Author Topic: Share your Simple but tricky Programming Exercises...  (Read 4449 times)
Offline 'yus
  • Pogi/Ganda Points: 299
  • hw -> fw -> sw
    • yus' projects
Re: Share your Simple but tricky Programming Exercises...
« Reply #60 on: November 18, 2010, 12:35:46 PM »
mukhang ok naman yung "number before letter... :)
http://www.freeimagehosting.net/uploads/1b48656aa8.png
« Reply #61 on: November 18, 2010, 12:39:53 PM »
nope di sideline ito heheheh :D
« Reply #62 on: November 18, 2010, 12:47:31 PM »
yup nasimulate ko din yung code mo ngayon lang. ayus na ayus
« Reply #63 on: November 18, 2010, 01:31:50 PM »
@sis gigz,
naalala ko lang kasi before yung tanong mo sa akin sa ym about kung saan maganda gamitin ang regex. di ko rin siya nasagot ng maayos kasi naghahanap din ako ng magandang mapaggagamitan... until nagkaroon ako ng ganitong problem na dikit dikit yung schematic name at kelangan kong ihawalay isa isa at isort after that... so ito yung kauna-unahang nagamitan ko ng regex:
written in python:
import re
mystr="A1D2S3MYLOGO4IC9IC10IC55"
MyComponentList=re.findall(r'[A-Z]+[0-9]+',mystr)
print MyComponentList
output
['A1', 'D2', 'S3', 'MYLOGO4', 'IC9', 'IC10', 'IC55']
C# equivalent:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Text.RegularExpressions;
namespace ConsoleApplication1
    class Program
        static void Main(string[] args)
        string MyStr="A1D2S3MYLOGO4IC9IC10IC55";
        Regex myReg=new Regex(@"[A-Z]+[0-9]+");
        MatchCollection m= myReg.Matches(MyStr);
        //print all the elements
        foreach(Match x in m)
            Console.WriteLine(x.ToString());
output:
A1
D2
S3
MYLOGO4
IC9
IC10
IC55
Press any key to continue . . .
« Reply #64 on: November 18, 2010, 01:43:04 PM »
nice.. point for you :D di ko maintindihan dati yang regex na yan.. siguro time for me na din para balikan ito =)
« Reply #65 on: November 18, 2010, 05:51:02 PM »
Anong version ng python gamit nyo? Di ko kasi mairun ung script.
« Reply #66 on: November 18, 2010, 05:59:59 PM »
python 2.xx sis... baka version 3 yung python mo?
« Reply #67 on: November 18, 2010, 07:17:04 PM »
Bakit ganun ayaw pa rin kahit sa 2.6.4
Line by line execution ba or copy past lang ng mga codes?
« Reply #68 on: November 18, 2010, 10:42:18 PM »
pwedeng copy paste pwedeng line by line execution.. mas maganda ipaste mo sa isang .py na file, tapos irun mo siya
« Reply #69 on: November 18, 2010, 11:11:01 PM »
Got it working using eric IDE ni yus. Level 3 na ako but I've used manual technique. Suko na ako sa level3 since di na kaya ng powers ko.
« Reply #70 on: November 20, 2010, 12:43:31 AM »
di ko na rin pinagpatuloy yan heheheh... mukhang kelangan in-depth ang knowledge sa python para sa puzzle na yan heheheh.... medyo mababaw pa lang ang nalalaman ko sa python hehehehe...
« Reply #71 on: December 07, 2010, 02:47:41 PM »
naaliw na ko sa REGEX :D
ginagamit ko sya ngayon, kahit na medjo nahihilo pa ko sa mga expressions..
bagay na bagay for parsing=)
