Author Topic: Speaker protect with signal and clip indicator  (Read 4613 times)
Offline jyjc
  • Cisco Professionals
Re: Speaker protect with signal and clip indicator
« Reply #40 on: May 19, 2012, 01:34:39 PM »
ah AC supply pala ito.. may nakalabel kasi na "to Negative Supply of Power Amp" nalito ko dun.
kahit magkabaligtad kasi ac source naman. dun sa board na label + and -
Offline Skyjham
  • Pogi/Ganda Points: 138
« Reply #41 on: May 23, 2012, 09:46:30 AM »
kilangan ang ground ng speaker protect board connected sa ground ng power supply ng amp para sa clippings
Learning is un-ending process
Offline jyjc
« Reply #42 on: May 23, 2012, 10:23:28 AM »
+1
Offline DJFEL
« Reply #43 on: July 04, 2012, 08:53:30 PM »
ito po ung speaker protect at signal
ito naman po ang clip
nababa ko lang..sa k10 power amp to..konzert anp...
dj fel on the mix
Offline Skyjham
« Reply #44 on: July 04, 2012, 09:17:07 PM »
yup sa K10 yan na schematic
Offline DJFEL
« Reply #45 on: July 04, 2012, 09:29:42 PM »
eto yong amp ginamit ko..may 8pcs amp na kami dito...hangGang ngayon isa pa ang na sira..yong da rest wla pa sira..
dj fel on the mix
Offline Skyjham
« Reply #46 on: July 04, 2012, 11:28:38 PM »
ano problema ng K10 mo sis?
Offline DJFEL
« Reply #47 on: July 05, 2012, 07:21:57 AM »
Ecap sis power supply 4pcs sabog lahat...piro ok na ngayon..last December na sira...
dj fel on the mix
Offline elaijah
« Reply #48 on: July 14, 2012, 07:32:45 PM »
subscribing ako mga sirs....
Offline kaiky14
  • Pogi/Ganda Points: 27
« Reply #49 on: July 30, 2012, 08:07:43 AM »
@Skyjham
merom ka pa ba nito?pwede ba ako order sayo?
Offline Skyjham
« Reply #50 on: July 30, 2012, 01:36:54 PM »
kilan mo kilangan sis dami kasi orders ng 10 pairs ng yamha meron ng built-in short circuit protection, mag o off yung relay pag may short na speaker.
Offline Deantyne
  • Pogi/Ganda Points: 90
  • Focus my friend...
« Reply #51 on: July 30, 2012, 02:53:52 PM »
pa marka.. ;D
BACK TO BASICS
Offline kaiky14
« Reply #52 on: July 30, 2012, 04:09:35 PM »
ito bang Speaker protect with signal and clip indicator na pinost mo ay ganun din?na kapag nagkaron ng short circuit sa spkr wire mag-o off din ung relay? kasi kung my available ka ngayon jan order na ako.. wala na kasi ako time pag ako pa gagawa kaya kuha nalang ako sa d naman kamahalan. ;D
Offline elaijah
« Reply #53 on: July 30, 2012, 04:58:40 PM »
hello sirs yung sinabi mong built-in short circuit protect ay same ba sa post mo na speaker protect na circuits sir? anong kaibahan sirs?
Offline Skyjham
« Reply #54 on: July 30, 2012, 10:20:48 PM »
iba din itong overload,overcurrent or short circuit protect sis, pag e short mo ang speaker mag off yung relay din after 7 sec onds mag on sya ulit. at pag na detect nya na meron pa ring short sa speaker terminals mag off sya ulit.
Offline kaiky14
« Reply #55 on: July 31, 2012, 08:06:48 AM »
pwede mo ba ako igawa ng Speaker protect with signal and clip indicator mo na nakapost dito sa thread mo tapos isama mo na rin yang bago mo na overload,overcurrent or short circuit protect.pa pm mo sakin contact number mo para matext o matawagan kita para jan thanks..
Offline dave26
« Reply #56 on: August 06, 2012, 12:31:35 PM »
gud day po,meron po akong power amp local lang ACOUSTIC ang brand.probs ko kc nagproprotect kapag setting ko mixer>eq>crossover>power amp.ginamit ko itong amp for 2 pcs na sub.pro kung direct to dvd> Eq na 2 way setup ok nman.nagproprotect nman pag nag line/out ko sa ibang amp...minsan nman ok nman kahit sa different settings...condemn ko nlang kya yung protect,ok lang po ba yun?
Offline Skyjham
« Reply #57 on: August 06, 2012, 02:22:29 PM »
pede ko yun ma bypass yun nga lang wala na protect ang speakers mo
  • Pogi/Ganda Points: 98
« Reply #58 on: August 06, 2012, 06:06:14 PM »
sis skyjham pwed po ba dagdagan ng short cicuit protect yung existing na protection circuit nung amp ko?
Offline Skyjham
« Reply #59 on: August 07, 2012, 12:11:03 AM »
pede sis kilangan mong maglagay ng emitter resistors na 100 ohms 1/4 watt sa mga power transistors,ito yung mag trigger sa short circuit protect din e feed doon sa DC protect para mag off ang relay pag may short sa speaker terminal.
Bali may dinagdag na dalawang resistors as a switch.din capacitor para sa delay at mga resistors
