Hi, all... I need help deciding the wheels for my mobot...
I initially planned to attach my wheels directly to the shaft of the motor (6V DC MABUCHI motor, small size lang) but I realized there won't be enough space left to insert my encoders in between..
I tried to "extend" the shaft by drilling a hole into chopsticks then sticking it in the shaft... but it's not really good with all the wiggling while the motor is running... I need the encoders for my PID. I am also using differential motors so if I'm gonna buy a new motor, I gave to buy 2 pcs.
I've been to e-gizmo, however their wheels are too thick... I've also been to Lil's and I saw a 2-pc "mags" that is sized just right, but it's width is also thick, although may as well insert it backwards in my motor...
This is my first time building a mobot, so i need help with sourcing or alternatives etc...
Right now, I'm still trying to make the chopsticks shaft work.. but i am also thinking of:
1.) buying a geared motor and put a longer shaft (will my PID calculations change because of having gears?)
2.) buying a motor with encoder (last resort)
3.) buying the 345++ peso 24V motor that has a reasonable shaft length and has a wedge and look for a large diameter wheel (nahihirapan din ako mag source ng wheels with reasonable diameter)
4.) Putting gears into my current motor (which I still have no idea on how to do it...)
5.) Some other options I am not aware of....
what do you think guys? need some advice.. advise.. here
Thank you..
