Author Topic: CLIP,SIGNAL,POWER indacator (Apex)  (Read 2240 times)
Offline Skyjham
  • Pogi/Ganda Points: 155
Re: CLIP,SIGNAL,POWER indacator (Apex)
« Reply #20 on: December 11, 2011, 07:24:53 PM »
ok to sir a,speaker protect nalang ang kulang, cge gawa ako ng speaker protect
Learning is un-ending process
  • Pogi/Ganda Points: 324
« Reply #21 on: December 18, 2011, 10:32:35 PM »
implant ko to sa class D ;D
Online 01110011
  • Pogi/Ganda Points: 101
« Reply #22 on: June 05, 2012, 02:02:10 PM »
paki buhay ;D pwede ba BC549 instead instead of BC550?
http://www.nxp.com/documents/data_sheet/BC549_550.pdf
Offline flyback
  • Pogi/Ganda Points: 62
« Reply #23 on: June 08, 2012, 08:20:38 PM »
yes make sure yung pin tama pagkalagay
Knowing GOD is not being good,Knowing GOD is just knowing him as my friend
Online 01110011
« Reply #24 on: June 08, 2012, 09:20:49 PM »
as of datasheet, they have the same pinouts
anyway thanks sir :)
Offline jeproks
  • Pogi/Ganda Points: 7
  • hello to all elabers!
« Reply #25 on: June 08, 2012, 10:08:54 PM »
subs waiting mode sa speaker protect ty
Online 01110011
« Reply #26 on: June 08, 2012, 10:23:46 PM »
sis skyjham already made one with speaker protect :)
Offline BABY AMPLI
  • Pogi/Ganda Points: 56
  • it is my life and i live it how i want
« Reply #27 on: June 20, 2012, 12:34:21 AM »
mga sis patulong nman po panu po i apply yung circuit ng clip signal indicator  newbie lang po ako patulong nman po
before you judge me..make sure that you are perfect
Offline 1022jv
  • Pogi/Ganda Points: 25
« Reply #28 on: August 31, 2012, 09:15:30 AM »
  This ckt is intended for amps with V+ and V- supply.    Yung V+ sa clip,signal and indicator circuit sa V+ supply ng amp mo iconnect yung out dun mo iconnect sa output ng amp at ground sa ground connection ng amp.  Na try ko na to at ok cya.
Offline BABY AMPLI
« Reply #29 on: August 31, 2012, 10:37:16 AM »
tnx po sir +1 po sayo..
Offline Deantyne
  • Pogi/Ganda Points: 94
  • Focus my friend...
« Reply #30 on: August 31, 2012, 11:08:48 AM »
sub muna..
BACK TO BASICS
Offline jaguar3275
  • Pogi/Ganda Points: 132
  • BAKLA LANG ANG MAGTAMPO AT MAG EMOT2X!!!
« Reply #31 on: August 31, 2012, 11:13:20 AM »
anu po ba ibig sabihin kung iilaw ang signal led at hindi iilaw?
Exodus 15:2 The LORD is my strength and my song, and he has become my salvation; this is my God, and I will praise him, my father’s God, and I will exalt him.
Offline 1022jv
« Reply #32 on: August 31, 2012, 11:49:15 AM »
 Yung signal led iilaw talaga yan if the if there is enough output signal and turns off if output signal is low, so kapag di umiilaw yung led kahit na increased na yung volume it means walang signal sa output.  You also can try finding the clipping point of your amp by increasing the volume  the amp hangang umilaw yung clip indicator para malaman mo kung gaano kalakas yung amp.   I alrady tried this in my amps.
Offline ™(◣◢)™
  • Pogi/Ganda Points: 14
  • Enjoy Life ;)
« Reply #33 on: August 31, 2012, 11:53:48 AM »
kung umiilaw meaning may signal na galing sa amp,
kung hindi either mahina yung source or may problema sa amp
Not Everything that counts can be counted And Not Everything that can be counted counts.
Author?
Offline 1022jv
« Reply #34 on: August 31, 2012, 12:29:50 PM »
yan mas better yung sagot nya.
Offline BABY AMPLI
« Reply #35 on: August 31, 2012, 12:46:27 PM »
mga sis tanung lang po anu po bang dinedetect nung clip indicator?bakit po sya nagcliclip..
ex. dc offset, overload or ????
Offline jaguar3275
« Reply #36 on: August 31, 2012, 01:09:12 PM »
thanks sis ™(◣◢)™ at 1022jv +1 kayo
Offline 1022jv
« Reply #37 on: August 31, 2012, 03:53:46 PM »
   Yung voltage sa output signal sir.    Kapag yung output signal is equal to reference voltage(yung V+) umiilaw yung clip led at maximum na yung output voltage
Offline louiex
« Reply #38 on: October 14, 2012, 04:25:25 PM »
"I think resistor value should be changed to different wattage ng amp na gagamitin.."
alin po sir  yong 6.8k or yong 47k?
Offline rovericks
  • Pogi/Ganda Points: 314
  • I SHALL RETURN
« Reply #39 on: January 19, 2013, 05:11:21 PM »
pwede kaya to sa 92vdc na rails? my mods ba na gagawin?
Think before you speak, don't jump to conclusions, i-analyze muna bago mag conclude..
