Author Topic: IEEE 519 help  (Read 685 times)
Offline LuffyX
IEEE 519 help
« on: December 28, 2011, 09:47:00 AM »
is there anyone here who has a copy of IEEE 519-1981 and IEEE 519-1992 documents?
Nobody wants to be alone.
"Christ Above All"
IEEE 519 help
Offline robbietan
  • Pogi/Ganda Points: 17
Re: IEEE 519 help
« Reply #1 on: December 28, 2011, 10:39:19 AM »
hard copy lang. if I may ask, how do you intend to use the standards? unless nasa testing or designing ka, the books are not much use.
voltage limits are in the realm of utility engineers and equipment designers, current limits are for users and equipment designers
apqi.ph
Re: IEEE 519 help
Offline LuffyX
Re: IEEE 519 help
« Reply #2 on: December 28, 2011, 11:12:09 AM »
@robbietan, thanks for the response sir. am not in testing and design sir. humihingi lang kasi ng certificate of compliance with IEEE 519 for our VFD ung client ko kaya naghahanap ako ng copy para mapag-aralan yang IEEE 519 before issuing the necessary certification.
"Christ Above All"
Re: IEEE 519 help
Offline robbietan
Re: IEEE 519 help
« Reply #3 on: December 28, 2011, 11:42:37 AM »
in that case, the manufacturer should be able to provide specs that comply with the harmonic standards. you can also look for  certain features of the VFD like built in reactors, filters, etc that help mitigate the harmonics emissions of the VFD
apqi.ph
Re: IEEE 519 help
Offline LuffyX
Re: IEEE 519 help
« Reply #4 on: December 28, 2011, 11:48:38 AM »
the specs does not have any indication that the equipment complies with the IEEE 519 standard. although, it has built in noise filters and external reactors, there is no data indicating the harmonic distortion produced.
"Christ Above All"
Re: IEEE 519 help
Offline robbietan
Re: IEEE 519 help
« Reply #5 on: December 28, 2011, 03:24:05 PM »
then my take is that you have to measure the voltage characteristics at the main supply breaker when you plug in the VFD and check if the voltage THD is below the 5% limit.
the utility (i.e Meralco) is only concerned when the voltage THD at the point of connection (at the meter) is beyond 5%.
apqi.ph
Offline robbietan
Re: IEEE 519 help
« Reply #7 on: February 24, 2012, 08:04:08 AM »
http://www.eaton.com/ecm/groups/public/@pub/@electrical/documents/content/ap04014002e.pdf
http://www.electrical-installation.org/enwiki/Power_harmonics_standards
the link from eaton is the usual informative and excellent article from eaton.
however, the link from enwiki is very vague. for example, the "harmonic levels" given are just numbers, there is no identification as to whether these "levels" correspond to VTHD or ITHD or ITDD, etc.
apqi.ph
Offline LuffyX
Re: IEEE 519 help
« Reply #8 on: February 28, 2012, 09:25:41 AM »
thanks for the links.
"Christ Above All"
Offline helensosa655
Re: IEEE 519 help
« Reply #9 on: April 07, 2012, 06:58:03 PM »
so great
Offline ramlew
Re: IEEE 519 help
« Reply #10 on: September 23, 2012, 08:50:43 AM »
tanung lang po,,,,,,what if an electrical engineer violates Anti-Electricity and Electric Transmission Lines/Materials Pilferage Act of 1994 [RA 7832]
Offline robbietan
Re: IEEE 519 help
« Reply #11 on: October 08, 2012, 12:41:30 PM »
the law does not discriminate engineers from non-engineers.
however, if anyone (engineers or non-engineers) from a utility company violated RA 7832, they may be out of a job
apqi.ph
Re: IEEE 519 help
