search mo datasheet ng pic na gagamitin mo sir.gamit ka ng transistor para mag drive sa relay.dac-resistor-transistor-relay> i search mo ito sir para magka idea ka.
pa help po sa relay out na dapat 5V ung labas...
ung relay, gusto mong magkaroon ng 5V output?
parehas lang ng switch ang relay sir,dapat may panggalingan ng 5v supply dapat.
more info .... schematic wala ba? nakakalito
ayan out nya 5v.. check na lang NC/NO ng relay Uploaded with ImageShack.us
vampire04, as an advice, try to document your projects with an schematic instead of layouts. may universal kasi kung schematic. example, ako mismo, di ko alam kung anong transistor yan. di ko nga alam kung BJT (NPN or PNP)or Mosfet(n-channel or p-channel)...
to be able to output a 5v from relay, you must have an existing 5V, relay is not responsible for making a 5v from 12v, but the regulator will do (LM7805).i made a circuit for you.
