Author Topic: Gizduino and Gsm module(sim900d)  (Read 1855 times)
Offline immanic
« on: December 06, 2011, 01:11:27 AM »
good day po,, sino po dito mga sirs ang successfully na nkapaginterface ng gsm module at gizduino?? pwede pong pahingi ng tips or instructions qng pano e2 paganahin?? thanks po in advance. tnry q na po kac lahat na nalalaman q and na research q about d2. kaso walei padin.. thanks for your kindness..
Offline immanic
Re: Gizduino and Gsm module(sim900d)
« Reply #1 on: December 06, 2011, 01:29:09 AM »
tinetest q po pala xa sa pc via terminal.exe... kaso ala padin... huhu. gumamint na aq ng power supply sa desktop.. pwede n bang direct lng ang gizduino sa gsm?? if yes,, anong pins po ang gagamitin??
Offline updated
  • Pogi/Ganda Points: 22
« Reply #2 on: December 06, 2011, 01:33:07 AM »
1. marunong ka ba mag arduino?
tx rx lang naman yung connection sir, plus ground and supply. dapat mapagana mo muna sa pc. para alam mo na gagawin mo sa arduino. mas madali kung ganun
"DO YOUR ORDINARY DUTIES EXTRAORDINARILY WELL."
Offline updated
« Reply #3 on: December 06, 2011, 01:39:57 AM »
nagka prob din ako sa terminal exe, hindi ko din mapagana. hindi ko kasi alam panu mag send ng hex dun. sa hercules na software ko napagana
Offline immanic
« Reply #4 on: December 06, 2011, 01:40:14 AM »
thanks sa reply sir ^^, transdeucers lng po and some user interface commands ang gnagamit ko.. first time po sa module.. noong una po, napagana q na sa terminal.exe yung AT and AT+CMGF .. nagrereply naman ang gsm.. but palaging nagrerestart after few seconds... then madami na aq natry na connections.. ngaun hndi q na mapagana... ang gnamit q po, newsoftserial den tx to rx and rx to tx.. den supply ko sa stat, 3.3v.. den common ang ground.. yun po.. pero walei padin :'(
Offline immanic
« Reply #5 on: December 06, 2011, 01:42:33 AM »
ok po.. try q ang hercules.. pero wala na pong voltage limiter na kailangan? rx tx lng tlga?? pano po yung stat and poweron??
Offline updated
« Reply #6 on: December 06, 2011, 01:46:06 AM »
anu reply ng gsm?
Offline updated
« Reply #7 on: December 06, 2011, 01:48:05 AM »
meron ka bang ginamit na converter? usb to ttl?(prolific)
Offline immanic
« Reply #8 on: December 06, 2011, 01:50:13 AM »
dun sa accidental qng naparun...  ang lumalabas sa umpisa gani2 ........ dotdot lng. den type aq ng AT   ok naman ang reply den minsan habang nasa kalagitnaan aq ng pagtype.. biglang lalabas uli ang ......... pero ngaun kahit yng cnabi hndi q na napapalabas po.. huhu. no response na ang gsm
Offline immanic
« Reply #9 on: December 06, 2011, 01:53:28 AM »
opo.. nakakapag program nmn po aq sa arduino before ng mga projects.. prolific din po gnamit q..
Offline updated
« Reply #10 on: December 06, 2011, 02:03:14 AM »
AT lang tinype mo? then send? meron bang kasama na carriage return at line feed?
Offline updated
« Reply #11 on: December 06, 2011, 02:05:34 AM »
sa terminal exe, nagmonitor ako ng hex data na binabato. kapag walang \r\n hnd gagana.
Offline immanic
« Reply #12 on: December 06, 2011, 02:08:20 AM »
sinunod q po kac yung instruction sa net.. proven naman daw po.. enter lang daw po para matransmit.. then,, pag "OK" daw po ang reply... pwede na dawpo yung mga AT commands iexecute.. pero iconfirm q lng po,, rx tx and supply lang po pala talga.. den direkta na sa gizduino yung rxtx?
Offline updated
« Reply #13 on: December 06, 2011, 02:16:28 AM »
tama, kung sa gizduino dapat common ground..
regarding sa pag sunod sa instructions sa net. ginawa ko din yun.. kaso ayaw ehh. kaya napunta ako sa hercules na software. nag send ako ng AT, then nag send ako ng hex na 0D 0A(carriage return at line feed) saka nagreply ng OK. nakapag text ako in this manner. kapag wala yung carriage return at line feed walang response ;D
Offline immanic
« Reply #14 on: December 06, 2011, 02:21:18 AM »
no idea po dun sa hex.. hehe, type q lang po yung cnabi mo po every line? saan ko po pala makukuha yung hercules? pwede po favor,, sample commands po ng pag try mo. hehe. salamat. mejo desperate na po kac aq dahil malapit na po ang defense namin sa thesis :'( e2 nalang po ang last feature. thanks a lot.. a bigfavor po..
Offline updated
« Reply #15 on: December 06, 2011, 02:39:02 AM »
google. try mo lang.. dapat AT pa lang mag reply ng OK. tulog na ako. ;D ;D ;D
Offline immanic
« Reply #16 on: December 06, 2011, 02:41:22 AM »
thanks a lot bro ^^, ;D
Offline torpedo
  • Pogi/Ganda Points: 21
  • Ooh-Rah!!!
« Reply #17 on: December 16, 2011, 03:16:58 PM »
charge taka daw brad...  +1
" Victory belongs to those who believe in it the most....and believe in it the longest. " Col. James H "Jimmy" Doolittle
Offline RagnaroksSun
  • Pogi/Ganda Points: 4
« Reply #18 on: December 23, 2011, 11:48:13 PM »
sir updated..patulong naman po.. nagloloko ata gizduino ko..tuwing nag uupload ako ng codes ko.. eto lumabas..
avrdude: stk500_getsync(): not in sync: resp=0x33
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x06
anu po possible problem nento sir?
Offline updated
« Reply #19 on: December 23, 2011, 11:58:51 PM »
reinstalling the prolific driver.
May power indicator naman? anu status ng hardware?
