Author Topic: request po sana nang codes..  (Read 197 times)
Offline ewan1921
« on: December 05, 2011, 12:34:45 AM »
hello po mga idol..
pwede pong humingi nang codes para sa led project like led flasher or running lights para po mapagaralan.. assembly po sana.. 16f84a or 877a po ang gagamitin..
pasensya na po baguhan pa lang po tlaga ako sa programming.. salamat po nang marami...
Offline NanotecH
Re: request po sana nang codes..
« Reply #1 on: December 05, 2011, 01:43:34 AM »
google mo lang marami dyan....
gusto mo naman punta ka dito samin sa bacoor, pag-aralan mo mga nasa libro ko...turuan pa kita... ;D
220V/10A input = 220V/30A output...Fact or Fiction?  Myth or Reality?
One word is enough for a wise man.
"Never tell the truth to people who are not worthy of it." - Mark Twain
Offline SpongeBob
  • Pogi/Ganda Points: 33
« Reply #2 on: December 05, 2011, 09:15:51 AM »
Marami nga yan sa net, ito nakita ko
Code: [Select]
title  "asmPKLED - PICkit Running LED"
;  This program copies the function of cPKLED.c and Flashes the 8 LEDs
;   on the PICkit 1 PCB in Sequence.
;  Hardware Notes:
;   PIC16F684 running at 4 MHz Using the Internal Clock
;   External Reset is Used
;   Circuit Runs on PICkit 1 PCB
;  LED Defines:
 #define D0Anode   PORTA, 4
 #define D0Cathode PORTA, 5
 #define D1Anode   PORTA, 5
 #define D1Cathode PORTA, 4
 #define D2Anode   PORTA, 4
 #define D2Cathode PORTA, 2
 #define D3Anode   PORTA, 2
 #define D3Cathode PORTA, 4
 #define D4Anode   PORTA, 5
 #define D4Cathode PORTA, 2
 #define D5Anode   PORTA, 2
 #define D5Cathode PORTA, 5
 #define D6Anode   PORTA, 2
 #define D6Cathode PORTA, 1
 #define D7Anode   PORTA, 1
 #define D7Cathode PORTA, 2
;  Myke Predko
;  04.10.04
  LIST R=DEC
 INCLUDE "p16f684.inc"
 __CONFIG _FCMEN_OFF & _IESO_OFF & _BOD_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTOSCIO
;  Variables
 CBLOCK 0x020
Dlay
ActiveBit                       ;  Record the Active Bit
 ENDC
  PAGE
;  Mainline
 org     0
  nop                           ;  For ICD Debug
  clrf    PORTA                 ;  Initialize I/O Bits to Off
  movlw   7                     ;  Turn off Comparators
  movwf   CMCON0
  bsf     STATUS, RP0
  clrf    ANSEL ^ 0x080         ;  All Bits are Digital
  bcf     STATUS, RP0
  clrf    ActiveBit             ;  Start with D0
Loop:                           ;  Return Here after Delay and RB0 Toggle
  incf    ActiveBit, w          ;  Load the Bit Number
  addlw   -1                    ;  Start with D0
  btfss   STATUS, Z
   goto   TryD1
  bsf     STATUS, RP0
  bsf     D7Anode               ;  Turn OFF Previously Displayed LED
  bsf     D7Cathode
  bcf     D0Anode               ;  Enable D0 LEDs
  bcf     D0Cathode
  bcf     STATUS, RP0
  bsf     D0Anode
  bcf     D0Cathode
  goto    LEDDlay               ;  Finished, Repeat
TryD1:                          ;  Display D1?
  addlw   -1
  btfss   STATUS, Z
   goto   TryD2
  bsf     STATUS, RP0
  bsf     D0Anode               ;  Turn OFF Previously Displayed LED
  bsf     D0Cathode
  bcf     D1Anode               ;  Enable D0 LEDs
  bcf     D1Cathode
  bcf     STATUS, RP0
  bsf     D1Anode
  bcf     D1Cathode
TryD2:                          ;  Display D2?
  addlw   -1
  btfss   STATUS, Z
   goto   TryD3
  bsf     STATUS, RP0
  bsf     D1Anode               ;  Turn OFF Previously Displayed LED
  bsf     D1Cathode
  bcf     D2Anode               ;  Enable D0 LEDs
  bcf     D2Cathode
  bcf     STATUS, RP0
  bsf     D2Anode
  bcf     D2Cathode
TryD3:                          ;  Display D3?
  addlw   -1
  btfss   STATUS, Z
   goto   TryD4
  bsf     STATUS, RP0
  bsf     D2Anode               ;  Turn OFF Previously Displayed LED
  bsf     D2Cathode
  bcf     D3Anode               ;  Enable D0 LEDs
  bcf     D3Cathode
  bcf     STATUS, RP0
  bsf     D3Anode
  bcf     D3Cathode
TryD4:                          ;  Display D4?
  addlw   -1
  btfss   STATUS, Z
   goto   TryD5
  bsf     STATUS, RP0
  bsf     D3Anode               ;  Turn OFF Previously Displayed LED
  bsf     D3Cathode
  bcf     D4Anode               ;  Enable D0 LEDs
  bcf     D4Cathode
  bcf     STATUS, RP0
  bsf     D4Anode
  bcf     D4Cathode
TryD5:                          ;  Display D5?
  addlw   -1
  btfss   STATUS, Z
   goto   TryD6
  bsf     STATUS, RP0
  bsf     D4Anode               ;  Turn OFF Previously Displayed LED
  bsf     D4Cathode
  bcf     D5Anode               ;  Enable D0 LEDs
  bcf     D5Cathode
  bcf     STATUS, RP0
  bsf     D5Anode
  bcf     D5Cathode
TryD6:                          ;  Display D6?
  addlw   -1
  btfss   STATUS, Z
   goto   TryD7
  bsf     STATUS, RP0
  bsf     D5Anode               ;  Turn OFF Previously Displayed LED
  bsf     D5Cathode
  bcf     D6Anode               ;  Enable D0 LEDs
  bcf     D6Cathode
  bcf     STATUS, RP0
  bsf     D6Anode
  bcf     D6Cathode
TryD7:                          ;  Display D7?
  addlw   -1
  btfss   STATUS, Z
   goto   LEDDlay
  bsf     STATUS, RP0
  bsf     D6Anode               ;  Turn OFF Previously Displayed LED
  bsf     D6Cathode
  bcf     D7Anode               ;  Enable D0 LEDs
  bcf     D7Cathode
  bcf     STATUS, RP0
  bsf     D7Anode
  bcf     D7Cathode
LEDDlay:                        ;
  clrf    Dlay                  ;  High 8 Bits for Delay
  clrw
  addlw   -1                    ;  Decrement the contents of WREG
  btfss   STATUS, Z             ;   256x
   goto   $ - 2
  decfsz  Dlay, f               ;  Repeate 255x
   goto   $ - 4
  clrf    Dlay                  ;  Repeat Again for ~ 400 ms total Delay
  clrw
   goto   $ - 2
   goto   $ - 4
  incf    ActiveBit, w          ;  Increment the Active LED
  andlw   7                     ;  Keep Within range of 0-7
  movwf   ActiveBit
  goto    Loop                  ;  Repeat
  end
