Author Topic: Sony KV-29HX1 Japan Surplus Picture Sexy  (Read 1090 times)
Offline BUMBLEBEE
  • Pogi/Ganda Points: 109
  • transform!!!!!!!!!!!
Re: Sony KV-29HX1 Japan Surplus Picture Sexy
« Reply #20 on: January 26, 2012, 09:00:05 AM »
subscribe....poh
Offline DSM_elektronix_shop
  • Pogi/Ganda Points: 153
« Reply #21 on: January 26, 2012, 07:52:39 PM »
ano n kya nanyrui
DSM_electronics_shop
Alvin Y. Carulasan
Sinal Village, Taguig city
Offline resist
« Reply #22 on: January 30, 2012, 09:39:45 AM »
ecap yn.....
Offline pEN DoTA
« Reply #23 on: February 02, 2012, 11:02:57 PM »
hindi na nakapag update ang t.s. busy sa panonood ng sexy.
GOD LOVES YOU
Offline Berlin C. Alcayde
  • Pogi/Ganda Points: 5
« Reply #24 on: February 04, 2012, 04:12:05 PM »
D ko pa nagawa mga sir. Npalitan ko na lahat ng ecap ganun pa rin. Pag nakaharap sa tv yung right side ang unang nagkakaitim paglumaki na yung itim sa right dun pa lang magkakaitim sa left.
Offline GuDo
  • repair is my hobby and also my career..
« Reply #25 on: February 19, 2012, 08:07:09 AM »
check line from jungle to pin drive kung maayos.. check resistors.. check pin 1 and pin 2 ng op-amp..
"manatiling masipag, dahil ito ang tutulong sa iyo na umahon sa kahirapan"
Offline mcleod
  • Pogi/Ganda Points: 143
« Reply #26 on: February 27, 2012, 12:55:49 PM »
pag sexy nasa pin amp nga ito or sa horizontal din kc related sila. may di sapat na voltage. caps or resistor ito try mo i hair dryer resistor or caps na mga andito makuha mo na, leaky ito pag tinest mo ok pag nag init change value.
Offline ronaldo
« Reply #27 on: March 04, 2012, 12:18:03 PM »
Sundin nyo lang mga payo ng mga master dito sa Elab:)
Offline samiel
  • Pogi/Ganda Points: 53
« Reply #28 on: March 04, 2012, 01:30:27 PM »
hmmmm...parang nakaincounter na ako ganyang problem sa sony surplus...check mo yung nakapaligid na zener diode sa jungle ic nya baka may nagleak...yung isa na gnawa ko hindi cya leak,pero nung tinaggal ko nagnormal cya...kaya tinanggal ko nalang cya hehehe
Offline DJFEL
  • Pogi/Ganda Points: 44
« Reply #29 on: March 04, 2012, 07:46:21 PM »
sub....
dj fel on the mix
Offline mcleod
« Reply #30 on: March 20, 2012, 02:34:34 PM »
kumusta na ang sexy este ang tv pala! ;D
Offline SexyPaint
  • Pogi/Ganda Points: 25
« Reply #31 on: March 25, 2012, 03:50:19 PM »
baka kinuha na ng may ari yung sexy.... ;D ;D ;D
