Author Topic: PIC+ENC28J60 Ethernet Development module  (Read 1258 times)
« on: December 01, 2011, 10:25:53 PM »
I recommended this to my friends... di nila mapawork! kahit yung http server demo stack...
kaya bumalik sa akin at pinatest din saakin. ;D ;D ;D
sa unang tingin madali lang, pero di ko din napawork. at umiinit yung encore mismo (medyo pinagdududahan ko ito).
Anyone tips or tricks na masasuggest ninyo?
Bale ang binago ko lang ay yung default IP addresses na ayon sa aking router/switch.
instead of the default 169.254.1.1 ginawa kong 192.168.0.33
pinalitan ko din yung subnet na naaayon din. 255.255.255.0
success yung build at loading ng program, pero ayaw talaga. di ko nga maPing.
Baka may fresh stack kayo dyan na galing sa CD, pahingi na din.. baka may nagalaw ako na di naman dapat.
Offline PlCUSER
  • Pogi/Ganda Points: 153
Re: PIC+ENC28J60 Ethernet Development module
« Reply #1 on: December 01, 2011, 10:33:38 PM »
ano po ung encore? encore router?
Online insomartin
« Reply #2 on: December 01, 2011, 10:34:07 PM »
^ i concur... router nga ba?
« Reply #3 on: December 01, 2011, 10:42:09 PM »
Im sorry... yung ENC28J60 mismo.
Something wrong with me tonight! hehehe ;D
Offline tiktak
  • Pogi/Ganda Points: 203
    • Tiktakx's Blog
« Reply #4 on: December 01, 2011, 10:45:11 PM »
try mo i load itong galing sa olimex
 http://www.olimex.com/dev/index.html
dyan binase yang mini webserver :D
8051 stuff
« Reply #5 on: December 01, 2011, 11:33:52 PM »
pahiram ng module :D iloload ko program ko :D(poport ko pala muna)
« Reply #6 on: December 02, 2011, 09:10:04 AM »
Salamat sis...
pero ayaw talaga... hehehe ;D
hopefully di ito hardware issue.
Offline PlCUSER
« Reply #7 on: December 02, 2011, 09:20:06 AM »
Ung ENC chip, mainit talaga. Kahit na walang activity. May heating element ata sa loob. Hehehe
« Reply #8 on: December 02, 2011, 09:49:17 AM »
salamat sa info... virgin pa ako sa ENC chip. ;D
still digging...
« Reply #9 on: December 04, 2011, 09:37:48 PM »
AFAIK, havent experienced this yet..
tried na din na iburn test dati yung gawa ko for 3-4 days,,, hindi naman... hmmmm parang ang sarap balikan :D hehee
Offline PlCUSER
« Reply #10 on: December 04, 2011, 11:52:24 PM »
posible nga. mas laki kasi body ng DIP pak, compared sa ssop at qfn. ;D ;D ;D
« Reply #11 on: December 04, 2011, 11:59:46 PM »
oo nga pala :D yung gamit ko ring pangtest board is SOIC, pero masmalaki pa rin :D hehe
« Reply #12 on: February 13, 2012, 07:30:07 PM »
May bago akong tanong... :D
bakit di ko magawang 192.168.0.X ang network ko?
(di magwork sa 192.169.0.X pero nagwowowrk sa default which is 169.254.0.x)
Di ba ang pagbabago ng IP addressing ay dun lamang sa TCPIPConfig.h?
May kailangan pa bang baguhin aside dun?
Online insomartin
« Reply #13 on: February 13, 2012, 07:46:19 PM »
sira na po yan.  ;D ;D ;D
« Reply #14 on: February 13, 2012, 07:51:50 PM »
di pa nga sumasabog! heheh ;D
Offline PlCUSER
« Reply #15 on: February 13, 2012, 08:20:16 PM »
« Reply #16 on: February 13, 2012, 08:45:36 PM »
sumabog sana hehe ;D
« Reply #17 on: February 13, 2012, 09:13:23 PM »
[code]
        #define MY_DEFAULT_HOST_NAME "MyEthernet"
#define MY_DEFAULT_MAC_BYTE1            (0x00) // Use the default of
#define MY_DEFAULT_MAC_BYTE2            (0x04) // 00-04-A3-00-00-00 if using
#define MY_DEFAULT_MAC_BYTE3            (0xA3) // an ENCX24J600 or MRF24WB0M
#define MY_DEFAULT_MAC_BYTE4            (0x00) // and wish to use the internal
#define MY_DEFAULT_MAC_BYTE5            (0x00) // factory programmed MAC
#define MY_DEFAULT_MAC_BYTE6            (0x00) // address instead.
