Author Topic: D-sub-9 Female female right angle - for PCB(20 pcs.)  (Read 627 times)
  • Pogi/Ganda Points: 53
« on: January 13, 2012, 07:26:20 AM »
di ko na rin ito magagamit.. Nasa gilid na lang..
di pa yan nabubuksan na dalawang nakapack
250 petot lahat na..
Re: D-sub-9 Female female right angle - for PCB(20 pcs.)
« Reply #1 on: January 13, 2012, 07:47:32 AM »
Offline dummy_c
  • Pogi/Ganda Points: 162
« Reply #2 on: January 13, 2012, 07:57:54 AM »
Pwedi ba hindi bilhin lahat? ;D ;D
250/20 = 12.5 petot bawat isa
« Reply #3 on: January 13, 2012, 08:04:31 AM »
ilan ba sis kaylangan u?
sige 220 na lang lahat yan! ;D ;D ;D
natatambak na lang kasi mga ganyan dito.. heheh
Offline dummy_c
« Reply #4 on: January 13, 2012, 08:09:28 AM »
10 pcs lang seguro sis...
Nasa cebu ka pa ngayon?
« Reply #5 on: January 13, 2012, 08:11:08 AM »
15.00 petot sa egizmo
Nope sa bicol na ako sir.. heheh binili ko yan sa egizmo dati pa.. di ko man nagamit.. ewan ko ba andami nang binibili ko hahah
« Reply #6 on: January 13, 2012, 08:40:40 AM »
200 na lang lahat :D
marami rin akong ganito, bumili ata ako dati ng 20pcs din tapos 3 lang nagamit ko, almost 6years na ata yun sa bins ko :D
  • Pogi/Ganda Points: 414
« Reply #7 on: January 13, 2012, 08:44:18 AM »
Aha kaya pala wala ako mabili, pinakyaw na ninyo.  ;D
« Reply #8 on: January 13, 2012, 08:46:41 AM »
Oh sige! 200 na lang! ;D ;D :D
Ididispose ko na rin toh.. hahah
  • Pogi/Ganda Points: 412
« Reply #9 on: January 13, 2012, 10:57:06 AM »
Kunin ko lahat...PM me sa details...;D
« Reply #10 on: January 13, 2012, 11:33:49 AM »
PM'ed you! :)
« Reply #11 on: January 18, 2012, 09:11:03 AM »
up!!! di kumuha sis KAS, male daw ang need niya! ;D ;D ;D Puro FEMFEM PU IYAN
Offline dummy_c
« Reply #12 on: January 18, 2012, 10:06:30 AM »
^ Bakla talaga si master kas! ;D
« Reply #13 on: January 18, 2012, 10:15:16 AM »
TXT me again....kukunin ko na lang yan bakla....or pm me ulit..;D
« Reply #14 on: January 18, 2012, 10:17:12 AM »
Padala mo dun sa kaibigan ko kailangan niya.  :D
« Reply #15 on: January 21, 2012, 04:53:29 PM »
heheh. PM mu na lang ako kung interesado ka talaga.. hahaha
« Reply #16 on: January 29, 2012, 06:32:56 PM »
up!!!!!!!!!!!!!!
« Reply #17 on: January 30, 2012, 11:32:12 AM »
up!!!!!!!!!!!!!!!!!!!!
Offline _basura_man()
  • Pogi/Ganda Points: 36
    • Learn robotics here.
« Reply #18 on: January 30, 2012, 11:46:19 AM »
bakit mo ako blinock hotgay?bilhin ko sana yan,may sama ka pala ng loob sa akin ah    :D :D :D
-John
« Reply #19 on: January 30, 2012, 12:01:58 PM »
ah? nuon pa yan di kona  naibalik! hahah
