Author Topic: Error during Build  (Read 499 times)
Offline tinkerbelldiwata
Error during Build
« on: January 16, 2012, 11:07:19 PM »
Hello, people! I was having a trouble building the file created in ZDS II 4.90 version. It appeared like this:
------- projectraks  Configuration: Debug -------
[ERROR] Unable to create linker command file.  Build aborted.
[ERROR] Unable to create make file. Build aborted.
Build completed.
What will i do? Tulong po..  :'(
Error during Build
Offline ΔЅịMø
  • Pogi/Ganda Points: 140
  • "Live Curious"
Re: Error during Build
« Reply #1 on: January 19, 2012, 04:48:51 PM »
Na-solve na po ba to?
« Reply #2 on: January 29, 2012, 10:20:15 PM »
Offline ΔЅịMø
  • "Live Curious"
« Reply #3 on: January 30, 2012, 09:09:54 AM »
Pero, na-compile nyo na po? Baka po kasi during compilation, may error po syang na-meet eh.
« Reply #4 on: April 12, 2012, 11:22:12 PM »
Ok na po ito.. salamat.. :) dapat pala hindi ko muna in-open yun project sa 5.0 zds II.. sa 4.9 dapat.. i should've installed 4.9 prior to opening the project..
Offline ΔЅịMø
  • "Live Curious"
« Reply #5 on: April 13, 2012, 09:33:11 AM »
Aw. Yun lang pala? :D :D Congrats! :D
« Reply #6 on: April 15, 2012, 04:38:16 PM »
[ERROR] Connection Failed. Check power and communication connections.
[ERROR] Target read/write error. (ERR_DTLI_SERIAL_ERROR)
[ERROR] Unable to connect to the target.
pano naman po ito? actually kaka-post ko lang din sa thread ni sir paranz. hindi ko po alam kung ano gagawin ko. feeling ko yung max232 ang problema. sensitive ba yun? i removed it from its esd case. ang ginagamit ko ay debugger from e-gizmo. nag'aalangan ako galawin kasi baka lalong walang mangyari.. tulong naman.. please!!!!!!!!!!!!!   :'(
Offline ΔЅịMø
  • "Live Curious"
« Reply #7 on: April 16, 2012, 09:15:10 AM »
Pwede ring yung po yung reason. Baka sira ang MAX232. Try nyo lang po yung debugger nila. Baka gagana yun. 5V lang po yung kailangan sir. Jan din kasi ako nagkakamali eh kaya sunog lahat ng MAX232 ko. Pin config lang po yung tingnan ninyo.