#define MY_DEFAULT_IP_ADDR_BYTE1        (192ul)
#define MY_DEFAULT_IP_ADDR_BYTE2        (168ul)
#define MY_DEFAULT_IP_ADDR_BYTE3        (1ul)
#define MY_DEFAULT_IP_ADDR_BYTE4        (254ul)
#define MY_DEFAULT_MASK_BYTE1           (255ul)
#define MY_DEFAULT_MASK_BYTE2           (255ul)
#define MY_DEFAULT_MASK_BYTE3           (255ul)
#define MY_DEFAULT_MASK_BYTE4           (0ul)
#define MY_DEFAULT_GATE_BYTE1           (192ul)
#define MY_DEFAULT_GATE_BYTE2           (168ul)
#define MY_DEFAULT_GATE_BYTE3           (1ul)
#define MY_DEFAULT_GATE_BYTE4           (254ul)
#define MY_DEFAULT_PRIMARY_DNS_BYTE1 (192ul)
#define MY_DEFAULT_PRIMARY_DNS_BYTE2 (168ul)
#define MY_DEFAULT_PRIMARY_DNS_BYTE3 (1ul)
#define MY_DEFAULT_PRIMARY_DNS_BYTE4 (254ul)
#define MY_DEFAULT_SECONDARY_DNS_BYTE1 (0ul)
#define MY_DEFAULT_SECONDARY_DNS_BYTE2 (0ul)
#define MY_DEFAULT_SECONDARY_DNS_BYTE3 (0ul)
#define MY_DEFAULT_SECONDARY_DNS_BYTE4 (0ul)
from TCPIPConfig.h
       memcpypgm2ram((void*)&AppConfig.MyMACAddr, (ROM void*)SerializedMACAddress, sizeof(AppConfig.MyMACAddr));
AppConfig.MyIPAddr.Val = MY_DEFAULT_IP_ADDR_BYTE1 | MY_DEFAULT_IP_ADDR_BYTE2<<8ul | MY_DEFAULT_IP_ADDR_BYTE3<<16ul | MY_DEFAULT_IP_ADDR_BYTE4<<24ul;
AppConfig.DefaultIPAddr.Val = AppConfig.MyIPAddr.Val;
AppConfig.MyMask.Val = MY_DEFAULT_MASK_BYTE1 | MY_DEFAULT_MASK_BYTE2<<8ul | MY_DEFAULT_MASK_BYTE3<<16ul | MY_DEFAULT_MASK_BYTE4<<24ul;
AppConfig.DefaultMask.Val = AppConfig.MyMask.Val;
AppConfig.MyGateway.Val = MY_DEFAULT_GATE_BYTE1 | MY_DEFAULT_GATE_BYTE2<<8ul | MY_DEFAULT_GATE_BYTE3<<16ul | MY_DEFAULT_GATE_BYTE4<<24ul;
AppConfig.PrimaryDNSServer.Val = MY_DEFAULT_PRIMARY_DNS_BYTE1 | MY_DEFAULT_PRIMARY_DNS_BYTE2<<8ul  | MY_DEFAULT_PRIMARY_DNS_BYTE3<<16ul  | MY_DEFAULT_PRIMARY_DNS_BYTE4<<24ul;
AppConfig.SecondaryDNSServer.Val = MY_DEFAULT_SECONDARY_DNS_BYTE1 | MY_DEFAULT_SECONDARY_DNS_BYTE2<<8ul  | MY_DEFAULT_SECONDARY_DNS_BYTE3<<16ul  | MY_DEFAULT_SECONDARY_DNS_BYTE4<<24ul;
My initialization sa EthernetConfig() ko=) [/code]
« Reply #18 on: February 14, 2012, 01:48:53 PM »
;D ;D ;D
[code]
from TCPIPConfig.h
ayan, nagwork na! ngayong araw pinalitan ko lang... ayun nagwork. pero parang perahas lang yung ginawa ko kahapon. hehehe;D
namamaligno yata ako.
« Reply #19 on: February 14, 2012, 04:50:00 PM »
sira na nga yan :D donate mo na lang saken :D
