Author Topic: 1.2V Ultra Bright White LED Driver  (Read 3809 times)
Re: 1.2V Ultra Bright White LED Driver
« Reply #20 on: July 03, 2008, 03:52:36 PM »
I'm using a 10mm led from deeco. i've replaced the value to fit my inductor. Can any of you provide some basis for the design like the computation so that I can maximize the value that I can use. I don't know if the RCL meter I used is correct but I only have 3.45 mH.
Offline florenz
« Reply #21 on: September 04, 2008, 11:34:46 PM »
Can this be used for Luxeon LED 3.3V, 250ma?, i.e. I will use 3 AA (3 x 1.2) = 3.6V.
Will it work?
« Reply #22 on: September 05, 2008, 08:59:31 AM »
Will it work?
it may work but it is better if you have a constant current source to protect the LED. Mahal pa nman nyan.
Offline macky
  • Pogi/Ganda Points: 51
« Reply #23 on: September 05, 2008, 12:08:25 PM »
Will it work?
250mA, i think that circuit is not capable of delivering even a 200mA output current.
john 3:16 | oil of gladness
Offline lightelectro
    • Android Tablet Lover
« Reply #24 on: September 12, 2008, 02:09:36 PM »
sino na nakagawa nito? pwede ba yung ordinary leds? 8)
LATEST ANDROID TABLET NEWS
Offline mArKhAo
  • Pogi/Ganda Points: 70
  • point and shoot
« Reply #25 on: September 12, 2008, 02:18:54 PM »
experiment! hehe... ung isa plng ngagawa q e... 1.5volts paiilawin ung isang ordinary led... with coil, transistor and 1 resistor... try mo poh.. ;)
« Reply #26 on: September 12, 2008, 02:38:50 PM »
ilang times sya na mas maliwanag? 8)
« Reply #27 on: September 12, 2008, 04:31:32 PM »
eto yung akin nakapost sa page 1
Offline macky
« Reply #28 on: September 12, 2008, 05:32:53 PM »
pwede rin sya driver sa mga laser(nabibili sa muslim), tested ko na po na hindi over-driven.
1.2volts na lang ang natitira sa battery pero malinaw pa rin ang laser.
Offline 1110000
  • Pogi/Ganda Points: 28
« Reply #29 on: September 14, 2008, 01:24:34 AM »
Here is my version:
The coil was from a nokia charger.
you can use those resistor type 100uH inductors from an original nokia phone charger :)
E153C51513
Offline kirk simone
« Reply #30 on: September 14, 2008, 06:46:01 PM »
try ko nga hehehe
shake it .....
« Reply #31 on: September 15, 2008, 10:08:11 AM »
the choke coil was from original nokia charger pero napalitan ko na ng mukhang resistor na coil from alexan.
