HOT built-in pero may case na ako solved sa sony resistor. ecaps din dyan near HOT and FBT pede sablay.  ;D ;D ;D
Offline mcleod
« Reply #110 on: April 19, 2012, 05:03:10 PM »
forget ko part din ng pincushion circuit yung mga inductor / coil mo baka may shorted na.
Offline Min
  • Pogi/Ganda Points: 202
« Reply #111 on: April 19, 2012, 05:22:49 PM »
Ryu, mababa ang 113v kung 130v ang naka indicate sa mapa. Pag ganyan kababa ang supply pwede bumaluktot ang raster sa gilid. Try mo muna i correct ung tamang B+ nya.
  • Pogi/Ganda Points: 411
« Reply #112 on: April 19, 2012, 06:52:39 PM »
subs lang muna.
  • Pogi/Ganda Points: 771
« Reply #113 on: April 19, 2012, 07:23:46 PM »
normal b+ yan 108 to 115
« Reply #114 on: April 19, 2012, 07:38:24 PM »
built in ung diode nito...
hahay hanap naman nito ;D
Offline mcleod
« Reply #115 on: April 20, 2012, 12:12:05 PM »
parang di ka rin naniniwala sis? google mo s-correction and e/w correction para lubos mo maunawaan ang tv deflection circuit.
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #116 on: April 20, 2012, 01:46:13 PM »
ang sipag ni sis mecleod ahhh.. ;D ;D ;D
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
Offline mcleod
« Reply #117 on: April 20, 2012, 02:45:36 PM »
kelangan mas knowlegeable kasi jujudge ako na nakakahiya. humahawak ng tao, kelangan mas magaling ka sa tao mo. saka gender bias. wag mo na baguhin surname ko di pa ako married.
« Reply #118 on: April 23, 2012, 09:36:02 PM »
kakasibak lang ng HOT. 2SD2634. bibili ako bukas.
nid ko mga replacements, mahirap ung pabalik balik.
« Reply #119 on: April 23, 2012, 11:21:17 PM »
wow hot na ang sinibak.
