Author Topic: Panasonic TC-21S10P schematic diagram  (Read 714 times)
Offline ditchie
  • Pogi/Ganda Points: 100
  • wish ....wish...
« on: January 03, 2012, 02:27:37 PM »
pa help po sana sa unit na ito kelangan ko ng schematic for troubleshooting.
major parts used:
JUNGLE AN5192NK
MICOM  MN1528115ZW
REG      C4804A  transisitor
H-OUT   D2499
error amp SE090
history: galing na sa ibang technician, sabi ng may-ari wala daw lang picture sometimes meron at blurry pero meron sound. ginalaw ng ibang technician sa main board. resolder niya micom at jungle, pero pangit ka solder cold solder mg pins. tpos ginalaw mg part near sound ic. nilagay sa copper side. meron din transistor na tinggal part number Q116 medyo malapit sa sound IC. marami pa ang ginalaw sa mainboard. pati din sa C-board.
what i've done:
inayos ko muna mga cold solder lahat ng ginawa niya resolder ko lahat at linis mode using laquer. pinalitan ko suspected ecaps sa PS section. Upon Inspection nakita ko na corroded na CRT socket so palit mode din. Before Power up , nag bulb method muna ako sa fuse. then power up. so far ok naman nagstandby ang unit. install fuse then power up standby ang unit ayaw mag.oscillate. no click heard from RELAY.
next voltage testing:
voltage at main ecap  300vdc
5VOLTS ok
b+ 10vdc only
no other voltage present.
help po...
--Mahatma Gandhi
Offline ditchie
  • wish ....wish...
Re: Panasonic TC-21S10P schematic diagram
« Reply #1 on: January 03, 2012, 02:30:44 PM »
any comments would greatly help me troubleshoot. 3days ko na itong ginagawa still no luck. standby lang ang unit w/ red led on.
additional info: all transistor at PS section including REG are ok.
--Mahatma Gandhi
Offline sympleguy2u™
  • Pogi/Ganda Points: 12
  • Experience is the best teacher of all time
« Reply #2 on: January 03, 2012, 04:05:45 PM »
Pag gusto may paraan, pag ayaw maraming dahilan
Offline ditchie
  • wish ....wish...
« Reply #3 on: January 03, 2012, 05:03:20 PM »
^tnx sis. pero saan download link dun..
--Mahatma Gandhi
« Reply #4 on: January 03, 2012, 05:08:50 PM »
Sis, dun sa baba makikita mo Get Manual
        click mo lang yan --->  not logged in
                                       Only 2 Downloads
                                       allowed a day!
Offline ditchie
  • wish ....wish...
« Reply #5 on: January 03, 2012, 05:13:12 PM »
tnx sis nag.appear na din after 30 minutes. kanina processing lang pla...
malanding points para sayo..
--Mahatma Gandhi
  • Pogi/Ganda Points: 776
« Reply #6 on: January 03, 2012, 06:35:24 PM »
replace mains filter ecap, small ecap
replace secondary 220uf200v
Offline ditchie
  • wish ....wish...
« Reply #7 on: January 03, 2012, 06:53:41 PM »
ok master pete  palitan ko bukas ecap.
--Mahatma Gandhi
Offline RhUNhA
  • Pogi/Ganda Points: 356
« Reply #8 on: January 03, 2012, 07:29:32 PM »
check m yung diode malapit sa tact switch...at yung mga tranie connected sa relay.check mo din yung base ng trannie trigger ng relay kung may supply nang gagaling sa syscon..
Offline ditchie
  • wish ....wish...
« Reply #9 on: January 03, 2012, 07:39:44 PM »
i'll check that sis. sa supply na galing from syscon meron naman siya sis.
--Mahatma Gandhi
Offline RhUNhA
« Reply #10 on: January 04, 2012, 07:29:19 AM »
kung may supply galing syscon yung base ng trannie trigger sa relay kapag press mo ang power button baka nmn deffective yung trannie mo ....sabi mo kasi ok nmn may  supply na 5v..ilan ba ang nasusukat mo sa pin ng relay...
