Author Topic: HELP! how to remove boot options from boot up screen??  (Read 780 times)
Offline BlackHaT22
« on: December 20, 2011, 02:04:32 PM »
help nman master mgdual os sna ko eh prehong xp chancel ko set-up pero dun padin sa boot ung choice,, naformat ko n ung partition pero andun pdin eung boot choices..
Offline sympleguy2u™
  • Pogi/Ganda Points: 12
  • Experience is the best teacher of all time
Re: HELP! how to remove boot options from boot up screen??
« Reply #1 on: December 20, 2011, 02:15:35 PM »
TS, punta sa MY COMPUTER then RIGHT CLICK then choose mo PROPERTIES, pag nasa properties ka click mo yung ADVANCE TAB then punta ka sa STARTUP and RECOVERY then click mo yung SETTING then i-click mo dun sa SYSTEM STARTUP yung edit. The i-post mo kung ano yung lumabas na setting sa notepad para madelete natin yung boot choices.
Pag gusto may paraan, pag ayaw maraming dahilan
  • Pogi/Ganda Points: 316
« Reply #2 on: December 20, 2011, 02:17:24 PM »
tambay, mabuti kung 7 lang ito..
  • Pogi/Ganda Points: 916
« Reply #3 on: December 20, 2011, 02:31:03 PM »
malamang win7 ito.. same sa nadanasan ko noon  ;D
paabang  dito ...  baka may  iba pang trick
Offline Lola Baciang
  • Pogi/Ganda Points: 134
« Reply #4 on: December 20, 2011, 02:43:59 PM »
Bkit kya nagkaganun?
post ka ng screenshat dito bka mas madali mag bigay np payo
Expect The Unexpected
« Reply #5 on: December 20, 2011, 02:46:28 PM »
Offline nucleus
« Reply #6 on: December 20, 2011, 03:08:06 PM »
help nman master mgdual os sna ko eh prehong XP chancel ko set-up pero dun padin sa boot ung choice,, naformat ko n ung partition pero andun pdin eung boot choices..
;D ;D
punta ka sa C: saka mo iset sa tools tab/folder options/ view tab click mo yung show hidden files uncheck yung hide extensions for known file types at uncheck din yung hide protected system files then click apply then ok
makikita mo ngayon si boot.ini sa C drive mo right click mo ito properties uncheck mo yung read only then click apply then ok.
open mo ngayon yung boot.ini at idelete yung line ng gusto mong alisin na option, siguraduhin na iyun nga ang gusto mong alisin at isave at pwede ka ng magrestart.
Offline j a y k e z
  • gimmegaggigsss
« Reply #7 on: December 20, 2011, 03:21:10 PM »
sis baka hindi mo nadelete ung dating XP partition, dapat delete mo partition, create partition, then format install na ;D
« Reply #8 on: December 20, 2011, 04:04:14 PM »
Anong step kaya ginawa nya,kaka-rf ko lng dual boot os,automatic nman inaalis ang dating laman smooth nman,dati kasi unregistered ung 2 os ko kya madalas nagkaka problem,ngyon registered na 2 os ko using activator.
ot-mali ang procedure mo siguro sis,paki elaborate dito ang procedure na ginawa mo
  • Pogi/Ganda Points: 414
« Reply #9 on: December 20, 2011, 05:44:41 PM »
Baka 2 xp os. Patambay na lang ng matuto sa mga master.
« Reply #10 on: December 20, 2011, 06:40:37 PM »
sp2 at sp3? ;D
Ts nawawala
Offline BlackHaT22
« Reply #11 on: December 20, 2011, 08:21:14 PM »
My nka install n kc n Window xp sp3 tas gumwa pa q ng isang unlocate partition bale partition2 un ininstall ko ung Windows XP SP3 DarkLite Edition aun nung nagload xia lageh nmmtay .. kya di ko n pingpatuloy tapos pinormat ko ung partition2 using "EASEUS partion mster" dhil di nmn gumgna tas dinelete ko tas merge q.. tas ngreboot n aun my choice padin n lumilitaw prehong window xp. error ung isa ...
« Reply #12 on: December 20, 2011, 08:26:54 PM »
pwede ka rin gumamit ng EasyBCD pero use it at your own risk...
di ko kabisado sa XP-XP
pero kung Win7-XP lang to solb na toh ;D
« Reply #13 on: December 20, 2011, 09:37:52 PM »
Check sa boot.ini. Or baka kaya ng second repair options. Di ko pa nasubukan.
Offline jmg
  • Pogi/Ganda Points: 83
« Reply #14 on: December 21, 2011, 09:30:33 PM »
agree ako dito TS
use easyBCD at solve nayan
Offline BlackHaT22
« Reply #15 on: December 22, 2011, 06:27:13 AM »
Marming Slamat mga master ...  masmadli ung kay simpleguy2u ^^
« Reply #16 on: December 22, 2011, 08:06:07 AM »
congrats na pla ito,kapehan na ;D ;D  ;D
